POV-Ray : Newsgroups : povray.binaries.images : Evening at the River Server Time
4 Jun 2026 16:23:30 EDT (-0400)
  Evening at the River (Message 21 to 26 of 26)
Subject: Re: Evening at the River
Date: 10 Nov 2002 08:58:03
Message: <79pssu0ois4jioc7d20kt097u6l029fi2q@4ax.com>
On Sat, 9 Nov 2002 22:52:23 +0100, "Christoph Gerber"
<ni.### [at] bluewinch> wrote:
>The code for the water uses variable reflection but is real simple
>otherwise:
I would suggest a few things:
1. Use POV-Ray 3.5 :)
2. Use fresnel reflection (coupled with a ior of 4/3) and
conserve_energy
3. The pigment is way off, water is normally perfectly clear with only
slight attenuation. Why don't you use something like pigment { rgbf 1
} and add attenuation to the ior (either fade_power 1000 or absorbing
media)?
These are realistic settings, try giving them a shot and see if they
make your scene look more real.
Peter Popov ICQ : 15002700
Date: 10 Nov 2002 10:42:26
Message: <chrishuff-C54E04.10420910112002@netplex.aussie.org>
In article <79pssu0ois4jioc7d20kt097u6l029fi2q@4ax.com>,
Agreed.
> media)?
Actually, a dark opaque pigment makes sense here, you usually can't see
through this kind of water unless you are right above a shallow portion,
and the scene is already slow rendering. I'd get rid of the ambient
though, as a rule I only use a non-0 ambient value for objects that are
supposed to glow.
http://tag.povray.org/
Date: 10 Nov 2002 11:28:11
Message: <t62tsu4m6eq18omqjunq22lug2aji9a3pp@4ax.com>
On Sun, 10 Nov 2002 10:42:10 -0500, Christopher James Huff
Attenuation won't slow it down, but it adds more realism along the
shores and at steep angles of incidence.
>I'd get rid of the ambient though, as a rule I only use a non-0 ambient
>value for objects that are supposed to glow.
Agreed.
Date: 10 Nov 2002 12:19:42
Message: <chrishuff-8D0F13.12192410112002@netplex.aussie.org>
In article <t62tsu4m6eq18omqjunq22lug2aji9a3pp@4ax.com>,
Instead of an opaque texture? Yes, it will be slower. The attenuation
calculations themselves don't cost much, though they are quite a bit
more than just using a constant color value, but any transparency at all
will require tracing at least one refracted ray every time the water is
hit, and then the additional texture calculation of the ground under the
water.
The shores often don't slope gradually out of the water, in fact there
is often an overhang. It takes practice to see into the water in this
situation even when it is clear, and if the water is carrying lots of
silt, you often can't see your feet if you are wading. A nearly black
opaque texture is a decent time saving approximation for this type of
image, even if it won't look good close up.
Date: 10 Nov 2002 14:30:34
Message: <nsctsu0cr34dvmiv8bueqbcelom031meq1@4ax.com>
On Sun, 10 Nov 2002 12:19:24 -0500, Christopher James Huff
>water.
You're right, of course, it's just that I thought it was rgbf 0.1 in
the original post.
Date: 12 Nov 2002 04:12:07
Message: <cah1tuoljeft79a8q0f8a63hil60euc5ec@4ax.com>
On Fri, 8 Nov 2002 22:06:32 +0100, "Christoph Gerber" <ni.### [at] bluewinch>
wrote:
> This scene is derived form my Elevado scene posted a few days ago.
I wonder how it could look under film exposure patch made recently by Karii.
ABX
