POV-Ray : Newsgroups : povray.binaries.images : well [49.7kb] Server Time
5 Jun 2026 07:58:26 EDT (-0400)
  well [49.7kb] (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: well [49.7kb]
Date: 26 Jul 2002 05:22:53
Message: <3D411462.7000705@b0n541.net>
> P.S.: If you want i'll e-mail you the articles in PDF form.
I'm also interested. Is it possible to send them to me too.
Thanks in advance...
Bonsai
    ___ __ __  _ ___ ___  _
   | _ )  \  \( )  _) _ )( )
   | _ \() |\ \ |\ \/ _ \| |
   |___/__/_)\__)___)/ \_)_)
        www.b0n541.net
Date: 26 Jul 2002 09:41:36
Message: <b6k2ku4mdjjnjf4gtd0b16085tidkaqc3d@4ax.com>
They're up for grabbers on http://www.alphac.it/pov
Or, more accurately, they'll be in a minute or so...they're around 9
megs in size.
Peace and POV,
Alex
Date: 26 Jul 2002 11:43:07
Message: <3d416e0b$1@news.povray.org>
"Samuel Benge" <sbe### [at] caltelcom> wrote:
> marabou wrote:
> > on a
> > defined stone and a nearly given radius how many complete stones can be
> > positioned to fill a circle and how great is radius then? is there a
> > formular i can use?
> Hello Marabou. Here is some code for you. I tested and re-tested this
> code and it works great. Note, Radius must be a multiple of Scale. For
> example if Scale is 4, then Radius must be 4, 8, 12, 16, etc. Here is
> the code (I added a camera and light_source for convenience):
> camera{location<0,40,-40>
>   look_at 0
>   angle 35
> light_source{
>   <2,1,-.5>*100000
>   ,<1.5 1.45 1.25>*1.7
> #declare Scale=1;
> #declare Radius=10;
> #declare RotateV=0;
> #while(RotateV<360)
>   superellipsoid{<.2,.2>
>    pigment{rgb 1}
>    scale< Scale, Scale/2, Scale/2 >
>    translate z*Radius
>    rotate y*RotateV
>   #local RotateV = RotateV+360/Radius/3*Scale;
> #end
#declare Scale=3.2;
Same problem :-(
Regards.
Philippe Lhoste (Paris -- France)
Professional programmer and amateur artist
http://jove.prohosting.com/~philho/
Date: 26 Jul 2002 11:55:02
Message: <3D4170D6.5020408@caltel.com>
Hmm, radius can be 3.2, 6.4, 12.8, 25.6, etc....
I guess you don't want to use a decimal radius?
Philippe Lhoste wrote:
> #declare Scale=3.2;
> Same problem :-(
> Regards.
Samuel Benge
Date: 26 Jul 2002 12:34:21
Message: <3d417a0d$1@news.povray.org>
> > #declare Scale=3.2;
> > Same problem :-(
> > Regards.
Oh well, as usual, problem between keyboard and chair...
I didn't read your note about the relationship between radius and scale.
I added it as a comment in your code snippet.
Thank you for this useful piece of code.
Date: 26 Jul 2002 12:48:06
Message: <3D417D45.1090001@caltel.com>
That's usually my problem too ;P
You're welcome. I hope it comes in handy :)
Samuel Benge
Date: 26 Jul 2002 13:23:04
Message: <3d418578@news.povray.org>
"Alessandro Morelli" <ale### [at] alphacit> schrieb im Newsbeitrag
news:b6k2ku4mdjjnjf4gtd0b16085tidkaqc3d@4ax.com...
This is interesting stuff. I would love to see that stone wall generation
method implemented on an isosurface basis, but I don't know if my
programming skills are up to it. If I get it right, it would be only
necessary to implement point 1 to 3 of their method, i.e. the generation and
deformation of the joint pattern and the pathfinding for the stone. Those
paths could probably be used to define some functions which would define an
isosurface (how do I do this? Splines perhaps?). The third dimension could
be implemented with some additional function (like some pattern-function).
The time consuming subdivision-process is not necessary then. Neither their
clipping (which could be done by scaling or some threshold value).
The disadvantage is clear - rendertimes will be quite high. They might be
bearable for smaller walls. Memory usage should be reasonable.
Comments?
Marc-Hendrik
Date: 26 Jul 2002 14:24:41
Message: <3D4193E0.E4A7C56D@duratechindustries.net>
How did you stagger the bricks from row to row?  I'm trying to do my own well,
and so far I've the rows repeating, but I can't seem to figure out how to get
each row to be rotated a little more than the last, i.e. staggered.
-Law
marabou wrote:
> on disk i found a piece of a scene i made long time ago. it is a macro
> which makes a floor, a wall and a well. the well part of macro is buggy as
> everyone can see. that is because i have no solution for the question: on a
> formular i can use? for help i would be appreciated. for comments on the
> pic, too.
>    well.jpg    Type: JPEG Image (image/jpeg)
>            Encoding: base64
Date: 28 Jul 2002 05:42:44
Message: <3d43bc94@news.povray.org>
> well, and so far I've the rows repeating, but I can't seem to figure out
> how to get each row to be rotated a little more than the last, i.e.
> staggered.
you set one row of your well. then you rotate it with a randomly generated
angle. then you do the same with next row. simple, isn't it?
Date: 29 Jul 2002 05:14:55
Message: <3D450702.6090409@b0n541.net>
Thanks.
        www.b0n541.net
