POV-Ray : Newsgroups : povray.binaries.images : [brazil] Athene WIP Server Time
5 Jun 2026 22:21:27 EDT (-0400)
  [brazil] Athene WIP (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: [brazil] Athene WIP
Date: 29 Apr 2002 12:22:54
Message: <3ccd735e@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote :
> It's certainly tricky to work out what they've done with the light. It says
> "pointlight", but the shape looks more like a spotlight.
interesting, why do you think, it's a spotlight?
I see currently no argument to state that ... I'm interested
in the details, why you think it is one ...
Date: 29 Apr 2002 12:29:31
Message: <3ccd74eb@news.povray.org>
"Jan Walzer" <jan### [at] lzernet> wrote in message news:3ccd735e@news.povray.org...
If you look at the back wall and the ceiling, it seems round with a defined
edge? Ignore the light falling on the statue, and just look at the brightest
light on the back wall/ceiling.
Of course, the same effect could be achieved by placing the pointlight on the
other side of a round window.
Date: 29 Apr 2002 13:17:10
Message: <3ccd8016@news.povray.org>
I don't think, this is the shape of a spotlight, what you mean.
I also see this, but this can be achieved by the use of normal
pointlights.
BTW: here's my recent (fast) try ...
Download 'athene.jpg' (16 KB)
Preview of image 'athene.jpg'
Date: 29 Apr 2002 13:22:48
Message: <3ccd8168@news.povray.org>
I can create this shape of the light quite good ...
it's a pity, that the rest of the room doesn't nearly look
as I want it to ...
Download 'athene_room.jpg' (10 KB)
Preview of image 'athene_room.jpg'
Date: 29 Apr 2002 13:27:33
Message: <3ccd8285@news.povray.org>
news:3ccd8168@news.povray.org...
> as I want it to ...
Ah - of course, I'd forgotten about the fade power. I'd still be tempted to
try putting the light around the corner so that only diffuse lighting hits
the statue... (assuming you haven't already done that).
Date: 29 Apr 2002 13:37:12
Message: <3ccd84c8@news.povray.org>
nope, I've not done that, but you can see in the orig, that
the statue and big parts of the floor are directly illuminated
by the lightsource, because there's one sharp shadow for each
object. I don't believe, that brazil is that good, that it can
produce such sharp shadows with such a rendertime ...
Date: 29 Apr 2002 17:13:13
Message: <3ccdb769@news.povray.org>
news:3ccd84c8@news.povray.org...
Yep - the thought had occured. I even wondered if the sharp shadows might be
an indication of a brazil weakness - sharp shadows from such a diffuse light
should be a no-no.
Well, if it's not diffuse lighting, then it looks like a really high, weird,
fade-power.
Date: 29 Apr 2002 19:46:55
Message: <3CCDDC0E.720CFAA5@unforgettable.com>
In POV-Ray, even a spotlight is technically a point light of sorts; the
light emanates from a single point, not from a diffuse surface or array
of points or something like that. Instead of trying to figure out how to
emulate the Brazil lighting with a plain vanilla light (which will, as
pointed out, put way too much light on the statue) why not just use a
spotlight to begin with?
-Xplo
Date: 29 Apr 2002 19:59:33
Message: <3ccdde65$1@news.povray.org>
Could you please let me know where I can get that beautiful Athene model?
Thanks!
George Pantazopoulos
news:3ccc679a@news.povray.org...
> Ok ... now, that I got the model, I can try a bit on
> the lighting.
> I still have the problem, setting upt the lightsource,
> to fit the lighting to the original[1], even without
> the object. I played with fade-power, fade-distance,
> lightness Rad.-settings and what not... I can't get
> the near left wall and the floor be as bright as in the
> original and still have the dark corner in the upper
> background and the "light-blooming" of the floor from the
> left. Interestingly, the most similar resulst I got with
> fade-power=0.5 -- (Does that make sense, what I'm writing?)
> Now, after having a quite satisfying lightsource, I was about
> to tweak the radiosity params, but this is even harder...
> I have big problems, with the time of 8m6sec to get the
> rendered image (even without Focal blur).
> But I still believe, this is my fault, and more advanced users
> are probably able to do better. What does our lighting-expert[2]
> say, what he whould advice ? Of course, I also like input from
> others ;)
> Jan ...
> [1]
http://www.trinisica.com/img/gallery/imageviewer.asp?image=brazil/b02x_athen
e_01.jpg&w=480&h=601
> [2] Kari, I mean you ... ;)
Date: 29 Apr 2002 20:29:36
Message: <3ccde570$1@news.povray.org>
I believe here: http://www.3dup.com/highmodels/1024/0001.html
cu!
