POV-Ray : Newsgroups : povray.binaries.images : Yet another media sky Server Time
6 Jun 2026 12:05:16 EDT (-0400)
  Yet another media sky (Message 21 to 29 of 29)
Subject: Re: Yet another media sky
Date: 13 Mar 2002 03:00:12
Message: <3c8f070c$1@news.povray.org>
*perfect!*
/em closes mouth ...
                  == John ==
"Jide" <jid### [at] kotisoonfi> wrote in message
news:3c8d1cd4@news.povray.org...
> This was a quickie. Just wanted to see how easy it really was. I resized
the
> image in gimp (was 1102*475)
> -Jide
Date: 13 Mar 2002 07:19:20
Message: <3c8f43c8@news.povray.org>
Wow. Really big Wow.
Date: 13 Mar 2002 16:47:21
Message: <3c8fc8e9@news.povray.org>
the
Well, finally someone made it. A true sky with povray.
Congratulations, looks perfect.
Bye
Txemi Jendrix
tji### [at] euskalnetnet
http://www.geocities.com/txemijendrix
Date: 13 Mar 2002 18:04:29
Message: <3c8fdafd$1@news.povray.org>
Great job, but shouldn't the clouds have thickness (I don't see any).
This scene easily shows the problem of sky_sphere, as this sky is a sphere.
POV's problem is that sky_sphere centers on the origin, but needs to center
far below the camera.
Date: 13 Mar 2002 19:23:51
Message: <chrishuff-1F2E5B.19232013032002@netplex.aussie.org>
In article <3c8fdafd$1@news.povray.org>, "RAY" <PCH### [at] yahoocom>
I do. They aren't towering stratocumolus, but they obviously have
thickness. They have leading edges that are brightly lit, and darker
bodies and edges away from the light. I've seen clouds like this many,
many times, they are more common then the thunderhead type.
This isn't a sky_sphere. If the author used the technique I used in the
POV 3.5 demo file, it tries to simulate the actual atmosphere, with
shells of air and clouds centered far below the origin. It looks like he
did a lot better at it then I did, though... ;-)
The sky_sphere feature doesn't "center" anywhere. It is not an object,
it is just a background feature. And it can't do effects like this, just
pigments.
Date: 13 Mar 2002 20:36:36
Message: <3c8ffea4$1@news.povray.org>
I can't see the tops, (they appear to be flat on the sphere
sphere.
center
> pigments.
It appears to center on the camera, wherever the camera is.  This creates
the effect of clouds ramming into the horizon.
Date: 14 Mar 2002 12:18:30
Message: <3c90db66$1@news.povray.org>
"RAY" <PCH### [at] yahoocom> wrote in message news:3c8ffea4$1@news.povray.org...
<snip>
[looks out of window] Hmm, I can't see the tops of the clouds out there either.
I'd suggest you take a look at the source for this scene - the clouds are media
contained within the difference of two spheres, which makes for a fairly
adaptable technique...
Date: 14 Mar 2002 13:29:43
Message: <chrishuff-4F05C4.13292614032002@netplex.aussie.org>
In article <3c8ffea4$1@news.povray.org>, "RAY" <PCH### [at] yahoocom>
Well, that's because you are under them...you can only see the top of
this kind of cloud if you are in an aircraft. (or spacecraft, I guess)
Otherwise, the top is obscured by...the bottom and sides. And these
clouds quite clearly have sides.
It only uses the direction of a ray, so you could say it "centers" on
wherever the ray started from. Its coloration is equivalent to that of a
unit-sphere centered on the origin, but it is just a background, not
centered anywhere.
Date: 14 Mar 2002 13:30:27
Message: <3c90ec43@news.povray.org>
Given the render time you reported I suspect you have background programs running, and
perhaps your render priority is set low. My
900Mhz Duron rendered the same image faster.
Grim
