POV-Ray : Newsgroups : povray.binaries.images : the power of crackle Server Time
6 Jun 2026 09:54:10 EDT (-0400)
  the power of crackle (Message 11 to 20 of 28)
<<< Previous 10 Messages Goto Latest 10 Messages Next 8 Messages >>>
Subject: Re: the power of crackle
Date: 10 Mar 2002 17:59:20
Message: <3c8be548$1@news.povray.org>
You could use a sample of a pattern and apply it to hexagon pillars...
that would give a height for each and they would be much more like actual
basalt, if that was what you were aiming for.  For the centerpoint of each
column, grab a value from one of the patterns like bumps.
    Hmm, gives me an idea.
Cheers!
Chip Shults
Date: 10 Mar 2002 18:08:08
Message: <3C8BE725.2823F022@spiritone.com>
You might be able to speed things up by using a hightfield with a
pigment function. They render fairly fast.
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Tek wrote:
> I've been messing around with the crackle pigment, and got a couple of good
> effects :)
> The first one's an iso surface that looks a bit like a city. It looks more
> city-like from a low camera angle, but I did this orthographic view to use a s a
> desktop backdrop :) BTW, this one took nearly 24 hours to render!! I'm gonna
> have to find a way to speed it up.
> The other picture's a circuit board pigment effect I dreamt up a couple of hours
> ago. Both use crackle with metric 1 to get that nice angular effect.
> What do you think?
> Tek
> http://www.evilsuperbrain.com
Date: 10 Mar 2002 18:14:04
Message: <3c8be8bc@news.povray.org>
> with a pigment function. They render fairly fast.
That won't work well. Completely and almost completely vertical surfaces in
height fields look horrible. And no, it won't help much using a higher
resolution for the height field.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 10 Mar 2002 18:30:48
Message: <slrna8ne3i.u8l.steve@zero-pps.localdomain>
On Sun, 10 Mar 2002 19:29:40 -0000, Tek wrote:
> What do you think?
Source me:-)
                                             or http://start.at/zero-pps
  7:47pm  up 4 days, 21:44,  1 user,  load average: 1.19, 1.10, 1.03
Date: 10 Mar 2002 18:55:13
Message: <3c8bf261@news.povray.org>
> You will always have serious problems with such infinite gradient
> functions.  There are no strongly visible artefacts at this scale, but in
> a more detailed view you will surely see them.
You're right there. I started out rendering from gound level and had to play
with the max_gradient and accuracy settings to reduce the artefacts to an
acceptable level, though from those low angles things rendered a lot quicker so
I could afford some more accuracy.
> Using conventional objects instead, preferably meshes, would be much more
> efficient.
> See for example:
> http://www.interq.or.jp/blue/kawashu/include/i04.html
> http://news.povray.org/povray.binaries.images/12339/
Thanks! I'd had a go at doing something like that, but my results weren't any
quicker to draw than the isosurface! The only problem with this is trying to
imitate the shapes I get using a metric of 1.
Tek
Christoph Hormann <chr### [at] gmxde> wrote in message
news:3C8BD3C2.7F80B4CE@gmx.de...
> > effects :)
s a
> efficient.
> See for example:
> Christoph
> POV-Ray tutorials, IsoWood include,
> TransSkin and more: http://www.tu-bs.de/~y0013390/
> Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Subject: Re: the power of crackle - BIG circuit picture (597k)
Date: 10 Mar 2002 19:03:33
Message: <3c8bf455@news.povray.org>
Here's a biiig backdrop render I've done. The colours are loosely based on
photos I saw once of a CPU... but who cares it looks cool :)
Tek
Tek <tek### [at] evilsuperbraincom> wrote in message news:3c8bb4ff@news.povray.org...
> effects :)
a
hours
> What do you think?
> Tek
Download 'crackcircuit2.jpg' (597 KB)
Preview of image 'crackcircuit2.jpg'
Date: 10 Mar 2002 19:13:14
Message: <3c8bf69a@news.povray.org>
By popular demand, source is now in p.b.s-f :)
Tek
> effects :)
a
hours
> What do you think?
> Tek
Date: 11 Mar 2002 03:31:23
Message: <3C8C6B5A.A940E282@gmx.de>
Marc-Hendrik Bremer wrote:
> Of course I have limited experience, but the problem seems not that big as
> it first appears. There is that adaptive gradient method R. Suzuki mentioned
> once (where? Don't know - had something to do with the old "eval" IIRC.) and
> functions like min(min(abs(x),abs(y)),abs(z))) work quite well with there
> infinite gradient and even with low max_gradient settings.
This function does not have an infinite gradient, it should render
perfectly with max_gradient 2.  However it does have non-continuous
derivatives, but this is no problem for isosurfaces.
> There are problems with the gradient of course and using pigments or
> functions in isosurfaces will sometimes need some high max_gradient
> settings. But I use them all the time and I had no problems, I could not
> solve with some decent settings - even with the really 'evil' brick-pattern,
> which is hard to use in isosurfaces.
> Perhaps your experience is different, but IMHO pattern/pigment-functions are
> very suitable esp. for isosurface beginners.
Pigment and pattern functions are generally suited for isosurfaces as long
as they are continuous.  brick, checker, cells, etc. are not.  You may
have successfully used them,  but every time you change the geometry or
the viewpoint there can be artefacts occuring and it will be unnecessarily
slow so i can only advise against it.
Date: 11 Mar 2002 03:37:16
Message: <usqo8usdu53a2v8n16s35ac0he79a3mjug@4ax.com>
On Sun, 10 Mar 2002 19:29:40 -0000, "Tek" <tek### [at] evilsuperbraincom> wrote:
Oh, man! 24 hours ?! Speed it up ?!
My failed "shortest code contest" entry at this moment has status line:
"165:16:47 Rendering line  159 of  600 supersampled 467 times."
(and there are only 2 flat isosurfaces) so you should be happy.
ABX
Date: 12 Mar 2002 12:11:09
Message: <3c8e36ad@news.povray.org>
Very cool for just a few lines of code. You really should find a way to make
this into a mesh.
 -Shay
