POV-Ray : Newsgroups : povray.binaries.images : Great balls of fire... Server Time
16 Aug 2024 18:19:25 EDT (-0400)
  Great balls of fire... (Message 1 to 10 of 12)
Subject: Great balls of fire...
Date: 16 Jan 2002 21:38:58
Message: <3c463942@news.povray.org>
one blob, one shader...
Parse Time: 1 second
Trace Time: 10 minutes 24 seconds
Peak Memory Used: 241464 bytes (235.8KB)
Pentium 3 450Mhz, 192MB RAM under Windows XP, GUI priority: highest, Render priority:
lowest
Rendered in POVMan 0.71.4 (at a resolution of 640*480, cropped using PSP)
Just another shader-test, inspired by HE Day's Christmas animation :)
cu!
Download 'vuurbal.jpg' (14 KB)
Preview of image 'vuurbal.jpg'
Subject: Re: Great balls of fire...
Date: 17 Jan 2002 00:06:03
Message: <3C465BBA.69F0669F@earthlink.net>
So if i get it right the shader is a function of PovMan...??
The same as the fur...??
Its been a while for me... =] Where is povMan and is it ported to the mac...??
nice stuff... how are you adding the :zk 2000: watermark... Post process or pov
process...??? Glad to be back btw... =]
priority:
> lowest
> cu!
> camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local C=0
> ;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local C=C+1
> ;#end#end L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
> <.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)               // ZK http://www.povplace.be.tf
Date: 17 Jan 2002 00:33:25
Message: <3c466225@news.povray.org>
More or less. Actually the shader itself is not part of POV's SDL: you write the
shader,
and compile it with another program (povslc.exe).  The shader describes the way the
surface is colored, including lighting.  That's why the finish of the object should
have
an ambient of 1 and a diffuse of 0.
But shaders are actually a Renderman-thing.  Hence the name POVMan...
Same principles, other formulas :)
http://www.aetec.ee/fv/vkhomep.nsf/ I think...
> nice stuff...
tnx :)
post processed, although I could do it with POV-Ray :)
cu!
Date: 17 Jan 2002 02:28:12
Message: <3C467E79.93E9A94E@applesnake.net>
excellent... let's see it animated!  (do I ask this everytime?
uh yes.)
-peter
priority:
> lowest
> cu!
Current obsession: "Ballet pour ma fille."
http://www.applesnake.net
Date: 17 Jan 2002 09:12:30
Message: <3c46dbce$1@news.povray.org>
> excellent...
tnx :)
> uh yes.)
A little test-animation is rendering right now :)
cu!
Date: 18 Jan 2002 00:45:16
Message: <3C47B669.27E6A3CC@earthlink.net>
How would you do that inside of pov...?? Without post process...?? So that it would be
the
same all the time no matter what size the image and where the cam. is placed...??
btw i see no port of povMAN for the mac... no bigey tho... =]
shader,
have
> > nice stuff...
> tnx :)
> cu!
Date: 18 Jan 2002 05:07:02
Message: <3c47f3c6@news.povray.org>
Those balls has a fair rendertime considering you used anti alias.. Btw, I
haven't downloaded Povman mostly because it's always behind the newest Pov
version.. But I'm interested in knowing if the shaders will ever be part of
Pov (copyright issues of Renderman?) and how stable they are at the moment?
Many shaders seem to be slow.. is that right?
Hugo
Date: 18 Jan 2002 07:45:48
Message: <3c4818fc@news.povray.org>
be
the
By using a customized lensflare with effect_location the same as camera_look_at.
Well, you don't really need a lensflare for that, but I don't know the exact
calculations
to place an object like that, so it's easier for me to use the lensflare INC-file :)
cu!
Date: 18 Jan 2002 07:48:00
Message: <3c481980$1@news.povray.org>
and my new version is a lot faster :)
I hope they will be part of POV someday.  It's really useful.
Maybe they're slower than regular textures, but try to make smoke like in my animation
without shaders (with media).  It'll be much slower than using shaders.
cu!
Date: 18 Jan 2002 13:08:14
Message: <3C48648E.3CEEACBF@earthlink.net>
Would that work in mega pov...??
If so can u give some pointers or recourses i can research...
I tried to use a bump map for awhile but it looked ugly on some scenes and did not
show at
all in others... thanks for now... =]
ceeyuu too ',
would be
> the
calculations
> cu!
