POV-Ray : Newsgroups : povray.binaries.images : oops I dropped it (2 images, 12kb each) Server Time
30 Mar 2026 00:06:52 EDT (-0400)
  oops I dropped it (2 images, 12kb each) (Message 1 to 7 of 7)
Subject: oops I dropped it (2 images, 12kb each)
Date: 3 Jan 2002 16:52:27
Message: <3c34d29b$1@news.povray.org>
Ok ok ok... it's all been done.  I was sitting there on my checkered floor
(you know, the one out in the middle of nowhere with no walls, ceiling or
landscaping to be found for miles. . .) playing with my glass ball. . . then
I dropped it.  Broke it clean in half.  Oh well.
Download 'new1.jpg' (12 KB) Download 'new2.jpg' (13 KB)
Preview of image 'new1.jpg'
Preview of image 'new2.jpg'
Subject: Re: oops I dropped it (1 image 13 kb)
Date: 3 Jan 2002 17:17:38
Message: <3c34d882$1@news.povray.org>
Found some electrical tape and taped it up...
Download 'tapedup.jpg' (14 KB)
Preview of image 'tapedup.jpg'
Date: 3 Jan 2002 17:21:38
Message: <3c34d972@news.povray.org>
LOL!
BTW, it looks like you used simple normals to fake the break. It would look better
with a real crack (hint: intersection with a heightfield).
#local j=text{ttf"arial""JRG".2,0}#local J=0;#while(J<10)#local R=0;#while
(R<2)#local G=0;#while(G<1)#if(inside(j<R,G.1>))object{j scale.025translate
<R-1G-J/20J/-40+2>pigment{rgb<9J>}}#debug"O"#else#debug" "#end#local G=G+
.025;#end#local R=R+.05;#debug"\n"#end#local J=J+1;#end// JRG
Home: http://digilander.iol.it/jrgpov
"Dayv" <gda### [at] homecom> ha scritto nel messaggio
news:3c34d882$1@news.povray.org...
Date: 4 Jan 2002 18:39:49
Message: <3c363d45$1@news.povray.org>
"JRG" <jrg### [at] hotmailcom> wrote in message
news:3c34d972@news.povray.org...
> LOL!
look better
You are correct, sir!  Didn't really invest much time in it.  Never had a
lot of success with heightfields at all.  After 6 years, still just slightly
less skilled than a novice!  Maybe I'll give that a try though.  :)
-Dayv
Subject: New version (1 image 12 kb)
Date: 5 Jan 2002 15:09:30
Message: <3c375d7a@news.povray.org>
Ok... here's the new and improved version of the two halves using a height
field.  I rendered this one in megapov and used photons.  (Never used
MegaPov before this week.)
Questions, comments?
-Dayv
Download 'newagain.jpg' (12 KB)
Preview of image 'newagain.jpg'
Subject: Re: New version (1 image 12 kb)
Date: 5 Jan 2002 16:15:01
Message: <3c376cd5@news.povray.org>
The scene is a bit too bright to make the photons visible. I would lower the overall
brightness of the scene.
The glass texture looks good, but a bit too 'glowing'. Either this is due to the high
overall brightness of the image or to too high diffuse and ambient values. I would
keep diffuse as low as possible (try 0.05) and set ambient to 0. The real crack looks
much better now.
BTW, why don't you simply use POV 3.5? Are you a Linux user? ;)
Date: 6 Jan 2002 12:33:06
Message: <3c388a52$1@news.povray.org>
to the high
I would
I'll try that, thanks.  The light source is rather bright. . . rgb 1.5  The
scene was originally much darker.  It seemed to start glowing after I turned
on the photons.  I'll tinker with it a bit.
>The real crack looks much better now.
:)  thank you.
No, have Windows...  my 3.5 beta version just ran out a few days ago.  Guess
I have to download again.
-Dayv
