POV-Ray : Newsgroups : povray.binaries.images : Capriccio - stairs (73+135k) Server Time
20 Jun 2026 13:56:33 EDT (-0400)
  Capriccio - stairs (73+135k) (Message 41 to 44 of 44)
Subject: Re: Capriccio - stairs (73+135k)
Date: 16 May 2003 01:06:34
Message: <3EC4700B.8DD782ED@mail.com>
That reminds me my very old picture in traditional media:
http://propro.ru/go/gallery/images/knights.jpg
The following image is my attempt (which lasts two years :)
to do the same on computer. And the second image is a
heightfield created from the first image.
Gena.
Download 'knights1.jpg' (51 KB) Download 'knights2.jpg' (45 KB)
Preview of image 'knights1.jpg'
Preview of image 'knights2.jpg'
Date: 18 May 2003 05:47:36
Message: <3EC75749.7040702@ibras.dk>
Peter Hertel wrote:
> included all the figures in the scene, thus only produsing one
> height_field.
I would like to put a dummy height_field in in my model, so when yours
is ready, it should just be a matter of replacing my dummy file with it,
and it will be in place on the cathedral. I hope.
To do that, I need to know what file type you are using, and what you a
going to call the height_field file.
/Ib
Date: 18 May 2003 09:20:18
Message: <3ec78892$1@news.povray.org>
> > height_field.
it,
a
I'd like to use PNG if it's okay, and the filename can be something like
"cathedral_relief.png" all lowercase. Or use anything you like, it
wouldn't matter to me.
What resolution and aspect ratio are you going to use? Are you going to
use CSG to cut out a triangle of the height_field? If you could give me
a copy of the dummy image, I'll adapt the aspect ratio from that.
-Peter
Date: 18 May 2003 10:41:18
Message: <3EC79C1E.8080504@ibras.dk>
PNG is fine. It doesn't really matter, as long as we agree.
Yes, I'm cutting the hf. Here is the code:
#declare FcdPedimentTympanum=difference {
    object {
       height_field {png "cathedral_relief.png" smooth }
       scale <700, 20, 171>
       rotate <-90, 0, 0>
       translate <-350, 0, 0>
    plane {-y, 0 rotate <0, 0,  26> translate <-350, 0, 0> }
    plane {-y, 0 rotate <0, 0, -26> translate < 350, 0, 0> }
    plane {-z, 0 translate <0, 0, 1000> }
For some reason, I don't quite understand, my dummy hf projected out
very far behind the facade, that's why I cut with the -z-plane.
/Ib
