POV-Ray : Newsgroups : povray.binaries.images : erosion structures 2 (127k) Server Time
16 Sep 2025 16:28:29 EDT (-0400)
  erosion structures 2 (127k) (Message 1 to 10 of 10)
Subject: erosion structures 2 (127k)
Date: 29 Oct 2001 18:08:58
Message: <3BDDE180.B7B11090@gmx.de>
Finished this render today: 3 days, 21 hours.
I think i will not work much more on this particular setup, the sky surely
could use some improvements, but it's more interesting to try some
different shapes.
I followed R. Suzuki's suggestion to try using 'evaluate' to speed up the
render.  Although i don't have a direct comparison, i think it is
significantly faster.  Radiosity settings are slightly higher quality than
before.
The statistics show a number of DNoise calls being a new personal record
for me: nearly 257 billions, the previous maximum was 220 billions ;-)
What's probably more interesting is the histogram i generated for the
render, it can be found on:
http://www.schunter.etc.tu-bs.de/~chris/files/lnd_hist.png
It also shows that the horizon is not slower than the rest of the scene.
Download 'lscp_erosion2.jpg' (127 KB)
Preview of image 'lscp_erosion2.jpg'
Subject: Re: erosion structures 2 (127k)
Date: 29 Oct 2001 18:18:24
Message: <3bdde3c0$1@news.povray.org>
Much better! Now the foreground looks great too, and as always the sky is
outstanding. Only the most distant clouds are a bit flat.
What about adding some dry plant...
Jonathan.
"Christoph Hormann" <chr### [at] gmxde> ha scritto nel messaggio
news:3BDDE180.B7B11090@gmx.de...
> different shapes.
> before.
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 29 Oct 2001 20:36:19
Message: <3bde0413@news.povray.org>
That terrain is fascinating. An exquisite render, Christoph! I'll try to
remember the evaluate-trick. I'm downloading beta7 right now. I'm going to
do something with radiosity I think... :)
Date: 30 Oct 2001 03:20:11
Message: <3BDE62BB.3B28C6DF@gmx.de>
Yes, they are simply a flat texture, should be improved.
Hmm, what kind of plants? Maybe some grass...  I'm a bit afraid of the
memory requirements, radiosity already takes 220 Mb.
Date: 30 Oct 2001 03:55:28
Message: <3BDE6B01.E6DA453E@gmx.de>
Thanks!
> I'll try to remember the evaluate-trick.
I will do some more experiments with the parameters, there's always the
danger of holes occurring, but i had luck this time...
Date: 30 Oct 2001 07:55:41
Message: <3bdea34d@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
: What's probably more interesting is the histogram i generated for the
: render, it can be found on:
: http://www.schunter.etc.tu-bs.de/~chris/files/lnd_hist.png
  Try inverting that image (ie. making it negative) with an image editing
program. Looks almost natural.
Date: 30 Oct 2001 08:16:16
Message: <3BDEA81F.511401CD@gmx.de>
Yes, indeed.
The reason is probably that the slowest regions are those where most
radiosity samples are not taken from the sky but from the isosurface
itself.
Date: 1 Nov 2001 12:02:54
Message: <3BE16D30.AE7CE8B1@ndh.net>
Hi Tracers!
Monstrous... what computer do you use?!? Thunderbird 1.4 GHz with 2 gigs of
RAM or even greater?
See you in Khyberspace - http://www.geocities.com/electricafghan/index-e.html
Afghanistan Chronicle: http://www.ndh.net/home/bleimann/
Yadgar
Date: 1 Nov 2001 12:02:59
Message: <3BE16DD4.8BA76717@ndh.net>
...or some shaggy Taliban troops sniping from behind the rocks!
Yadgar
Date: 1 Nov 2001 12:26:58
Message: <3BE185E1.9D532F81@gmx.de>
512 Mb RAM are perfectly sufficient, it took just above 200 Mb and only
for radiosity, without only 300k.  Processor is an Athlon 1 GHz, but
that's just a matter of patience... ;-)
