POV-Ray : Newsgroups : povray.binaries.images : POV / MAX2.5 Server Time
20 Sep 2025 06:38:14 EDT (-0400)
  POV / MAX2.5 (Message 1 to 6 of 6)
Subject: POV / MAX2.5
Date: 30 May 2001 03:27:41
Message: <3B14A108.7060000@xlstudio.com>
this is not a quality scene test
this is not my model (viewpoint)
this is not a pov scene (at the origin)
this IS a POV rendering
I am working on a MAX2.5 plug-in to render in POV.
this is one of the first image I produced.
the plug-in is a MAX2.5 Renderer that generates a POV scene and call POV
to render the scene. with this, you don't have to export your scene to a
3DS file, then convert it to a POV scene and then render it with POV.
You just have to clic: "render" (a teapot) and everything is done
automaticaly.
what the plug does (24 hours of work for now):
- geometry (he he !!) with smooth_triangles
- basic parameters of  pigment: color, specular, metallic, ambient
- texture mapping (using MegaPOV0.7 for its UV feature)
- point lights (omni in MAX)
- spot lights
- target camera (camera with a "look_at")
- render a still image or an animation (sequence of images, no video
computation for now)
- activation of radiosity and antialiasing
what is planned:
- "free camera" (no "look_at")
- "cylindrical light"
- "multi-sub" (an object with multiple image_map)
- fog
- postprocess effects (stars, blur ?, ...)
- more pigment parameters
- maybe procedural pigments and normal
- correct some annoying messages from MAX
            David Gemelli
Download 'helico.jpg' (22 KB)
Preview of image 'helico.jpg'
Subject: Re: POV / MAX2.5
Date: 30 May 2001 10:19:40
Message: <pc0ahtc57ls2ahu5br9r069rlnobe3usbt@4ax.com>
On Wed, 30 May 2001 09:28:08 +0200, gemelli david
>automaticaly.
This sounds good, but... please... carefully... read... POVLEGAL. If
you are able to keep within the bounds of the license, cool!
Peter Popov ICQ : 15002700
Date: 30 May 2001 10:32:07
Message: <3b150467@news.povray.org>
HURRAH!!!!!!!!
(see povray.co.uk)
PGP Public Key
Date: 30 May 2001 11:06:48
Message: <3B150912.3040305@xlstudio.com>
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
yes, I know I have to read it carefully. just didn't had time.
but I'm not afraid, because I don't use the POV code into the plug-in,
it is like an export plug-in that allows you to call POV directly for
you. And I won't have this plug-in sold or something like that...
thanks for the advice !
             David Gemelli
PS: if I have question about particular english terms, do you think I
can ask to a POV team member or someone else ?
Date: 30 May 2001 11:41:38
Message: <3B1510F0.4050805@xlstudio.com>
I read the POVLEGAL.DOC file and then sent a mail to
"tea### [at] povrayorg" to be sure...
so, waiting for the answer, I'm stopping my work on the plug-in.
I hope, it will be possible to continue this, I found this work very
interesting (regarding POV and MAX)
            David Gemelli
Date: 30 May 2001 12:58:55
Message: <tj9ahtc3d0klee7hd18bpr8t9ftu2pm5et@4ax.com>
On Wed, 30 May 2001 16:52:02 +0200, gemelli david
The boundary line between what POV does and what it does not must
always be very clear. The user must also know that POV is a separate
program available from povray.org and... well, and the rest of
POVLEGAL :) Read it carefully it's not that long. Shorter than your
plugin code for sure :))
The Team is busy working on 3.5. Ask the TAG. That's why we're here.
<voice="Xan">
  We live to serve!
</voice>
