POV-Ray : Newsgroups : povray.binaries.images : Strata (Tiling) [25 + 32 Kbu, jpg] Server Time
29 Mar 2026 08:43:09 EDT (-0400)
  Strata (Tiling) [25 + 32 Kbu, jpg] (Message 1 to 10 of 19)
Subject: Strata (Tiling) [25 + 32 Kbu, jpg]
Date: 12 May 2001 07:42:23
Message: <3AFD2235.18DEAD6A@free.fr>
This two pictures are the last of the patterns in my tiling patch.
Yep... It's a code patch, not a script.
Available soon on http://pov.grimbert.cjb.net/
I'm not happy at all with the naming used, but I have no time
to find good names... I'm still hooked on the 2D paving of the plane,
specially with n connected square/hexagon/triangle pieces.
The good news is that, at least for that kind of paving, I have found
a naming scheme.
In the meantime, maybe someone will find a macro/script to provide the
same kind of paving, but I doubt it...
Download 'carrelage14.jpg' (32 KB) Download 'carrelage15.jpg' (25 KB)
Preview of image 'carrelage14.jpg'
Preview of image 'carrelage15.jpg'
Subject: Re: Strata (Tiling) [25 + 32 Kbu, jpg]
Date: 14 May 2001 00:04:15
Message: <3AFF5977.3EB47150@pobox.com>
Alas no 3.4.3.3.4, nor its dual the `Cairo' tessellation.
Anton Sherwood  --  br0### [at] p0b0xcom  --  http://ogre.nu/
Date: 14 May 2001 03:26:06
Message: <3AFF88FF.57992788@atosorigin.com>
the 3.4.3.3.4 is still on the design table, I just need more time...
as well as the two 6.3.3.3.3 versions, and 12.6.4 and 12.12.3
The "cairo"* is also part of the new patterns I have found, thanks to
Vahur Krouverk and a little web surfing. I did not realise it was the dual
of the 3.4.3.3.4 . I wonder if any of the other archimedians have duals, and
what they would look like... Thanks :-> I already had so little time, now I
have a new branch to explore !
Date: 14 May 2001 13:59:34
Message: <3b001d06@news.povray.org>
are you talking about universal macro generating pigment form count of
segment/vertex/figures or script for selected patterns ?
here is my result for your first pigment
script is not optimized, I want to show way of finding
of course MegaPOV required
#macro Sig(A,B,X)_(A,B)_(B,X)_(X,A)#end#macro _(A,B)cylinder{<A.x,A.y,3>,<B.u,
B.v,3>.1,9}#end global_settings{max_trace_level 9}light_source{0 1}camera{up y
*4right-3*x}blob{_(<3,1>,<1,-5>)_(<2,-2>,<4,-2>)Sig(x,<-1,1.5>,<1,3>)_(z-1,z-4
)pigment{rgb 1}}box{-3 3pigment{rgb 0}finish{reflection 1}hollow} // POV-Ray31
Download 'strata.jpg' (39 KB) Download 'strata.pov.txt' (3 KB)
Preview of image 'strata.jpg'
Date: 14 May 2001 14:32:42
Message: <slrn9g096f.okg.ron.parker@fwi.com>
Why "of course"?  Here are a few that work in plain ol' POV.  I started
to do 6.4.3 but never finished it.
#macro _6_6_6()
  #local G=pigment {gradient x color_map {[0 rgb 1][1 rgb 0]} scale 1.000001}
  #local B=pigment{
    radial
    pigment_map{
      #local i=0;
      #while(i<6)
        [i/6 G rotate(30+60*i)*y]
        [(i+1)/6 G rotate(30+60*i)*y]
        #local i=i+1;
  #local T2=sqrt(3)/2;
  radial
  pigment_map{
    [1/3 B translate<.5,0,-T2>]
    [1/3 B translate<-1,0,0>]
    [2/3 B translate<-1,0,0>]
    [2/3 B translate<.5,0,T2>]
  translate x
  warp{repeat 1.5*x flip x}
  warp{repeat .5*sqrt(3)*z flip z}
#macro _8_8_4()
  #local G=pigment {gradient x color_map {[0 rgb 1][1 rgb 0]} scale .5000001}
  #local H=pigment {
    gradient x
    pigment_map {
      [.5 G][.5 G translate -.5*x scale <1-sqrt(2),1,1> translate .5*x]
  radial
  pigment_map{
    #local i=0;
    #local j=8;
    #while(i<j)
      [i/j H rotate(180/j+360/j*i)*y]
      [(i+1)/j H rotate(180/j+360/j*i)*y]
      #local i=i+1;
  rotate 180/j*y
  warp{repeat .5*x flip x}
  warp{repeat .5*z flip z}
#macro _12_4_6( )
  #local T15=tan(pi/12);
  #local Hx=pigment {
    radial
    pigment_map{
      #local i=0;
      #while(i<6)
        [i/6 G scale <T15*sqrt(3),1,1> rotate(30+60*i)*y]
        [(i+1)/6 G scale <T15*sqrt(3),1,1> rotate(30+60*i)*y]
        #local i=i+1;
    rotate 30*y
  #local H=pigment{
    gradient x
    pigment_map {[.5 G][.5 Hx translate (.5+T15*sqrt(3)/2)*x]}
  #local J=pigment{
    gradient x
    pigment_map {[T15/2 G scale <T15,1,1>]
                 [T15/2 Hx translate (T15*(1+sqrt(3)))/2*x]}
  #local Sq=pigment {
    radial
    pigment_map{
      #local i=0;
      #while(i<4)
        [i/4 J rotate(45+90*i)*y]
        [(i+1)/4 J rotate(45+90*i)*y]
        #local i=i+1;
    rotate 45*y
  #local I=pigment{
    gradient x
    pigment_map {[.5 G][.5 Sq translate (.5+.5*T15)*x]}
  #local B=pigment{
    radial
    pigment_map{
      #local i=0;
      #while(i<12)
        [i/12 #if (i/2 = int(i/2)) I #else H #end rotate(15+30*i)*y]
        [(i+1)/12 #if (i/2 = int(i/2)) I #else H #end rotate(15+30*i)*y]
        #local i=i+1;
    rotate 15*y
  radial
  pigment_map{
    [1/3 B translate<.5,0,-T2>*(.5+T15*sqrt(3)/2)]
    [1/3 B translate<-1,0,0>*(.5+T15*sqrt(3)/2)]
    [2/3 B translate<-1,0,0>*(.5+T15*sqrt(3)/2)]
    [2/3 B translate<.5,0,T2>*(.5+T15*sqrt(3)/2)]
  warp{repeat 1.5*x*(.5+T15*sqrt(3)/2) flip x}
  warp{repeat .5*sqrt(3)*z*(.5+T15*sqrt(3)/2) flip z}
#macro _12_12_3( )
  #local G=pigment {gradient x color_map {[0 rgb 1][1 rgb 0]} scale 1.00001}
  #local P=tan(15*pi/180)/sqrt(3);
  #local H=pigment {gradient x
    pigment_map {[.5/(1+P) G scale <.5/(1+P),1,1>]
                 [.5/(1+P) G scale <.5/(1+P),1,1> translate -.5/(1+P)*x
                  scale <-P,1,1> translate .5/(1+P)*x]}
    scale <2,1,1>
  #local B=pigment{
    radial
    pigment_map{
      #local i=0;
      #local j=12;
      #while(i<j)
        #local i=i+1;
    rotate 180/j*y
  radial
  pigment_map{
  translate x
//plane {y 0 pigment {_6_6_6()} finish {ambient 1}}
//plane {y 0 pigment {_8_8_4()} finish {ambient 1}}
//plane {y 0 pigment {_12_12_3()} finish {ambient 1}}
plane {y 0 pigment {_12_4_6()} finish {ambient 1}}
camera {location 3*y sky z look_at 0}
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 14 May 2001 17:45:56
Message: <slrn9g0kgq.opt.ron.parker@fwi.com>
And here's that code:
#macro _6_4_3( )
  #local G=pigment {gradient x color_map {[0 rgb 1][1 rgb 0]} scale .500001}
  #local G1=pigment {gradient x color_map {[0 rgb 1][1 red 0]} scale .500001}
  #local SquG=pigment {gradient x pigment_map {
               [.5/sqrt(3) G scale 1/sqrt(3)]
               [.5/sqrt(3) G scale 1/3 translate (.5/3+.5/sqrt(3))*x]}}
  #local Sq = pigment {
    radial
    pigment_map {
      #local i=0;
      #while(i<4)
        [i/4 SquG rotate(45+90*i)*y]
        [(i+1)/4 SquG rotate(45+90*i)*y]
        #local i=i+1;
    rotate 45*y
  #local HexG=pigment {gradient x pigment_map {
               [.5 G1][.5 Sq translate (.5/sqrt(3)+.5)*x]}}
  #local Hex = pigment {
    radial
    pigment_map {
      #local i=0;
      #while(i<6)
        [i/6 HexG rotate(30+60*i)*y]
        [(i+1)/6 HexG rotate(30+60*i)*y]
        #local i=i+1;
  radial
  pigment_map{
    [1/3 Hex translate<.5,0,-sqrt(3)/2>*(.5+.25*sqrt(3))]
    [1/3 Hex translate<-1,0,0>*(.5+.25*sqrt(3))]
    [2/3 Hex translate<-1,0,0>*(.5+.25*sqrt(3))]
    [2/3 Hex translate<.5,0,sqrt(3)/2>*(.5+.25*sqrt(3))]
  translate (.5+.25*sqrt(3))*x
  warp{repeat 1.5*x*(.5+.25*sqrt(3)) flip x}
  warp{repeat .5*sqrt(3)*z*(.5+.25*sqrt(3)) flip z}
plane {y 0 pigment {_6_4_3()}finish {ambient 1}}
camera {location 5*y sky z look_at 0}
Date: 14 May 2001 17:50:26
Message: <slrn9g0kp9.opt.ron.parker@fwi.com>
On 14 May 2001 17:45:56 -0400, Ron Parker wrote:
Oops, looks like I left some debugging stuff in.
Delete this line.
This G1 should be G.
Date: 15 May 2001 04:08:21
Message: <3b00e3f5@news.povray.org>
Ron Parker wrote in message ...
> Why "of course"?
"of course" because of keyword function{} and becouse "version unofficial
megapov .6;"
I was sure that it is possible
and it is great
Date: 16 May 2001 12:41:55
Message: <slrn9g5bek.q2r.ron.parker@fwi.com>
>and it is great
Actually, there are bugs in some of them, particularly the 6.4.3.4
implementation (starting with its name, but the tiling is a little off
too.)  Also, I've rewritten them to work with nongradient pigments as
arguments and completed the set (well, almost completed the set... I
still lack the two versions of 6.3.3.3.3)
If anyone finds this even vaguely interesting, I'd be happy to post the
whole set to a scene-files newsgroup.
Date: 16 May 2001 16:43:16
Message: <slrn9g5pj6.q6q.ron.parker@fwi.com>
>>and it is great
One last update... I now have both versions of 6.3.3.3.3 as well.
