A challenge was given a week or two ago to
produce realistic lightning in povray. I thought I'd have
a go at it.
The pictures below are of a very preliminary version
of my lightning macro.
Comments? Criticisms? Suggestions?
Gail
* gsh### [at] monotix co za * System.dat not found. *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k *
* If at first you don't succeed, call it version 1.0 *
Download 'lightning1.jpg' (10 KB)
Download 'lightning2.jpg' (8 KB)
Download 'lightning3.jpg' (8 KB)
Preview of image 'lightning1.jpg'
Preview of image 'lightning2.jpg'
Preview of image 'lightning3.jpg'
> a go at it.
Sure :-)
-The shape looks good, but the decrease in width is too strong IMO (in many
cases, the width/brightness of a lightning stays quite constant during the path)
-It would be good to have the color fading from white to black/darkblue at the
edges. (you seem to use objects for the lightning, so this is probbaly not that
easy)
Christoph Hormann <chr### [at] gmx de>
the
that
> easy)
Yes it is, with the blob pattern.
Looks fine to me.
> easy)
Actually I did this for my (well, not only my) IRTC-entry for History.
I just filled the object with a constant media with a very light blue.
At the edges, where there is less media to look through, it looks more
blue than inside the object (which is white because very light blue +
very light blue = white, well, in povray anyway :-)
ZK
http://www.povplace.be.tf
"Christoph Hormann" <Chr### [at] schunter etc tu-bs de> wrote in
message news:39B8D89E.A28789A8@schunter.etc.tu-bs.de...
many
path)
the
that
| easy)
I concur. This would do well for cloud to cloud lightning but in the case
of cloud to ground it should probably have a near constant main bolt. If a
large diffuse and lower ambient is used the edges will fade but since that's
light source dependant that could not work right. Transparency could be
used along with a strong highlight but once again is too dependant on
external light.
Tony's idea to use media is possibly the best answer I can think of too.
Looks promising! Can you make it hit (as well as originate from) a
specific point?
Abe
> a go at it.
> Gail
> [Image]
> [Image]
> [Image]
The general appearance looks very good to me. Just curious - does your
lightning emit light? I tried adding media to a bolt of lightning to get the
halo effect, but it didn't light up anything around it. (Plus, it looked
like crap.) Maybe adding some bluish-colored fade_power light sources along
the length of the bolt would do the trick, in order to light up the clouds
that the lightning is coming from...
Dave
Well done, Gail! :)
Grim
How about combining this with the new Glow light in MegaPov+ ?
> a go at it.
> Gail
> [Image]
> [Image]
> [Image]
