POV-Ray : Newsgroups : povray.binaries.images : Lightning (3 pics 30kbu) Server Time
18 Feb 2025 17:56:06 EST (-0500)
  Lightning (3 pics 30kbu) (Message 1 to 10 of 21)
Subject: Lightning (3 pics 30kbu)
Date: 8 Sep 2000 06:17:21
Message: <39b8bcb1@news.povray.org>
A challenge was given a week or two ago to
produce realistic lightning in povray. I thought I'd have
a go at it.
The pictures below are of a very preliminary version
of my lightning macro.
Comments? Criticisms? Suggestions?
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Download 'lightning1.jpg' (10 KB) Download 'lightning2.jpg' (8 KB) Download 'lightning3.jpg' (8 KB)
Preview of image 'lightning1.jpg'
Preview of image 'lightning2.jpg'
Preview of image 'lightning3.jpg'
Subject: Re: Lightning (3 pics 30kbu)
Date: 8 Sep 2000 08:15:34
Message: <39B8D89E.A28789A8@schunter.etc.tu-bs.de>
> a go at it.
Sure :-)
-The shape looks good, but the decrease in width is too strong IMO (in many
cases, the width/brightness of a lightning stays quite constant during the path)
-It would be good to have the color fading from white to black/darkblue at the
edges. (you seem to use objects for the lightning, so this is probbaly not that
easy)
Date: 8 Sep 2000 10:49:07
Message: <39b8fc63@news.povray.org>
the
that
> easy)
Yes it is, with the blob pattern.
Date: 8 Sep 2000 11:00:45
Message: <39b8ff1d@news.povray.org>
Looks fine to me.
Date: 8 Sep 2000 11:42:51
Message: <39B90944.98014D88@urc1.cc.kuleuven.ac.be>
> easy)
Actually I did this for my (well, not only my) IRTC-entry for History.
I just filled the object with a constant media with a very light blue.
At the edges, where there is less media to look through, it looks more
blue than inside the object (which is white because very light blue +
very light blue = white, well, in povray anyway :-)
ZK
http://www.povplace.be.tf
Date: 8 Sep 2000 13:52:52
Message: <39b92774$1@news.povray.org>
"Christoph Hormann" <Chr### [at] schunteretctu-bsde> wrote in
message news:39B8D89E.A28789A8@schunter.etc.tu-bs.de...
many
path)
the
that
| easy)
I concur.  This would do well for cloud to cloud lightning but in the case
of cloud to ground it should probably have a near constant main bolt.  If a
large diffuse and lower ambient is used the edges will fade but since that's
light source dependant that could not work right.  Transparency could be
used along with a strong highlight but once again is too dependant on
external light.
Tony's idea to use media is possibly the best answer I can think of too.
Date: 8 Sep 2000 16:18:15
Message: <39B94917.CA2E49CC@taconic.net>
Looks promising! Can you make it hit (as well as originate from) a
specific point?
Abe
> a go at it.
> Gail
Date: 8 Sep 2000 23:07:07
Message: <39b9a95b@news.povray.org>
The general appearance looks very good to me. Just curious - does your
lightning emit light? I tried adding media to a bolt of lightning to get the
halo effect, but it didn't light up anything around it. (Plus, it looked
like crap.) Maybe adding some bluish-colored fade_power light sources along
the length of the bolt would do the trick, in order to light up the clouds
that the lightning is coming from...
Dave
Date: 10 Sep 2000 01:39:14
Message: <39bb1e82@news.povray.org>
Well done, Gail! :)
Grim
Date: 10 Sep 2000 04:43:28
Message: <39BB49BC.CB7DE99E@home.com>
How about combining this with the new Glow light in MegaPov+ ?
> a go at it.
> Gail
