POV-Ray : Newsgroups : povray.binaries.images : Summerglass (60 kbu) Server Time
1 Oct 2024 13:19:04 EDT (-0400)
  Summerglass (60 kbu) (Message 11 to 17 of 17)
Subject: Re: Summerglass (60 kbu)
Date: 30 Aug 2000 12:10:04
Message: <39AD3214.E09D8CDA@aetec.ee>
Seems like You live in southern part of Bayern, look out of window and
render...
Date: 30 Aug 2000 12:16:33
Message: <39AD339F.23E896E4@schunter.etc.tu-bs.de>
> render...
In summer ?
Date: 30 Aug 2000 14:55:44
Message: <MPG.141761385d6140ba98979b@news.povray.org>
On Wed, 30 Aug 2000 12:06:33 +0200, Hans-Detlev Fink wrote...
> The snowy rocks are a superposition of 2 RMFs.
> The tree: thanks to Andrew Clinton for his splinetree.
> The grass: thanks to Gilles Tran for his mesh grass.
> The color banding is due to jpg compression, this
> scene needs big size to make the glass look lost in
> the ice desert.
I was looking at this, when I had an idea you'll probably hate... <grin>
If it were possible to alter Gilles' macro to create a 'grass' of tree
objects, then you could have a more useful sense of scale, with the large
tree in the centre of the dome representing the 'tree of life' from
various mythologies.
Of course it would be almost impossible to tell that the 'grass' was
actually a forest canopy at the size it would render.
Oh, and I really like the image BTW, it reminds me of various console
RPG's set in post apocalyptic worlds where some technologies are still
functioning.
Bye for now,
     Jamie.
Date: 31 Aug 2000 04:21:41
Message: <39AE1594.2E53D010@enst.fr>
	You don't need Gilles' macro to do that. Something like the following
(untested) code should do:
#declare S = seed (1234);
#declare Jitter = 0.2;
#declare X = 0;
#while (X < 100)
  #declare Y = 0;
  #while (Y < 100);
    object {
      Tree
      translate <X+Jitter*rand (S), 0, Y+Jitter*rand(S)>
    #declare Y = Y + 1;
  #declare X = X + 1;
	Of course, it needs to be adapted to the size of the trees (something
like 0.4 units wide in this example). Note that if you use a mesh tree,
this shouldn't use too much memory but if you use a blob or CSG tree,
your computer probably won't have enough memory to do it...
Date: 31 Aug 2000 05:32:42
Message: <399D0254.1F1AEB8B@pecos.no.spam.de>
This is a very nice idea, worth a separate project, and I do not at
all hate it. Though, this wouldn't be possible with Gilles' macro
since it's a mesh. OTOH, with other grass macros I've seen it
shouldn't be a big problem, but sloooow ...
I agree with the other posters that the scale and/or perspective
have to be changed anyway.
> functioning.
Thank you. Yes, this and various other scenarios come to mind.
-Hans-
Date: 31 Aug 2000 05:43:15
Message: <399D04CC.2F182751@pecos.no.spam.de>
Christoph Hormann wrote:
> Thanks very much for that detailed explanations, the RMF parameters are quite
> interesting, i have never used such values.
RMF parameters being an endless story ...
> The isosurface function was a bit irritating first, because i usually do the
> scaling and translation in the pigment (this allows to test the components as
> textures, which is a lot faster than on the isosurface) but it surely also works
> this way.
Well, actually I didn't spend much brain on code design here, just
a "grown project", you know ;)
> I somehow wonder about the low max_gradient, in my last landscape i got values
> around 100-200 using eval, but i can't see any errors in your picture.
Yes, I started with even smaller values and then eval gave something
like 11.xx. Values around 8 definitely produce discontinuities and
gaps in the surface.
-Hans-
Date: 31 Aug 2000 16:55:20
Message: <MPG.1418d29b772401fb98979e@news.povray.org>
On Thu, 31 Aug 2000 10:21:40 +0200, =?iso-8859-1?Q?J=E9r=F4me?= Berger
wrote...
> #declare X = 0;
> #while (X < 100)
>   #declare Y = 0;
>   #while (Y < 100);
>     object {
>       Tree
>     #declare Y = Y + 1;
>   #end
>   #declare X = X + 1;
> #end
Ah, but this relies on you speaking fluent POV code...  I don't, I speak
Moray relatively fluently <grin>
The reason I mentioned modifying Gilles' macro is that that was what Hans
said he was using, and I, in my innocence of such things <grin> assumed
it would be easier to alter existing code to do something than to rewrite
from scratch.
Ah well, bye for now,
     Jamie.
