GrimDude wrote:
> With the pilot so far forward of the center-of-gravity it probably won't be
> seeing anything like 6g's. Maybe, if you gave the nose more glass and set
> the pilot on his belly, you could get 4-6g's, but somehow I doubt it. :)
> This appears to be a nice sport design. :)
> Grim
Don't worry, son ! ;-)
My calculations show it works.
Maybe it looks a little bit nose-heavy
due to the view angle...
Greetings ! - Jens
ryan constantine wrote:
> where do the landing gear go? doesn't look like there is room. and how
> about engine exhaust? is that under the wings? which direction does
> the canopy open? does the pilot lay down? why are the wing tips
> 'cut'? i only recall seeing rounded wing tips. does the pilot get to
> sit on something and use controls or just flop around inside the
> cockpit? just kidding with that last one. considering the wingspan is 6
> meters, it looks like the fuselage is about a meter wide and the canopy
> would be 2 meters long. and the engine compartment seems a bit small
> maybe. a friend of mine had a push plane called a cozy. it had canards
> in the front, wings that swept back and had the tails at the wingtips.
> it was a three seater and very aerobatic although i'm not sure of how
> many g's it could handle. they sold it to get a 5-seater twin engine
> boring plane and shortly after that, the new owner crashed on landing.
> it was deemed unrepairable. i must say, your design is visually
> appealling. i like it.
> Jens Strohmeyer wrote:
> > This is a general aviation sports aircraft I designed in my spare time.
> > It is a single-seater, has limited aerobatic capabilites (-/+ 6 g)
> > and uses a pusher engine and rectractable main landing gear.
> > MTOW is about 500 kg, top speed is 450 km per hour. Wing span is 6 m.
> > (You must know that I am a post-graduate aerospace engineering student.)
> > "Designed" does not mean "paint" with POVRAY in this case.
> > What you see is the result of months of hard work and lots
> > of calculations and sketches and "what-if's", so there is a reason why
> > the
> > plane looks like this and not any other way.
> > I used POVRAY for design visualization because I had
> > no other CAD-Tool at hand.
> > I send you this not to judge the image, but the plane !
> > Any comments on the aircraft would be nice.
> > Thanks !
> > Jens
> > [Image]
The nose gear rectracts rearward into the nose
(who would have expected that ? *grin*)
while the main gear rectracts partly forward into
the tailbooms (similar to the A-10 Thunderbolt).
This is to keep a rather long wheelbase and track
and to protect the propeller.
Engine exhaust is not shown in the picture, it will be
to the rear (two pipes on each side of the fuselage
little below wing level).
Engine compartment is not too small as i use a
"Wankel" rotary-piston engine. It has little weight
and small dimensions related to high power output.
Canopy opens forward and upward, like in some
modern sailplanes. The pilot sits in it much the same way.
Anything forgotten ? Oh, yes, the wingtips.
Right, they should be aerodynamically improved.
Rounded wingtips make sense and I already thought
about it, but if you take a closer look at some
aerobatic competition planes (e.g. Extra 300),
you dont see rounded tips.
However, I was too busy with other aspects but too
include it into the image.
Thanks for questions and comments !
Greetings ! - Jens
Oh, I know it'll fly! :) I wouldn't hesitate to fly such a plane.
My comment was directed mostly to its similarity to early P-38 mockups. The
38 was a much heavier plane, of course (and flew at greater speeds then you
probably had in mind), so Kelly wisely choose to put the pilot near the CG.
I don't see anything in your design that would indicate problems.
Grim
> Grim
So do I ! :))
Thx for your comments.
Of course I know about the P-38,
and my own design has been influenced by it a little bit
because I do like it very much.
Nevertheless, the design concept is straight technical.
Jens
Jens Strohmeyer <j.s### [at] tu-bsde> wrote in message
news:3997DD26.6A2CDC13@tu-bs.de...
I like it. Sort of P-38-ish. Looks like it would fly just fine. Have you
calculated any theoretical moments of inertia or stability derivatives? It
might be interesting to try it out in a flight simulator.
Jon (Aero Engr, too)
Jon S. Berndt
JSBSim Project
www.hal-pc.org/~jsb/flightsim.html
> Jon S. Berndt
> JSBSim Project
Hello Jon !
Of course I have.
But so far, I havent had the possibility of testing it in a simulator
because I dont have a flight simulator aircraft construction tool. :(
It would be great to test it that way, I already thought about it.
I have read some info about FLIGHT GEAR quite a while ago.
Do you think it will be sufficient for that task ?
I don't know about the current development stage though.
Thx for your comments/ideas !
Jens
It
> Hello Jon !
> Of course I have.
I am biased. ;-) I am the coordinator for JSBSim, an open source flight
dynamics model (FDM) that is used for FlightGear, along with the NASA
Langley LaRCsim FDM. For the past two years I have been writing a C++ FDM,
with the cooperation of a couple other guys. If you can give me the mass
properties and stability derivatives I can model it. See the link below in
my signature. FlightGear/JSBSim currently models the C-172 and the X-15. I'd
like to create a movie using the data output from FlightGear/JSBSim and use
POV-Ray to render the approach and landing.
(see www.flightgear.org) We are at version 0.7.4 and just finished showing
at the San Jose Linux World show. There is one Linux distribution that is
now including FlightGear (Debian? Mandrake? SUSE? - it's not RedHat).
Jon
Jon S. Berndt
JSBSim Project
> It
> > Hello Jon !
> > Of course I have.
> Jon
> Jon S. Berndt
> JSBSim Project
Well, I thank you very much for the offer ! :-)
But to my regrets I am not allowed to send
you any detailed data of the aircraft because
I have signed a contract with an aircraft
production company.
The aircraft design is part of the contract
and also contents of my thesis (diploma).
I hope you understand my situation.... sorry !
I have downloaded FlightGear to my Win98 system
and tested it, but it seems still to have some stability problems.
Sometimes it runs without any problems, sometimes not.
If you show me how to integrate a new aircraft
into FlightGear, I could model it by myself, I think.
It would be nice to stay in contact !
Best regards,
Jens
"Jens Strohmeyer" <j.s### [at] tu-bsde> wrote in message
news:399### [at] tu-bsde...
> production company.
Do you plan on selling this plane pre-built or in kit form? Years ago I
built a Falcon XP (2 seat pusher canard, for those who've never heard of it
http://www.datasync.com/~ericfree/falcon_xp_1.jpg ). Had to sell it because
the wife hated it. The wife is gone and now I'm looking for another plane
to build.
Eric
> > production company.
> to build.
> Eric
> "I don't like it, and I'm sorry I ever had anything to do with it."
> - Erwin Schrodinger talking about Quantum Mechanics.
Well, please remind the fact that even a prototype has not yet flown.
It will take quite a long time until production starts (if at all !).
Thank you for your interest !
Best regards,
Jens
