Yep, I didn't manage (nor tried) to put bubbles in the levels...yet
The title is in fact :'Invasion'. The idea behind it is that bubble levels
are used to make thinks levelled, perfectly horzontal or vertical. In this
little world, the aliens are bubble levels and their job is to lower
everything at sea level... . Er, ok, i'll follow the white guys with the red
cross...
Sax
Harold Baize wrote:
> I love it, and the title of course is "Water level", right?.
> The next step would be putting the little bubbles
> in the tubes :-)
> Harold
> "Sax" <qua### [at] freegatesbe> wrote in message
> news:3965C6CE.55765523@freegates.be...
> > Hi all,
> > Here is my first real scene i worked on...
> > Is there a way in povray to make real waves, I mean not a texture but a
> > "surface" with wave you could surf on ?
Please post the function.
I get paid to do -anything- while connected to the internet.
Please use my referral id to find out more
http://www.getpaid4.com/?billdewitt
>in the tubes :-)
From what I know a spirit level is what you're all talking about
(the one with the little bubble in), a water level is quite
different and consists of two small transparent tubes with a mark
at the middle of each, each transparent tube/cylinder is then
connected to a very long flexible but crumple proof tube a bit like
a hose pipe, you fill the pipe up untill the water reaches the mark
in each transparent cylinder. You put the lids on the transparent
cylinders, and you can check items at long distances to see if they're
level or not, one person holds one transparent tube up to the wall
or roof at his end and a second person takes the other transparent tube
(on the other end of the pipe), to the second location and holds the
tube up to the appropriate place, if the water in each transparent tube
is touching the line, then the two locations are leve. And that is a
water level.
Steve email mailto:ste### [at] zeroppsuklinuxnet
%HAV-A-NICEDAY Error not enough coffee 0 pps.
or http://start.at/zero-pps
12:49am up 23:15, 2 users, load average: 1.08, 1.02, 1.01
"Steve" <ste### [at] zeroppsuklinuxnet> wrote in message
news:slr### [at] zero-ppslocaldomain...
| is touching the line, then the two locations are level. And that is a
| water level.
And that was also interesting to learn.
