My empirical studies with MegaPOV radiosity have shown that it
works as advertised. There are some other factors that are more
important for realism than the radiosity settings.
1. assumed_gamma & Display_Gamma
These parametrs relate only to the CRT and have nothing to do
with simulating light transport and should be taken out of
the simulation by using assumed_gamma 1.0. Display_Gamma should
be set to a value correct for the particular monitor.
2. Light source intensity distribution
In real life there are no omnidirectional light sources. By this I mean
that all ligh sources have some charachteristic intensity distribution.
In this scene the light source is a flat square panel. It's projected
area decreases by cos(angle) and so does it's brightness. For this reason
just using area_light isn't enough because it still radiates in all
directions with equal intensity (see fig.3). I used spotlight to simulate
this cosine falloff. (tightness 0 produces cos(angle*2)/2+0.5 intensity)
3. fade_power
In real life light source's apparent brightness follows 1/r^2 equation.
The correct value for fade_distance seems to be 1.4*light_source_diameter.
All three factors must be taken into account if relism is the goal.
As proof I present 3 images (gamma 2.2):
1) The Cornell reference image.
2) MegaPOV 0.5 image rendered with with:
assumed_gamma 1.0, Display_Gamma=2.2
spotlight modifier
fade_power 2
This is a nice match with basically the default MegaPOV radiosity settings.
All texture and radiosity parameters within nominal range.
3) The same scene with same settings without:
assumed_gamma
spotlight modifier
fade_power
(Texture and light colors gamma corrected)
This is a typical 1st attempt at radiosity. Too much color bleed,
not enough diffuse light, flat shading.
Once again, the difference between images 2 and 3 is caused by
assumed_gamma, spotlight and fade_power. Source to binaries.scene-files
by Monday.
_______________________________________________________________________
Kari Kivisalo www.kivisalo.net
Download 'realistic.jpg' (26 KB)
Preview of image 'realistic.jpg'
I commend you for your work. Very well done. You should make a tutorial, I
think.
Good job of looking into other factors for squeezing more realism out of radiosity.
> 3. fade_power
> spotlight modifier
> fade_power 2
> assumed_gamma
> spotlight modifier
> fade_power
> by Monday.
> [Image]
Samuel Benge
E-Mail: STB### [at] aol com
Visit my isosurface tutorial at http://members.aol.com/stbenge
On Sat, 10 Jun 2000 16:05:02 +0300, Kari Kivisalo <kar### [at] kivisalo net>
>3. fade_power
And your images prove your words. Impressive work!
My only concern is fade_power, shouldn't you use 1000?
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] usa net
TAG e-mail : pet### [at] tag povray org
I'm pretty sure that every physics book I have red says 1/r^2.
You must be thinking about interior fade_power :)
On Sat, 10 Jun 2000 23:47:06 +0300, Kari Kivisalo <kar### [at] kivisalo net>
I wouldn't question your physics books because mine read the same
<grin>. It escaped me that realistic attenuation is only suppoted for
object interior. But then, isn't light fading unrealistic in this
case? Can you try placing the whole scene in a transparent object and
using realistic attenuation?
good work - its noce to see the megapov defaults with minpr tweaking are
right on the nail for my money - maybe you should make a tutorial on how to
do the req'd tweaks!
I posted realistic.pov with some comments to binaries.scene-files.
Tweaking the radiosity block has only minor effect to the overall scene.
To Popov:
This 1/r^2 attenuation is purely geometric and has nothing to do
with media interaction.
Peter Popov <pet### [at] usa net> wrote...
Actually, the equation that POV uses for light attenuation is a good
approximation. Interior attenuation, however, is simulating a totally
different phenomenon, and therefore _should_ be using a totally different
equation. However, in the official POV-Ray, it uses the same equation. The
fade_power 1000 "hack" just tells POV to use a different equation to produce
more realistic results. That equation, though, would not work for simulating
light attenuation caused by the energy spreading out over a larger area as
distance increases.
-Nathan
Kari Kivisalo <kar### [at] kivisalo net> wrote...
> 3. fade_power
Great detective work! I'm glad to hear that things are working correctly.
-Nathan
