POV-Ray : Newsgroups : povray.binaries.images : Randomly packed cubes (40k) Server Time
2 Oct 2024 08:18:42 EDT (-0400)
  Randomly packed cubes (40k) (Message 1 to 10 of 14)
Subject: Randomly packed cubes (40k)
Date: 25 May 2000 00:23:42
Message: <392CA9D8.83F222F0@faricy.net>
Okay, here's 450 cubes packed into a cubical area. Each time a cube is
generated it is checked for intersection with other cubes. Every
consecutive time a cube is found to intersect the failure rate is
incremented, if it reaches a threshold the algorithm assumes the space
is full (in this case 30).
Each cube has a random:
size (0.2-1, evenly distributed),
rotation (evenly distributed),
HLS color (hue 120-270, evenly distributed,
   lightness .25-.75, sinusoidal distribution favoring middle values,
   saturation .5-1, quadratic distribution favoring higher values),
surface normal (part crackle, bumps, wrinkles, even distribution)
parse 6m34s render 1m12s total 7m46s
total mem 3,307,666 bytes
Download 'kubes.jpg' (41 KB)
Preview of image 'kubes.jpg'
Subject: Re: Randomly packed cubes (40k)
Date: 25 May 2000 08:21:59
Message: <392d1ae7@news.povray.org>
Looks good...
but whats the volume of the outer cube and the volume of all the stacked
cubes?
(not that i dont believe none intersect!!!)
Date: 25 May 2000 08:23:47
Message: <392D1C17.20126E28@psu.edu>
How do you do the intersection test??
-paul
> David Fontaine     <dav### [at] faricynet>     ICQ 55354965
> Please visit my website: http://www.faricy.net/~davidf/
Date: 25 May 2000 14:03:39
Message: <392d6afb@news.povray.org>
Yeah could you possibly explain how this was done, I wouldn't mind working
on this style, as I'm a fan of the while style macros, is it realted to
trace (I've never used it though)?  Thanks
Pete
Paul <pdj### [at] psuedu> wrote in message news:392D1C17.20126E28@psu.edu...
> -paul
> >  [Image]
Date: 25 May 2000 16:55:59
Message: <392d935f@news.povray.org>
Yeah, I'd like to know this as well...it looks pretty amazing.  Good job.
Source?
-Chris-
> -paul
Date: 25 May 2000 18:12:42
Message: <392DA473.C442E6A9@faricy.net>
Source will be in p.b.s-f as soon as I clean it up a little. I know it looks
like some intersect, but I am positive it's just an illusion. (I ran a (really
slow *cough cough*) render with every cube intersected once with every other
cube (for a total of n(n-1) intersections, so within a smaller bounding cube)
and nothing showed up.)
Date: 25 May 2000 18:13:42
Message: <392DA4AF.DFF4C9C1@faricy.net>
"Rick [Kitty5]" wrote:
> Looks good...
> cubes?
mumble mumble, I'd have to add some code and wait for it to reparse...
mumble grumble
Subject: No! Bug!
Date: 25 May 2000 18:35:28
Message: <392DA9C9.7D0692AF@faricy.net>
Radians vs. Degrees. Agh! So maybe some of them do intersect. Fixed it now.
Date: 25 May 2000 18:49:57
Message: <392DAD2F.5522973E@faricy.net>
Serge LAROCQUE wrote:
> Are you absolutely sure that none of the cubes intersects with another? :-))
No :-(
Date: 26 May 2000 00:24:22
Message: <392DF3DF.7D06@pacbell.net>
This would be a good way to create an astroide feild for a space scene.
Ken Matassa
