POV-Ray : Newsgroups : povray.binaries.images : stereogram anyone? 51kbu Server Time
3 Oct 2024 19:15:46 EDT (-0400)
  stereogram anyone? 51kbu (Message 9 to 18 of 28)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: stereogram anyone? 51kbu
Date: 13 Jan 2000 18:16:03
Message: <387e5cb3@news.povray.org>
Yes, I thought it was he, but he is so young there.
TonyB <ben### [at] panamaphoenixnet> wrote in message
news:387e5611@news.povray.org...
> >ps. Is the target person anyone we know?
> William Henry Gates III, New Mexico, 1977... busted! (If I'm not
mistaken.)
Date: 13 Jan 2000 18:27:43
Message: <387E5F6F.350AD066@stud.ntnu.no>
Harold Baize wrote:
> Sigmund,
> Alright, I realize my last message didn't really answer the question- why.
> Well, when we look at things in the distance (infinity) the line of
> sight of each eye is parallel. It is still pretty much parallel at
> 195cm. Given an average human eye separation of 6.5cm that works out
> to be 1:30. When we look at things closer than this our eyes converge
ahhh ooohh It's coming to me .. gotta.. _think_... Nah. G'night everone!
sig., still cuious about that ratio..
Date: 13 Jan 2000 18:35:27
Message: <387e613f@news.povray.org>
Sigmund Kyrre Aas <as### [at] studntnuno> wrote in message
news:387E5AB6.1772ADD6@stud.ntnu.no...
> Harold Baize wrote:
> Don't be. The camera separation would be the same :) Here's my cam:
> camera {
>    #local L=28;
>    #local Pos=<-45 , 12 ,-30>*.7;
>    location  Pos + vnormalize(vcross(Pos,y))*clock
>    look_at   <0, 0 , -2>
>    angle degrees(atan2(35,L))
Whoa, hecka complex camera statement. Guess I'm still thinking with a
POV 1.0 camera syntax.
> The target is at <0,0,0> and it's normal is -x. On closer inspection,
> the camera distance is 39 units and the target radius is 15, so the "one
> unit for every 30 units" rule is actually fulfilled.
Which is why it produces a strong stereo effect without eye strain :-).
To look at an object 39cm from your eyes you would definitely need to
converge the eyes.  Instead you bring the cameras together. The
result is a dart board that appears to be more than a meter in diameter.
> Can this rule be derived from the focal length of the human eye or
> something?
Yes, but I'll have to look up the specifics if you want them. Ultimately
though, the rule is species specific, a dog would use a smaller separation,
say 1:20.
Harolddd
Date: 13 Jan 2000 21:57:26
Message: <387E90DF.41245BFE@mailbag.com>
Sigmund Kyrre Aas wrote:
> Correct! Now can you do the tail people as well?
> sig.
The Simpsons.
I recognized the grinning mug shot the moment I saw it; I'm surprised
the neighbors didn't complain about how loudly I was laughing.
-Mark Gordon
Date: 14 Jan 2000 03:05:00
Message: <387ed8ac@news.povray.org>
Harold Baize wrote in message <387e613f@news.povray.org>...
>> camera {
>>    #local L=28;
>>    look_at   <0, 0 , -2>
How's this?  This is one of the cameras from a fly-through of the Grand
Canyon that I'm working on.
camera{
 #declare Clock = clock;
 // Some basic vector calculus, plus a fudge factor
 #declare UnitTangent = vnormalize(path(Clock+dclock)-path(Clock));
 #declare PlusdClock =
vnormalize(path(Clock+dclock+dclock)-path(Clock+dclock));
 #declare UnitNormal = vnormalize(PlusdClock - UnitTangent);
 #if(vlength(UnitNormal)=0)#declare UnitNormal =
vaxis_rotate(y,vcross(UnitTangent, y),
90-degrees(acos(vdot(UnitTangent,y))));#end
 #declare Curvature = vlength((PlusdClock -
UnitTangent)/dclock)/vlength((path(Clock+dclock)-path(Clock))/dclock);
 #declare UpVect1 = vaxis_rotate(y,vcross(UnitTangent, y),
 #declare AngleFract = atan2(Curvature,1)/(pi/2);
 #declare Angle = degrees(acos(vdot(UnitNormal, UpVect1)));
 #if(vdot(UnitNormal,UpVect1)<0)#declare Angle=(-360)+Angle;#end
 #declare Angle = (Angle/2)*AngleFract;
 #fopen FileID "GCanyon.dat" read
 #read(FileID, OldAngle)
 #fclose FileID
 #if(abs(Angle-OldAngle)>dAngle)
  #declare Angle=OldAngle+(abs(dAngle)*Sign(Angle));
 #fopen FileID "GCanyon.dat" write
 #write(FileID, Angle)
 #fclose FileID
 #declare UpVect = vaxis_rotate(UpVect1,UnitTangent,Angle);
 #declare UnitBinormal = vnormalize(vcross(UnitTangent, UpVect));
  #warning concat("Tangent:  ", str(UnitTangent.x,6,6),",",
str(UnitTangent.y,6,6), ",",str(UnitTangent.z,6,6), "\n")
  #warning concat("Normal:   ", str(UnitNormal.x,6,6),",",
str(UnitNormal.y,6,6), ",",str(UnitNormal.z,6,6), "\n")
  #warning concat("UpVect:   ", str(UpVect.x,6,6),",", str(UpVect.y,6,6),
",",str(UpVect.z,6,6), "\n")
  #warning concat("Binormal: ", str(UnitBinormal.x,6,6),",",
str(UnitBinormal.y,6,6), ",",str(UnitBinormal.z,6,6), "\n")
 location path(Clock)
 direction UnitTangent
 up UpVect
 right UnitBinormal*1.33
 angle 60
Mark
Date: 14 Jan 2000 04:00:58
Message: <387EE5E5.FB9ED07B@student.uni-siegen.de>
> I just crammed a stereogram out of an unfinished scene of mine.
How do you view that? Some setup with a mirror or two?
I definitely can't misadjust my eyes in such a way that
I see something (apart from too slightly different images)...
> Just wondering; shy can't I use 'actual' eye distance? I tried 7 cm
> between the cameras, but that produced far too different images. This
> one uses 1 cm and the camera is ca. 50 cm away from.
I guess you have never really viewed a scene just from 50cm away
in real live. And it has to do with the viewing angle of the camera.
The larger this is, the closer together the cameras have to be.
Markus
Date: 14 Jan 2000 07:09:50
Message: <387f120e@news.povray.org>
Just imagine how far apart in your scene the human eyes would be, and for the second
picture translate the camera that much.  make
each image look in a parallel direction - when people are looking at the stereo image,
the eye-crossing differences will be done by
their own eyes; it shouldn't be done by the camera.  That's how I did my image
earlier, and it looks fine.
- Slime
news:387E5F6F.350AD066@stud.ntnu.no...
> Harold Baize wrote:
> > Sigmund,
Date: 14 Jan 2000 07:28:23
Message: <387f1667@news.povray.org>
Curious that this doesn't look exactly right, the left/right shift seems
enough based on the apparent displacements of the dart fins against the board.
When I see it in stereo it's flat, which kind of goes with what you say about
using 1cm instead of a wider 7cm, so maybe 3cm would have been better.
  The way I use to see these is just hold my hand flatout and aligned with my
nose between my eyes and angle my hand enough to only be able to see each
picture with the corresponding eye, closing each one at a time to be sure I have
only the full left or right image in view.  Sometimes I don't need to do this at
all for the small pictures or just a quick hand divider for my eyes for others.
I think another thing to keep in mind about it is these can be fairly deep 3D
and require some focusing.  By that I mean there can be near and far parts which
have to be looked upon as separate parts, otherwise you don't ever see the whole
picture forward to back "in focus" without actually looking at those parts
alone.  This can make for a seemingly distorted and nonmergeable stereopair.
Probably the predominate factor with this particular rendering.  That in mind I
believe it needs the wider camera separation.
Date: 14 Jan 2000 10:34:05
Message: <387F41EF.9555B41A@stud.ntnu.no>
39 cm from the center, yes. With 15 cm target radius it's 33 cm away
from the closest rim of the target. Perhaps this 1:30 should be adjusted
when I've got a 28 mm lens? Maybe that's why it looks big. Oh, wait. I
didn't have a 28 attached. I copied from another scene file. It was
really 35mm.
sig.
Date: 14 Jan 2000 10:34:54
Message: <387F4220.B668FABC@stud.ntnu.no>
I forgot to ask you yesterday: Do you know why he was arrested?
sig.
> William Henry Gates III, New Mexico, 1977... busted! (If I'm not mistaken.)
