POV-Ray : Newsgroups : povray.binaries.images : sor bug Server Time
24 Jan 2026 14:57:15 EST (-0500)
  sor bug (Message 1 to 9 of 9)
Subject: sor bug
Date: 7 Apr 1999 18:32:10
Message: <370bceda.0@news.povray.org>
Hi!
I think I've found a bug in sor :-(
I use Linux (Kernel 2.2.5-ac1), AMD K6-2-350
self compiled Povray version 3.1e (tried with and without uvpatch)
I've also tried an inofficial version of I've compiled 3.1 and the bug
didn't seem to be present...
In povray 3.0 there seemed to be a bug, two... but it looked different.
I'll attach the images of the bug.
1. Povray 3.1e
2. Povray 3.1
3. Povray 3.0
I'll send a similar bug report to povray.bugreports
(but without the images, and a pointer to this mail)
Below is the sourcecode of the scene:
	location <10,20,-30>
	look_at <0.01,0.01,0.01>
light_source {
	<5,100,-20>
	color rgb <1,1,1>
light_source {
	<50,-100,-20>
	color rgb <1,1,1>
sor {
	19
	<10,0>
	<11,1>
	<13,2>
	<14,3>
	<15,4>
	<16,5>
	<17,6>
	<18,7>
	<19,8>
	<20,9>
	<21,10>
	<22,16>
	<23,17>
	<24,18>
	<25,19>
	<26,20>
	<27,21>
	<28,22>
	<30,23>
	finish {ambient 0.4}
			checker
			color rgb <1.4,1,0.6>
			color rgb <0,1,0>
	sturm
	scale -y
Ronald Lembcke (aka _crash)
es1### [at] fenbaynetde
Download 'sortest31e.gif' (14 KB)
Preview of image 'sortest31e.gif'
Subject: Re: sor bug
Date: 7 Apr 1999 18:52:39
Message: <370BD276.67BBAF15@pacbell.net>
Ronald Lembcke wrote:
> Hi!
Can you be a little more specific about what you feel is wrong with
the object. I can't really tell from the image what problem you see
in it and if I knew what to look for might be able to offer a more
informed opinion on the subject.
Ken Tyler
mailto://tylereng@pacbell.net
Date: 7 Apr 1999 19:26:13
Message: <370bdb85.0@news.povray.org>
I'll try to...
I think the object should be closed as there is
no open statement in the defininition.
When I remove "open" from the sor1.pov example
all the objects get closed.
and the 3 images I've posted (2 of them were in a second mail as
I forgot to attach them) look completely diferent....
same scene-file only different povray version.
Another (slightly modified) example:
This time the only difference between the images is:
1. is open
2. is closed
light_source {
	<5,100,-20>
	color rgb <1,1,1>
sor {
	19
	<4,0>
	<7,1>
	<13,2>
	<14,3>
	<15,4>
	<16,5>
	<17,6>
	<18,7>
	<19,8>
	<20,9>
	<21,10>
	<22,16>
	<23,17>
	<24,18>
	<25,19>
	<26,20>
	<27,21>
	<28,22>
	<30,23>
//	open
	sturm
			checker
			color rgb <0,1,0>
	scale -y
Und weg...
           Roni
Download 'sor2_open.gif' (16 KB) Download 'sor2_closed.gif' (16 KB)
Preview of image 'sor2_open.gif'
Preview of image 'sor2_closed.gif'
Date: 8 Apr 1999 03:29:08
Message: <370C4C8E.2D745DE5@aol.com>
Looks to me like you have double-illumination in that second image, the
hole is still there same as the first I think, just seeing the inside
fully lit and giving the illusion of a semi-circle hole. Have you tried
another camera location or rotate the sor some?
The first and last points are not actual surface points either, they are
"pointers" to what the beginning and ending shape will be like.
Check the Scene help file in POV Win 3.1 or DOC in earlier versions for
a diagram of 'sor'.
You use 'open' to prevent closure but not using 'open' doesn't mean
"close".
To close one you need doubling up on the start and/or end point(s).
> 1. is open
> 2. is closed
> camera {
> light_source {
>         <5,100,-20>
>         color rgb <1,1,1>
> sor {
>         19
>         <4,0>
>         <7,1>
>         <13,2>
>         <14,3>
>         <15,4>
>         <16,5>
>         <17,6>
>         <18,7>
>         <19,8>
>         <20,9>
>         <21,10>
>         <22,16>
>         <23,17>
>         <24,18>
>         <25,19>
>         <26,20>
>         <27,21>
>         <28,22>
>         <30,23>
> //      open
>         sturm
>         texture {
>                 pigment {
>                         checker
>                         color rgb <0,1,0>
>         scale -y
> Und weg...
>            Roni
>    sor2_open.gif    Type: GIF Image (image/gif)
>                 Encoding: base64
>    sor2_closed.gif    Type: GIF Image (image/gif)
>                   Encoding: base64
Date: 8 Apr 1999 05:51:32
Message: <370c6e14.0@news.povray.org>
Yes and no....
The hole you see has to do with the inside... it's shape is the same....
but you don't see the inside... look at the checker pattern.
I've attached the open image again, because I missplaced the ambient
statement ( the finish must be in the texture... when it's before the
texture it gets ignored)
You'll see that when it is open, there's a completelly different
pattern.
Yes... I read that
> a diagram of 'sor'.
I looked at the html version...
I've rendered the sordemo.pov from docdemos
and it's closed and doesn't look like the image in the doc.
I'll attach it, too.
I have to specify open to look like it should.
> "close".
The povuser.txt says:
 The optional keyword open allows you to remove the caps on the
 SOR object. If you do this you shouldn't use it with CSG anymore
 because the results may be wrong.
so: when I don't use "open" there _are_ caps.
Maybe that might be a solution...
but there's still something wrong with it.
Ronald Lembcke
Download 'sor2_open.gif' (15 KB) Download 'sordemo_c.gif' (6 KB)
Preview of image 'sordemo_c.gif'
Date: 8 Apr 1999 15:07:40
Message: <370CF04B.CB50CDAC@aol.com>
What version/platform do you have there?
I just rendered my sordemo.pov file using POV-Ray for Windows 3.02 (I
also have 3.1e though no sordemo.pov with that one) and it rendered it
open without the 'open' keyword. Then using 3.1e it renders the same sor
as closed, so you are correct sir!
> Yes and no....
> pattern.
> Yes... I read that
> > a diagram of 'sor'.
> > "close".
> Ronald Lembcke
>                 Encoding: base64
>    sordemo_c.gif    Type: GIF Image (image/gif)
>                 Encoding: base64
Date: 8 Apr 1999 17:45:40
Message: <370d1574.0@news.povray.org>
Hasn't changed since my first mail ;-)
Yes... but there's still something strange going on in 3.1e
A mail from Alan Kong in  povray.announce.frequently-asked-questions
(Subject: Here are the changes between public POV-Ray 3.1 and 3.1e)
says
| 3.1a               9/29/98 Chris Young
| Fixed problem with sor and lathe affecting unix and amiga
Maybe this fix introduced another problem (I don't know the original one)
I've modified the sordemo scene a little bit... (camera and sor)
I'll attach images rendered with 3.02 (the version from the Debian Linux
package) an inofficial version of 3.1 and the version of 3.1e I've compiled.
The wierd thing is the shadow of the image rendered with 3.1e
The shadows of 3.02 and 3.1 are correct... well... one sor is open
the other one is closed... but the shadows are ok in respect to this.
But in 3.1e there's a half-shadow... similar to the half existing cap
in my previous posts.
modified version of sordemo.pov:
#include "golds.inc"
global_settings { assumed_gamma 2.2 }
  location <5, 9, -10>
  look_at <0, 5, 0>
  angle 45
background { color rgb<0.2, 0.4, 0.8>  }
light_source { <100, 100, -100> color rgb 1 }
plane { y, 0
  pigment { checker color Red, color Green scale 10 }
sor {
  4,
  <0.5,   4.0>,
  <1.0,   5.0>,
  <3.0,  6.0>,
  <4.0,  7.0>
  texture { T_Gold_1B }
Ronald Lembcke
Download 'sor_302pvm_deb.gif' (6 KB) Download 'sor_31.gif' (4 KB) Download 'sor_31e.gif' (4 KB)
Preview of image 'sor_302pvm_deb.gif'
Preview of image 'sor_31.gif'
Preview of image 'sor_31e.gif'
Date: 8 Apr 1999 18:55:39
Message: <370D2487.52D5E2BE@pacbell.net>
 There is one easy solution to this seeming dilemma. Drop the sor
and us a lathe. The are much more predictable, are considerably
more versatile, and the rendering time comparison is minor as long
as you don't use the advanced spline types. They also seem to work
better in csg operations plus add the ability to add real thickness
to the created object if you double back on your path. It is my
revolution object of choice in all but a few rare cases.
Ken Tyler
Date: 9 Apr 1999 01:04:28
Message: <370D7C1F.2D3D99A4@aol.com>
Rotating and translating your example sor into another camera view you
will see a round hole and the sor is open. So I'm just getting more
confused. The correct behaviour should be closed ended until 'open' is
specified, but at least it's not a incomplete hole there as you can see
if you re-render the following new viewpoint. Your sor isn't containing
closable points to begin with either, which apparently is just like
saying 'open'. Don't know what this means for the sor "correctness"
exactly.
//new view
   look_at <0, 5, 0>
   angle 45
 plane { y, 0
 sor {
   4,
   <0.5,   4.0>,
   <1.0,   5.0>,
   <3.0,  6.0>,
   <4.0,  7.0>
  rotate <-60,-30,0> translate <-5,0,5> //moved to see into sor
Sorry, I forgot about the other post. I have a very time-limited message
reading here.
> says
> camera {
>   look_at <0, 5, 0>
>   angle 45
> plane { y, 0
> sor {
>   4,
>   <0.5,   4.0>,
>   <1.0,   5.0>,
>   <3.0,  6.0>,
>   <4.0,  7.0>
> Ronald Lembcke
>    sor_302pvm_deb.gif    Type: GIF Image (image/gif)
>                      Encoding: base64
>    sor_31.gif    Type: GIF Image (image/gif)
>              Encoding: base64
>    sor_31e.gif    Type: GIF Image (image/gif)
>               Encoding: base64
