POV-Ray : Newsgroups : povray.binaries.images : How to mirror Server Time
20 Sep 2025 18:07:01 EDT (-0400)
  How to mirror (Message 1 to 3 of 3)
Subject: How to mirror
Date: 13 Feb 1999 13:47:09
Message: <36C5F3F2.68616FFA@mediaone.net>
Howdy. Here is an object that I want to appear in front of a mirror. In
the mirror, I will show the object from the back, bu offset both to the
right and left (trick mirror!)
Does anyone have an idea how to setup the mirror?
Thanks very much,
D.
Download 'mirrorlyre.jpg' (30 KB)
Preview of image 'mirrorlyre.jpg'
Subject: Re: How to mirror
Date: 13 Feb 1999 20:54:54
Message: <36C62CC2.BBEAF377@aol.com>
Sounds like you need something like 2 planes folded a little.
//BEGIN
intersection {
plane {z,0 rotate 15*y //vary the rotation as needed
 pigment {rgb .1}
  finish {reflection 1}
plane {z,0 rotate -15*y //vary the rotation as needed
 pigment {rgb .1}
 clipped_by {box {-6,6 scale <1,1,1>}} //overall mirror size
  translate 10*z //move backward or forward as needed
//white pointlight at camera position
#declare LCX = 0
#declare LCY = 10
#declare LCZ = -30
light_source { <LCX,LCY,LCZ> color rgb 1
light_source {<-1,3,5>, color rgb 1 //backlight
camera
  location  <LCX,LCY,LCZ>
  angle 22.5   // angle 67 = direction 1
  // direction 3.33*z
  look_at   <0, 2, 0>
box {-1,1 pigment {rgb 1}} //subject object
//END
> Thanks very much,
> D.
 mailto:inv### [at] aolcom?PoV
Date: 15 Feb 1999 02:15:41
Message: <36C7C9E5.D78E2B36@paradise.net.nz>
I'd go with a big cylinder myself - no messy folds ;)
cylinder {<0,1000,-100>,<0,-1000,-100>,100
	pigment {rgb 0.1}
Adjust the "100"s to change the curvature (it's translated back so it just
reaches z=0 on the y-axis)
> //BEGIN
> intersection {
>  pigment {rgb .1}
>  pigment {rgb .1}
> #declare LCX = 0
> #declare LCY = 10
> #declare LCZ = -30
> camera
>   // direction 3.33*z
>   look_at   <0, 2, 0>
> //END
> > Thanks very much,
> > D.
> >  [Image]
>   http://members.aol.com/inversez/POVring.htm
Sam
    mailto:smi### [at] paradisenetnz
    http://www.geocities.com/SiliconValley/Horizon/4152/
"Someday we'll look back on this moment and plow into a parked car."
  -- Evan Davis
