![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi folks.
I posted a still from this in povray.binaries.images yesterday... Well
anyway, I finally suceeded in finishing the actual animation. (Overnight
render, 6 hours 45 mins - 2 hours parsing + 4 3/4 hours rendering!)
When the first frame is rendered, POV-Ray sits there generating a 2MB
include file containing all the fractal data. (This is *not* included in the
time given above.) Once this file exists, it is reused for each frame (since
the fractal itself doesn't change during the animation).
I shrank the animation down to 320 x 240, but it's still a tad big -
2,335,026 bytes (ie, about 2MB). It can be found (hopefully!) at
http://www.btinternet.com/~Orphi/Video/Mandel-Flight-3-Small.m1v
(Assuming the people who host my website get their stuff right of course!!!)
I'm still not *quite* happy with the way it looks... the "particles" don't
look right at all, but the lighting is fairly good...
Comments?
Andrew.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Any chance of having the light sources fade out rather than cutting off
abruptly? Even if they only fade out over three or four frames, it
could make it quite a bit easier to watch.
Jamie.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, I've been thinking the same sort of thing myself... If I can figure the
math out, it might be worth doing. (It took me ages to get it like it is
now - and I still haven't managed to get the spread of particles right yet.
They are all "lined-up" too much. *sigh*)
Andrew.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>Andrew.
for fading a light_source #declare a spline containing the colors to be
stepped through, then in your light source reference the spline with "(how
long particle has existed)/(lifespan)", the spline does all the rest. Thus
if you do
#declare light = spline{
linear_spline
0.0, <1,1,1>
1.0, <0,0,0>
the light will be dimmer the longer the particle exists.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Aahhh... thanx for that... Will give it a go...
Andrew.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
