POV-Ray : Newsgroups : povray.binaries.animations : Blow yer mind, dude Server Time
19 Jul 2024 01:04:20 EDT (-0400)
  Blow yer mind, dude (Message 1 to 10 of 15)
Subject: Blow yer mind, dude
Date: 16 Mar 2004 08:46:22
Message: <4057052e@news.povray.org>
Compressing this small enough to post here didn't do it justice, so go to
the link below.
http://www.shelbyvision.com/Psychedellic.htm
I think it's worth the wait, but I can't guarantee you will. ;^}>
Steve Shelby
Subject: Re: Blow yer mind, dude
Date: 16 Mar 2004 14:18:33
Message: <40575309$1@news.povray.org>
This is grooovy baby!
A. Powers.
news:4057052e@news.povray.org...
> the link below.
> Steve Shelby
Date: 16 Mar 2004 19:09:50
Message: <4057974e$1@news.povray.org>
"Fernando G. del Cueto" <fcu### [at] yahoocom> wrote in message
news:40575309$1@news.povray.org...
> A. Powers.
to
> > the link below.
> > Steve Shelby
I think you've just come up with a new official slogan for the POV-Ray site
- Respectfully,
Dan
http://<broken link>
Date: 17 Mar 2004 01:55:57
Message: <4057f67d$1@news.povray.org>
That's cool!
Could you post the source? I want to render a super-smooth hi-res version to run
full screen :)
Tek
www.evilsuperbrain.com
"Steve Shelby" <ssh### [at] rexnetnet> wrote in message
> the link below.
> Steve Shelby
Date: 17 Mar 2004 06:59:23
Message: <40583d9b$1@news.povray.org>
Thanks. Did you try the 9.36 mb version? It's 800x600 and shows no loss from
the original uncompressed .avi. Or were you wanting to just render a still?
A little explanation is required here. This anim is one I made a couple
years ago, using Moray 3.3 and POVray 3.1. the animation is from Moray's
plugin, so if you run it from POVray, you'll have to set up the clock
yourself. The cone rotates on it's axis 360 degrees in 120 frames, with last
frame skipped for smooth looping. It has to be rendered with POVray 3.1. If
you use 3.5 you'll get something completely different. Also, if you use
Moray, it has to be version 3.3.
Let me know how it works out.
Steve Shelby
news:4057f67d$1@news.povray.org...
> That's cool!
to run
> full screen :)
> Tek
to
> > the link below.
> > Steve Shelby
Download 'cone2.zip' (4 KB)
Date: 17 Mar 2004 07:03:00
Message: <40583e74$1@news.povray.org>
Which words are you referring to?
Steve Shelby
"Dan P" <dan### [at] yahoocom> wrote in message
news:4057974e$1@news.povray.org...
> > A. Powers.
> to
> > > the link below.
> > > Steve Shelby
site
> - Respectfully,
> Dan
Date: 17 Mar 2004 20:49:23
Message: <40590023$1@news.povray.org>
news:40583e74$1@news.povray.org...
> Steve Shelby
Why, "Who needs drugs when we have POV-Ray," of course :-)
- Respectfully,
Dan
Date: 17 Mar 2004 23:55:32
Message: <40592bc4$1@news.povray.org>
Yeah I saw that version, the resolution's good but it's not very smooth, so I
intend to render it with more frames.
I'll let you know how it goes. :)
Tek
Date: 18 Mar 2004 00:59:30
Message: <40593ac2$1@news.povray.org>
I've not had any luck with it. I can't make it look quite like the animation
even using pov 3.1, there must be some settings moray does implicitly that I
don't have. Plus there's not actually any animation data in the file, nothing is
using the clock variable.
Tek
news:40592bc4$1@news.povray.org...
> Tek
Date: 18 Mar 2004 08:36:52
Message: <4059a5f4@news.povray.org>
I opened the same .pov file I sent you and rendered it in pov3.1, and the
the image looks like the attached file. I did not even have Moray open. Does
your render look different from that?
About the clock, Moray's animation plugin produces an .avi directly, without
any clock values being set in POVray. So if you want to animate the scene in
POVray without using Moray, you have to set it up there yourself. My
animation was 8 seconds long and 15 frames per second (119 frames after
skipping the last one for smooth looping). You simply have to make the cone
rotate (around the z axis) 360 degrees in the time specified.
Steve Shelby
news:40593ac2$1@news.povray.org...
animation
I
nothing is
> Tek
> "Tek" <tek### [at] evilsuperbraincom> wrote in message
loss from
still?
so I
> > Tek
Download 'Copy of cone2.jpg' (37 KB)
Preview of image 'Copy of cone2.jpg'
