POV-Ray : Newsgroups : povray.binaries.animations : Now the balls also slide! [MPG1, 786kB] Server Time
10 Apr 2026 02:00:56 EDT (-0400)
  Now the balls also slide! [MPG1, 786kB] (Message 1 to 5 of 5)
Subject: Now the balls also slide! [MPG1, 786kB]
Date: 9 Mar 2004 17:27:34
Message: <404e44d6@news.povray.org>
Now my particle system handles damping properly: the balls end up
sliding (looks like rolling...). I was afraid that I need some
conditionals to distinguish between slide/bounce state but "luckily" the
same piece of code handles both cases.
There is no friction at all. The speed along the surface normal is
dampened by 30% every time a ball bounces off the floor.
Severi S.
Download 'yaps3.m1v.mpg' (684 KB)
Subject: Re: Now the balls also slide! [MPG1, 786kB]
Date: 9 Mar 2004 17:45:52
Message: <404e4920$1@news.povray.org>
Nice one! How do you do it to keep particles out of the objects?
And what's your "lucky" code which keeps particles sliding nicely?
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 9 Mar 2004 19:11:04
Message: <404e5d18$1@news.povray.org>
I won't show the code (it is still very ugly) but here is what I'm
basically doing:
1. My approach is a "refined" Euler method -  I guess :) When the
position of a particle is updated the gravity is also taken directly
into account - not only speed. So gravity affects both the speed and the
position during every step. Without it I see my particles bounce for too
long with damping. This also gives 100% accuracy (when particles are not
colliding) no matter how big time steps between frames.
2. If the new position indicates a collision, the previous position is
restored (so basically particles _can't_ intersect with an object). The
next happens:
a) speed is directed away from the surface taking the damping into
account: this gives basic bounces.
b) particle is moved along the surface: this allows rolling and the
bounces are also more accurate, still not perfect though. If I want them
perfect I would have to find the _exact_ moment of collision.
c) gravity affects the speed along the surface: this allows the increase
in speed when rolling - also the accuracy of bounces increase.
I might have forgotten something but basically it works like that.
By "lucky" I mean that there seems to be no bugs and everything seems to
work as expected after I implemented 2.b and 2.c. BTW, have you tried
how Cristophs particle system/MegaPov handles rolling/sliding? Just
curious. At least it is a lot faster as it is hard coded.
Now I have only planes as environment and I check collisions by shooting
a ray towards every plane. This obviously is accurate but a bad thing to
do when there are many objects. Next I have to make the environment as a
one single union and shoot proper rays towards it. Accuracy decreases
but I can use as complex environment as I want.
Severi
Date: 9 Mar 2004 19:30:17
Message: <404e6199@news.povray.org>
> next happens:
But you surely have to calculate where the particle hits the object, don't
you? Either I'm missing something here, or you're missing some really big
issue. Just take the following:
A particle flying with 20mph. It'll hit a wall in 50 seconds, but you jump
and calculate 2 minutes. So, instead of rebouncing off the surface, you just
take the exisiting position and reverse the direction of velocity, so it'll
fly another direction. Maybe it'll hit another surface there to, so you
reverse the velocity once again... That it should have actually dropped a
few meters until it hit the first wall is left out?
Never looked at it, but just ask Christoph, he'll surely know. :-)
How does accuracy decreas when using a ray per object or one ray total per
union? Internally, I think POV-Ray just shoots the rays at the different
union-components, but returns only the closest hit. It's faster than doing
that yourself, and the comparison in SDL might be less accurate than what
POV-Ray is capable of internally, but surely not that much?
Since you're now shooting a ray at every plane individually, I expect you're
shooting them parallel to the plane's surface-normals, and thus maintain
that a particle won't intersect a plane because you know it's radius and can
then easily move it along the normal so that it won't intersect the plane.
This technique will run into problems with other objects, where the closest
point to the object isn't found with some arbitrary normal that easily.
"Tim Nikias v2.0"
Date: 9 Mar 2004 19:56:50
Message: <404e67d2$1@news.povray.org>
> you?
Yes, of course. I do the regular time stepping as everybody. First there
is the "main loop" for each particle that divides each frame according
to the speed and size of the particle. This loop moves the particles and
checks if there was a collision. If there was it moves to a "sub loop"
which has smaller time steps. So I do find the moment when the particle
collides, but it is not mathematically 100% accurate.
> issue. Just take the following: A particle flying with 20mph. It'll
> hit a wall in 50 seconds, but you jump and calculate 2 minutes. So,
> instead of rebouncing off the surface, you just take the exisiting
> position and reverse the direction of velocity, so it'll fly another
> direction. Maybe it'll hit another surface there to, so you reverse
Basically yes, but the timescale will be different because of adaptive
stepping. During a collision a particle is moved allways only a fraction
of its radius every step. So the accuracy should be adequate.
> That it should have actually dropped a few meters until it hit the
No, that is why there is the point 2.b (and 1.) which is done at every
collision.
Well, maybe I'll try it myself if Christoph doesn't show up automagically :)
I meant that the accuracy decreases as you can't shoot the ray allways
directly to the nearest point in the environment. You have to "guess".
If you knew the shape of each object it might be possible to shoot the
ray to the nearest point (as I was doing with the planes).
I will change to using a few well chosen ray directions (like speed and
gravity or something between them) and test the system with different
kinds of environment objects. So, more animations to follow!
Severi
