POV-Ray : Newsgroups : povray.binaries.animations : Cigarette Smoke Test 3 (472kbu) Server Time
27 Nov 2026 16:42:32 EST (-0500)
  Cigarette Smoke Test 3 (472kbu) (Message 1 to 23 of 23)
Subject: Cigarette Smoke Test 3 (472kbu)
Date: 15 May 2002 18:14:28
Message: <3ce2ddc4@news.povray.org>
I tried to change the smoke based on the feedback I've gotten and using
the images posted by TinCanMan as reference. I hope it's an improvement
over the last version.
This one also took quite a bit longer to render. On my Athlon 1700 it
took a little over 3 hours. But I still think it would have taken at
least five times as long to get a similar effect using media.
Comments much appreciated as always. :)
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Apr 14)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Download 'cigsmoke3.mpg' (473 KB)
Subject: Re: Cigarette Smoke Test 3 (472kbu)
Date: 15 May 2002 18:47:44
Message: <MPG.174d04156676e5e59896ff@news.povray.org>
In article <3ce2ddc4@news.povray.org>, run### [at] mobilixnetdk
says...
I think it is a vast improvement! Very nice.
Except the first second, there it looks like a transparent cone... maybe
fade it in slower?
Lutz-Peter
Date: 15 May 2002 19:14:53
Message: <3ce2ebed$1@news.povray.org>
Absolutely fantastic.  And since you never see smoke "just starting" in most
situations, you can easily avoid that first few frames being too uniform.  Just
have it "run ahead" a few frames in any animation you do.
Cheers!
Chip Shults
Date: 15 May 2002 19:24:26
Message: <3CE2EDD0.A2266A3D@onwijs.com>
> Rune
Well, I don't know about the first few frames but the rest looks
excellent.
If it isn't realistic it sure looks like it (you could at least
fool me).
I'm curious about what you0re going to use it for.
Remco
Date: 15 May 2002 19:38:00
Message: <3ce2f158@news.povray.org>
Something about that looks very realistic. I still think that the turbulence
should start a little earlier.
The most unrealistic thing is probably easy to change: in the beginning of
the animation, where the smoke is just starting to appear, the top of the
smoke has a defined horizontal line. You should try fading it in, so the
flat top of the smoke has full transparency, and we can't really tell where
it has started.
You might also try adding a cigarette, and maybe an ashtray =)
 - Slime
[ http://www.slimeland.com/ ]
Date: 15 May 2002 20:35:33
Message: <3ce2fed5@news.povray.org>
Hi Rune,
That looks great! Very realistic. It dissipates
nicely, but it seems to have an abrupt start. It
might seem a little thick for a cigarette, but
I'm sure you can adjust it to suit the needs. Maybe
the color could be a little more blue. Too bad about
the render time, but it's going to be worth it.
=Bob=
"Rune" <run### [at] mobilixnetdk> wrote in message news:3ce2ddc4@news.povray.org...
: I tried to change the smoke based on the feedback I've gotten and using
: the images posted by TinCanMan as reference. I hope it's an improvement
: over the last version.
: This one also took quite a bit longer to render. On my Athlon 1700 it
: took a little over 3 hours. But I still think it would have taken at
: least five times as long to get a similar effect using media.
: Comments much appreciated as always. :) -- Rune
Date: 15 May 2002 20:37:07
Message: <3CE2FF70.7E5C74AF@yahoo.com.au>
Yes definitely. I really like the way the smoke tendrils move toward the top.
They have that lazy drifting quality about them.
MJL
Date: 15 May 2002 21:11:36
Message: <3ce30748$1@news.povray.org>
oooh! I like.
looks tons better now.
there's still something that I can't pick out that makes it seem CG and not
RL, but isn't that the same with all CG.
Good work.  I'm glad I could help out.
-tgq
Date: 16 May 2002 04:53:30
Message: <3ce3738a@news.povray.org>
looks much better than the last, however i think you shoud make it thinner
at the base, and fatter at the top :)
PGP Public Key
Date: 16 May 2002 06:36:36
Message: <3ce38bb4$1@news.povray.org>
Everyone gives praise here, and it's well deserved for the technical effort,
but let me add a tiny bit of poison.. On my monitor, when I turn up the
brightness it's very visible that the bezier patches still curls in
sometimes fast, abrupt and unexpected ways.. This is more visible now than
test 1 & 2 and those turns doesn't look like smoke.. Apart from that, it's a
very good imitation of the pictures posted for reference.. Very good.
Hugo
Date: 16 May 2002 06:38:06
Message: <Xns92108106356ADseed7@povray.org>
Good!
Maybe a tad less granularity in the thick smoke, very visible in the
frames about 9 sec. into the animation.
Ingo
Date: 16 May 2002 08:25:49
Message: <3ce3a54d@news.povray.org>
Thanks! :)
> a transparent cone... maybe fade it in slower?
I'll try to do that.
Rune
Date: 16 May 2002 08:25:50
Message: <3ce3a54e@news.povray.org>
> that the turbulence should start a little earlier.
I don't know about that. Changing that part now could mess up
everything... ;)
> You should try fading it in, so the flat top of the
> where it has started.
The comment of the thread - yeah I'll fix that. :)
> an ashtray =)
Will do!
Rune
Date: 16 May 2002 08:25:51
Message: <3ce3a54f@news.povray.org>
Hehe, thanks! :)
> being too uniform.
I think I'd rather fade it in as others suggest.
Rune
Date: 16 May 2002 08:25:52
Message: <3ce3a550@news.povray.org>
> the rest looks excellent.
Thank you! :)
> (you could at least fool me).
My particle system is far too simple to realistically simulate smoke, so
my goal is to just make it look realistic...
> I'm curious about what you're going to use it for.
I have no plans to use it in a longer animation. If I can clean up the
code enough I'll include it as a demo scene for my particle system.
Maybe you meant what object to use it for - well, I think I'll add a
cigarette and an ashtray after all.
Rune
Date: 16 May 2002 08:25:53
Message: <3ce3a551@news.povray.org>
Thank you! :)
> It dissipates nicely, but it seems to have an
> abrupt start.
Yes, the abrupt start. I'll have to fix that.
> It might seem a little thick for a cigarette
Doesn't that depend on the size of the cigarette? ;)
> Maybe the color could be a little more blue.
Oh, I thought I had made it very blue. I think I like the color as it is
now.
> Too bad about the render time, but it's going to be worth it.
And if used in a larger scene, the smoke probably won't take up that
much of the screen space, so in real uses it might be faster.
Rune
Date: 16 May 2002 08:25:54
Message: <3ce3a552@news.povray.org>
> tendrils move toward the top. They have that lazy
Thank you, that was my goal. :)
Rune
Date: 16 May 2002 08:25:55
Message: <3ce3a553@news.povray.org>
TinCanMan wrote:
> oooh! I like.
Phew! Thanks! :)
> it seem CG and not RL, but isn't that the same with all CG.
Well, I never expected that I could make it totally believable. "Almost"
is good enough for me.
Rune
Date: 16 May 2002 08:25:56
Message: <3ce3a554@news.povray.org>
> you shoud make it thinner at the base, and fatter
> at the top :)
Thinner at the base maybe, but fatter at the top will increase render
time too much I think... :)
Rune
Date: 16 May 2002 08:25:57
Message: <3ce3a555@news.povray.org>
> very visible in the frames about 9 sec. into the animation.
You're right, maybe a tad less granularily...
Rune
Date: 16 May 2002 08:25:58
Message: <3ce3a556@news.povray.org>
> for the technical effort, but let me add a tiny bit
> of poison..
Fine by me. :)
> On my monitor, when I turn up the brightness it's
> in sometimes fast, abrupt and unexpected ways..
Yes, I can see that. It's a result of how turbulence works in POV-Ray,
which I use though the vturbulence macro. Turbulence has some abrupt
changes some places.
Unfortunately I don't have any ideas for how to avoid it, but I'll keep
trying to find one.
Rune
Date: 16 May 2002 10:59:07
Message: <3ce3c93b@news.povray.org>
or cigar?
Hrm. Watching one of mine now. because 've got so many fans in my computer,
the turbulance starts almost as son as the smoke particles leave the embers
> now.
atching mine now. I think the smoke becomes blue when you exhale?
Hope so. I've only just managed to get to 1200MHz (from last year's 400)
Date: 16 May 2002 11:18:56
Message: <3ce3cde0$1@news.povray.org>
"Rune" <run### [at] mobilixnetdk> wrote in message news:3ce3a551@news.povray.org...
[Deletions]
I said:
: > Maybe the color could be a little more blue.
: Oh, I thought I had made it very blue. I think I like the color as it is
: now.
I was comparing your animation with the pics that TinCanMan
posted. The pics were quite a bit more blue, but they were
on a total black background.
And it still looks incredible!
=Bob=
