![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I'm not happy with this.. it didn't turn out at all like I'd hoped.. but
after re-rendering three times, I decided it was time to post it.
The cloth behaves as desired whilst it remains attatched to the rail (
notice how the door frame causes the cloth to fold sharply - very nice ),
but later it gets tangled up.
Basically, I created the anim by editing the POV script on-the-fly, entering
different 'wind' values and saving the .pov file in the editor, thus causing
POV to write the updated .cl file for the Post_Process Cloth step to
process.
I was going to post my code for this, but as it didn't turn out very well, I
don't know if it would help anyone - maybe you feel otherwise.
I'll keep on experimenting and hopefully things will improve as Jerome
updates the prog.
Andy Cocker
listen to my music at:
www.mp3.com/lunarland
'I spilled spot remover on my dog. He's gone now. '
'I went to a restaurant that serves "breakfast at any time."
So I ordered french toast during the Renaissance. '
- Steven Wright.
Download 'Door.mpg' (412 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Whoa! I've never seen cloth do that... are you trying to make it dance? :) I
don't care if it doesn't work like you wanted it, I just want to figure out
how you're doing it. TIA
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Still great stuff.
I think it's Alladins magic carpet ;-)
Nekar
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Tony[B]" <ben### [at] catholic org> wrote in message
news:3aa97a82@news.povray.org...
I
out
No, actually, I was expecting the cloth to fall rapidly to the floor when I
removed the attatchments. I was then gonna blow it across the floor.
However, as you can see, when I released the cloth, it hardly fell at all,
so I introduced a wind blowing straight downwards. Then I changed the wind
direction to blow into the room from the corridor, and later to blow
directly upwards.
As you can see, when the wind blows into the room from the corridor, the
cloth twists around on itself, and from then on, the cloth seems to get
tangled up.
I'll tell you what, I'll work on a new simpler scene, and post the source
with instructions that explain what I'm doing. That ok? Expect something
soon.
Andy Cocker
- Steven Wright.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I
You would need to make it heavier then. And also maybe reduce the viscosity
of the air. You've seen my anim. It falls more or less quickly.
OK.
> tangled up.
That's odd.
> soon.
Sure, sounds cool.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3aaa5508@news.povray.org...
when
> I
viscosity
What do you mean "make it heavier"? There's the facility to do this in
Clothray, but not in Cloth Simulator I think. Possibly viscosity has
something to do with it (so many variables, not enough time to experiment
with them all :-( ) I think it's more to do with the -s step value that is
used to simulate time passed between frames. This has to be adjusted to
compliment wind speed etc. IMO, in your anim, things happened a little too
quickly. It is difficult to get it right though.. I often end up with slow
motion cloth.
> > tangled up.
> That's odd.
It is odd, as the wind was blowing directly along the z (y in Cloth) axis,
and the cloth was perpendicular to it, so no twisting should have occurred.
I suspect this is related to the bug that Jerome has possibly fixed, where
the cloth becomes attatched to the surface of a collision object, or, as has
just happened to me, becomes attatched to 'thin air'.
Andy Cocker
- Steven Wright.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Look in the docs for "weight".
Looked fine to me. It all depends on the velocity of the wind. It fell
quickly enough, I think (mine).
has
Let's hope the new version helps. I'm hoping he improves the self-collision
a bit more.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
news:3aaa8b2a@news.povray.org...
Sorry, yes you are quite right. That should help me. What weight settings
have you used? For what size cloth?
Andy Cocker
- Steven Wright.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I've used 0.05 for a 72*44.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3aaa96ed$1@news.povray.org>, "Andy Cocker"
> settings have you used? For what size cloth?
You're right that it is incomplete. Version 0.4.0 fixes that.
Jerome
* Abandon the search for truth, * mailto:ber### [at] iname com
* Settle for a good fantasy. * http://www.enst.fr/~jberger
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
