![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thanks!
MJL
Skip Talbot wrote:
> Sweet deal! How about with radiosity and a high ambient on those cylinders?
> A setup like this with a story/concept behind it would have made a great
> entry in the overly complicated machines IRTC round. Looking forward to the
> updated version.
> Skip
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
POV-Physics 6.5.9.6 - Fake laser beams will cast shadows unless created with
no_shadow sources... doh. Thanks to everyone who pointed that out.
Here is an update, no shadows, slightly higher resolution.
MJL
Download 'laser3.mpg' (279 KB)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I saved it. :o) It's better, but still doesn't really look like 'light'..
But how did you calculate the position of the mirrors?
Hugo
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
No. Light will not block the passage of light.
Cheers!
Chip Shults
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Neat animation. Did you use two trace statements to get the beam to
bounce off the mirrors and stop at the more diffuse objects?
I've got a couple suggestions, since the beam is a little hard to see:
-dim the lights in the room
-give the cylinders an emitting media with a cylindrical density. The
density pattern can be rotated using the Reorient_Trans macro, I think.
Now if you're a real glutton for punishment, you can introduce convex
mirrors and substitute some of the cylinders for cones :)
> with no_shadow sources... doh. Thanks to everyone who pointed that out.
> MJL
Samuel Benge
sbe### [at] caltel com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I know :-( This was meant to be a quick experiment, but maybe I'll try to improve
the laser beam.
Most were easy (90 degree deflections). The others used simple trig.
MJL
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, pretty much.
I thought of doing that, but this was meant to be just an hour or so of
entertainment. I'll see if it improves things though.
Ha! If you do this, you may as well shoot photons and ditch the cylinders
altogether. You could use lenses then too.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Cool. Isn't it supposed to explode at the end?
or is that just all the more S for your ER?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 16 Jul 2002 15:06:55 +1000, Mark James Lewin
Looks good -- although it seems to me like the laserbeam is hitting the
little mirror on the center left for quite a while without a reflected beam
Marc van den Dikkenberg
The PowerBasic Archives -- http://www.xlsior.org
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 17 Jul 2002 13:40:17 -0400, "Greg M. Johnson"
It it would be powerful to explode something at the end, it wouldn't be a
very smart idea to reflect it straight back at the laser emitter, like it
does at the very beginning of the animation. :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
