POV-Ray : Newsgroups : povray.binaries.animations : Submarine with spherical iris (264 kb) Server Time
15 Oct 2025 11:57:39 EDT (-0400)
  Submarine with spherical iris (264 kb) (Message 1 to 9 of 9)
Subject: Submarine with spherical iris (264 kb)
Date: 23 Feb 2002 08:45:07
Message: <3C779CC9.5EDDF1A1@scifi-fantasy.com>
5 second animation, 30 fps, approx. 22 seconds per frame to render.
How do I make blinking lights?!
Tim Cook
Version: 3.12
Download 'selkie.avi.dat' (264 KB)
Subject: Re: Submarine with spherical iris (264 kb)
Date: 23 Feb 2002 09:38:02
Message: <3c77a94a@news.povray.org>
#declare Frequency = 10; // Blinks per clock unit.
#declare Ratio = 0.4; // How much of the time the lamps are on.
#declare LightOn = (mod(clock*Frequency,1)<Ratio);
light_source {<1,2,3>, color rgb 1*LightOn}
But if you're using Moray, then I have no idea.
Nice animation by the way!
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 23 Feb 2002 15:36:31
Message: <3c77fd4f$1@news.povray.org>
Well, you cheated on the iris. Still nice though.
 -Shay
"Timothy R. Cook" <tim### [at] scifi-fantasycom> wrote in message
news:3C779CC9.5EDDF1A1@scifi-fantasy.com...
Date: 23 Feb 2002 18:35:21
Message: <3C78273A.5EC19C8D@scifi-fantasy.com>
Cheated in what manner?  Only rotated each piece from a single point
instead of moving it in the appropriate curve while rotating?  I've
no idea the exact curve needed, nor how to translate it onto a sphere,
nor how to impliment that in Moray...
BtW, I noticed that the normal doesn't change position while the
pieces rotate, giving a somewhat disconcerting appearance.  How
would I fix THAT?
Tim Cook
Version: 3.12
Date: 24 Feb 2002 03:28:24
Message: <3C78A432.BED7B591@gmx.de>
> would I fix THAT?
Rotate and translate the objects AFTER the normal was
applied (no idea how that is done in Moray though).
Tim Nikias
Date: 24 Feb 2002 07:30:34
Message: <94nh7u43j2sg03969h33pjnpftudimbmot@4ax.com>
Hi Timothy R. Cook, you recently wrote in povray.binaries.animations:
> would I fix THAT?
Did you apply the material to the referenced object or the group? It
needs to be applied to the single object (Iris01). Then it
automatically stays fixed with the object, so that when you rotate it,
the texture goes with it (provided you have left the texture
coordinate at the default 'local' setting).
Followups to moray.win
- Lutz
  email : lut### [at] stmuccom
  Web   : http://www.stmuc.com/moray
Date: 24 Feb 2002 15:01:44
Message: <8JTVuOgd4xB@lzer.net>
... damn ...
What a pity, that this kicks my box reproducable to a BSOD
Something must be wrong with my MPEG-decoder ...
I have this also with some other MPEG/AVIs ...
should I reinstall ? ... again ? ...
Date: 24 Feb 2002 23:22:02
Message: <3C79BBF0.E364E83C@scifi-fantasy.com>
Codec used: DivX 3.11
Try www.divx.com
Tim Cook
Version: 3.12
Date: 28 Feb 2002 19:43:08
Message: <3C7ECEB8.E49A3B4F@209software.com>
#if sin(clock/3)>0
    #declare bulbcolor = rgb 0
#else
    #declare bulbcolor = rgb<.8,.8,1>
or, alternately,
#declare bulbcolor = rgb sin(clock/3);
The "/3" part may need to be tweaked to make the blinking slower or faster (frames per
blink wise)
the threshold of 0 in the first line makes it so the light will be on half the time
and off half the time, this is called a duty cycle of 50%.
if you to change the duty cycle, then vary the number from -1 to 1 like this;
#if sin(clock/3)>.8         <--mostly off, blinks on very briefly
#if sin(clock/3)>-.3         <--mostly on, blinks off briefly
> Tim Cook
> http://empyrean.scifi-fantasy.com
