POV-Ray : Newsgroups : povray.binaries.animations : Re: Caustics Server Time
13 Jan 2025 03:44:05 EST (-0500)
  Re: Caustics (Message 1 to 10 of 11)
Subject: Re: Caustics
Date: 24 Nov 2001 16:27:45
Message: <3C0010D1.3FE409C@gmx.de>
Jide wrote:
> Was playing with Cristoph Hormanns water function.
> Went for the height_field approach to save time too.
> A bit of tweaking here and there + photons.
Nice, how many waves did you use?
> Rendertime for 100 frames was a bit over 1 and half
> hours.
Heightfield generated in POV?  How long did it parse per frame?
Date: 24 Nov 2001 17:05:01
Message: <3c00198d@news.povray.org>
Only 40. With more waves the function multiplier has to be
changed because Pov seems to kind of 'wrap' the output to [0,1]
and as much I liked tampering with the settings I'd be easier if
I knew the possible max/min values of the function for different
numbers of waves. I'm propably not making any sense ?
> > hours.
I can get the statistics only for the 7 first frames from the rerun dialog
and the times are between 12.0 and 12.7 seconds (Athlong 1.4 GHz).
And that's for 512*512 hf so not too bad.
-Jide
Date: 24 Nov 2001 17:05:28
Message: <3c0019a8@news.povray.org>
Jide
> hours.
Too fast. Now add scattering media. ;-)
Jonathan.
Date: 25 Nov 2001 08:27:16
Message: <3c00f1b4@news.povray.org>
I've been trying it with scattering media but I can't
get visible light beams :(
-Jide
Date: 25 Nov 2001 11:25:40
Message: <3c011b84@news.povray.org>
Try media 100 in the global_settings photons block.
"Jide" <jid### [at] kotisoonfi> ha scritto nel messaggio
news:3c00f1b4@news.povray.org...
> -Jide
Date: 26 Nov 2001 12:26:23
Message: <3c027b3f$1@news.povray.org>
Had it in there already.
-Jide
Date: 26 Nov 2001 13:18:57
Message: <3c028791$1@news.povray.org>
> -Jide
Also be sure to put
photons {
   target
   refraction on
   reflection on //off?
in the height field. Oh... you may also have problems if the height field
doesn't go all the way "down" to the bottom of the container. You'll need a
plane at the top of the water or something.
But there's a bug with media photons. I've mentioned it a few times, but it
doesn't seem to get on the known bugs list... they make the media too
bright, somehow. (If you encounter this bug too, *please* post it in the
beta group, and i'll confirm it for you, so they'll put it on the list...)
(I wish they'd fix it, because I've got this *awesome* picture that I can
finish once they do.)
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 26 Nov 2001 13:46:11
Message: <3c028df3@news.povray.org>
Have you put hollow inside the heightfield block?
Jonathan.
news:3c027b3f$1@news.povray.org...
> -Jide
Date: 26 Nov 2001 13:48:29
Message: <3c028e7d@news.povray.org>
...which explains why they don't intend to fix it... ;)
Jonathan.
Date: 26 Nov 2001 17:20:34
Message: <3c02c032@news.povray.org>
Yep. I think I have remembered everything. Here's the
relevant code conserning mdeia and photons.
global_settings {
  photons {
    spacing 0.0075
    jitter 0.5
    media 100
#declare M_Watx =
material {
  yadda yadda
  media {
    method 3
    samples 5,5
    intervals 1
    scattering { 2, rgb <0.1,0.18,0.2> }
    collect on
height_field {
    yadda yadda
    hollow
    material { M_Watx }
  photons {
    target
    reflection off
    refraction on
    collect off  // I suspected this might be it but I doesn't seem to
matter
-Jide
