POV-Ray : Newsgroups : povray.beta-test : Radiosity Status: Giving Up... Server Time
29 Mar 2026 06:32:19 EDT (-0400)
  Radiosity Status: Giving Up... (Message 91 to 100 of 194)
Subject: Re: Radiosity Status: Giving Up...
Date: 31 Dec 2008 19:25:37
Message: <495c0d81$1@news.povray.org>
Warp wrote:
> clipka <nomail@nomail> wrote:
>> Duh. Any mention of such things as sin, cos, log or such? I don't see any.
>   I don't see them either, eg. here:
> http://en.wikipedia.org/wiki/X86_instruction_listings#SIMD_instructions
Why do you *expect* to see them?
	Thorsten
Date: 31 Dec 2008 19:27:12
Message: <495c0de0$1@news.povray.org>
Warp wrote:
> Thorsten Froehlich <tho### [at] trfde> wrote:
>> Warp, could you stop theorizing and actually *use* the information already
>> out there, supplied by Intel and plenty of other sources? SSE != SIMD
>   Have you checked lately what "SSE" stands for? ;)
I have no intention to continue such an argument on semantics, this leads
nowhere and does not change the fact that x87 FPU usage is deprecated.
	Thorsten
Date: 31 Dec 2008 19:28:09
Message: <495c0e19@news.povray.org>
> "x87 arithmetic is deprecated in 64-bit mode" - but not because it would
> be inferior, but simply because "the extent to which operating systems will
> continue to support x87 in the future is unknown."
  That's a really odd statement. I didn't know that the FPU or the x87
instruction set required OS support. (Can the OS even force programs to
not use x87 instructions if it wanted to? Even if it could, it would have
to be deliberate, and I can't really understand *why* it would want to
do that. It would certainly break like 99% of software out there, and for
what reason?)
Date: 31 Dec 2008 19:30:25
Message: <495c0ea1@news.povray.org>
  Because you said that, according to Intel, x87 is obsolete and all code
is recommended to use SSE instead. If that's true, then it would be a
rather large setback for programs requiring trigonometric and logarithmic
calculations, as they would have to be made in software.
  I really don't see how SSE obsoletes x87.
Date: 31 Dec 2008 19:31:49
Message: <495c0ef5@news.povray.org>
  So trigonometric and logarithmic functions must be calculated in
software mode now? This is supposed to be a step forward?
Date: 31 Dec 2008 19:44:38
Message: <495c11f6$1@news.povray.org>
>>> You are looking at the wrong manual. This manual does not tell you how
>>> to do something but what is available.
>> I guess it would help if M$ would not call x86-64 "AMD64" in older documents...
> I'm not surprised that they did, because that's what the original implementation
> was named...
<http://download.microsoft.com/download/5/b/5/5b5bec17-ea71-4653-9539-204a672f11cf/AMD64_PortApp.doc>
>> <http://developer.amd.com/pages/62720069_4.aspx>
> I still don't get the point.
x87 is "bad" because the FPU stack architecture (effectively only having two
registers) makes it next to impossible to schedule instructions in a
compiler in any reasonable way. SSE provides eight registers instead,
reducing register pressure and hence making floating-point computations more
efficient.
That is why AMD/MS defined x86-64 to pass floating-point values by SSE
registers. This change enables all kinds of common optimizations the non-x86
world has enjoyed for decades. Of course, all this has nothing to really do
with x86-64, it just happens that as an ABI change was needed, this old
issue has been fixed while also adding 64-bit integer support.
> There is no mention that SSE2 could do the same transcendental functions without
> some additional piece of software, and I wonder whether that will do good to
> performance.
In essence x86 is the only architecture where more than sqrt is still
supported in microcode hardware. Doing this in software is much more
desirable and efficient.
	Thorsten
Date: 31 Dec 2008 19:47:54
Message: <495c12ba$1@news.povray.org>
Clearly you do not know much about floating-point units in modern processors
then. You actually want to do it is software because that is more efficient
(see my other post). x87 is pretty much the last architecture to still have
microcode ops for more than sqrt.
	Thorsten
Date: 31 Dec 2008 19:52:10
Message: <495c13ba$1@news.povray.org>
Yes, by not saving and restoring the x87 "register" stack when switching
threads or making operating system calls. You need OS support for that.
	Thorsten
Date: 31 Dec 2008 20:05:01
Message: <web.495c1662cd9d1e7530acaf600@news.povray.org>
>   Besides the basic operations there's sqrt, but no trigonometric nor
> logarithmic functions. x87 has those (although only base-2 logarithms
> are supported directly).
Only base-2 logarithms? Hey, big deal :)
Base-x logarithms (with constant x) are easily done computing the base-2
logarithm and dividing the result by a constant (namely the base-2 logarithm of
x).
But I guess I'm not telling you any news here.
(I was a bit surprised to find that the supported base is 2, not e - but
thinking about again it's straightforward of course, and I wouldn't be
surprised if computing log2 would actually be a piece of cake on a binary
computer, maybe even easier than a sqrt.)
Date: 31 Dec 2008 20:10:00
Message: <web.495c1775cd9d1e7530acaf600@news.povray.org>
> what reason?)
Faster task switching, and less mem requirements for task information.
Currently, a task switch needs to save x87 FPU registers.
