POV-Ray : Newsgroups : povray.beta-test : Radiosity Status: Giving Up... Server Time
26 Mar 2026 23:25:02 EDT (-0400)
  Radiosity Status: Giving Up... (Message 185 to 194 of 194)
Subject: Re: Radiosity Status: Giving Up...
Date: 8 Jan 2009 04:51:17
Message: <9EBA57A61A6644F8904D39D12C71058C@HomePC>
> -----Original Message-----
> From: Warp [mailto:war### [at] tagpovrayorg]
>   And as long as the OS is run on a system with FPU and with programs
> using
> the FPU, the OS cannot drop support. It's that simple.
Minor nitpick... it's not about dropping the FPU, because it's the same
FPU that runs x87 as well as SSE/2/3/4.  They're the same transistors.
What's being deprecated is the instruction set, not the component of the
CPU.
...Ben Chambers
www.pacificwebguy.com
Date: 8 Jan 2009 05:03:06
Message: <9BB5C48AA611419686C70EA14AAA05AD@HomePC>
>   So the hardware would be perfectly able to run the software, but the
> OS deliberately stops the software from being run if it uses the FPU.
> And this makes sense?
They don't deliberately stop it from working.  What's being considered
(although not implemented yet) is simply not doing the work to make it
keep working.
...Ben Chambers
Date: 8 Jan 2009 05:06:26
Message: <68FE4234D83B40F4A862D313E34F8D45@HomePC>
>   At least in the past Intel processors had the strange rule that you
> cannot
> use the FPU and the SSE unit at the same time. I don't know if they
> have
> fixed that limitation later.
No, you had to switch modes (and deal with saving state et al).  Mainly
because... wait for it...  it's the same unit!
X87 and SSE both use the same units on the processor.  Even MMX shared
the same units (to some extremely limited extent).  You can't use them
both at the same time, because of the operating mode (like 16bit and
32bit code, you can't run them both at the same time, though you *could*
switch between them).
...Ben Chambers
Date: 8 Jan 2009 05:08:44
Message: <157DE14D8C6241B4B288D9BC4FCB39F4@HomePC>
>   Maybe it's different in a x86-64 architecture, but at least in my
P4,
Please use a modern processor when discussing future plans for
processors.
That's like basing your claims for Windows 7 on what Windows 2000 looked
like.
...Ben Chambers
Date: 8 Jan 2009 11:24:24
Message: <496628b8@news.povray.org>
> P4,
> processors.
  I was not talking about plans for processors. I was talking about the
claim that *operating systems* (including linux) are going to drop support
for the FPU even on architectures which do have a perfectly good FPU (ie.
every single current Intel and AMD processor). I find this claim ludicrous,
especially for linux (which aims for maximal portability).
Date: 8 Jan 2009 13:06:54
Message: <E27156FD1B5345A39FEF77078A910197@HomePC>
the
> support
> (ie.
> ludicrous,
Oh, it definitely is ludicrous.
The Wikipedia article on x87 clearly states that "The x87 unit is
largely deprecated on the 64-bit x86-64 architecture and associated
64-bit implementations of operating systems such as Microsoft Windows,
Mac OS X, Solaris, and Linux though it is still well supported for full
compatibility with older applications."
...Ben Chambers
Date: 8 Jan 2009 13:15:01
Message: <web.49664246cd9d1e75fa150d980@news.povray.org>
Actually, I found this claim on the German Wikipedia article on
darauf in der Version 3.1 zu einer weiteren Umstellung, die wiederum bald
letzte ABI Wechsel erfolgte mit Version 3.4, welche auch in der aktuellen 4.x
Reihe des GCC Verwendung findet. Da die eingesetzte GCC Version von
entweder im Quelltext oder in mehreren ABI-Versionen ausgeliefert werden."
which roughly tranlsates to:
therefore it happens rather seldom. A more recent opposite example however is
the C++ ABI for the GNU C++ compiler, that first changed from version 2.95 to
version 3.0; due to errors in this new ABI it was soon followed up by another
change in version 3.1, which in turn was superseded soon after by the ABI of
version 3.2, to be compatible to other compilers like that from Intel. As it is
almost impossible to migrate the system smoothly to a new ABI, this rapid change
caused a lot of disgruntlement. The last ABI change occurred with version 3.4,
which is also used with the current 4.x versions of the GCC. As the version of
GCC employed can differ from Linux distribution to Linux distribution, C++
programs for Linux which mainly build on the GNU compiler must be distributed
either as source code or in multiple ABI versions."
So much for binary compatibility in the (x86) Linux world...
This makes sense insofar as *binary* compatibility has never been that much of
an issue in the Unix world anyway: Software has always been *expected* to need
recompiling on different machines anyway. It was only the success of "IBM
compatible (!) PCs" that started the whole binary compatibility thing anyway.
In fact, Linux runs on many, many more platforms than just x86 - maybe more than
Windows will ever dream of running on - and has been doing so almost ever since
it came to existence; so the portability in Linux always had to be achieved at
a non-binary level anyway. (And strictly speaking, portability actually only
begins where binary compatibility comes to an end.)
So all in all, thinking it over again, I don't find it too surprising to
actually see more emphasis on binary compatibility in Windows than in Linux.
Date: 8 Jan 2009 13:50:03
Message: <49664adb$1@news.povray.org>
Isn't that more a C++ thing than a x86 ABI thing? Is it the calling
conventions to the OS, the stack frame format, or the C++ name mangling and
structure layout that changed?
Nah. CP/M before that, and lots of mainframe stuff before that, SPARC
stations too, etc.  People have wanted binary compatibility since core
memory days.
   Why is there a chainsaw in DOOM?
   There aren't any trees on Mars.
Date: 10 Jan 2009 02:40:00
Message: <web.49685085cd9d1e75f3c0a050@news.povray.org>
Don't know details - I'm just quoting. But it's a GNU thing in any case, and
although "GNU's Not Unix", GNU's Linux. (Well, that's not perfectly true, but
anyway...)
> memory days.
I don't know about SPARC, but successors of CP/M threw binary compatibility
overboard (had to, because they switched from 8080 to something else). MS-DOS
for instance, which in its very core was "heavily inspired" by CP/M, and
included some data structures just for the sake of compatibility with it.
And if I remember correctly, there were even things like CP/M for 68k systems,
which is definitely bye-bye to binary compatibility.
Sure, people have *wanted* binary compatibility since core memory days, but
since when did people get *used* to it?
Date: 10 Jan 2009 06:59:59
Message: <49688dbf$1@news.povray.org>
clipka wrote:
> MS-DOS for instance, which in its very core was "heavily inspired" by CP/M, and
You are correct - in fact, it was designed to allow machine-translated 8080
CP/M programs to run directly. That is, basically, all that needed to be
done was translate the instructions - the translator did not need to worry
about trying to understand what the instructions where *doing*, and hence
did not need to fix up operating system calls etc. They just worked. Even
the MS-DOS '.com' file format was dictated by the way CP/M worked (the
first 256 bytes of a com file replicate the first 256 bytes of memory in a
CP/M system).
-- Chris
