POV-Ray : Newsgroups : povray.beta-test : Known Bugs 14 Jan 2002 Server Time
13 Mar 2026 08:29:27 EDT (-0400)
  Known Bugs 14 Jan 2002 (Message 34 to 43 of 43)
Subject: Re: Known Bugs 14 Jan 2002
Date: 17 Jan 2002 05:44:35
Message: <3c46ab13$1@news.povray.org>
"Mike Williams" <mik### [at] nospamplease> wrote.
>>> Isosurface *disappears* at high resolution (fwd)
>>> http://news.povray.org/3bb0b351@news.povray.org
>>Cannot duplicate.
>I can duplicate this (although the quick version that I wrote now runs
>to completion). The point at which the quick version collapsed into
>blankness has varied from beta to beta, and now manages to go all the
>way through. The original scene file posted by Warp still fails when
>rendered with the specified size and antialliassing.
>The question is whether this is a bug, or whether isosurfaces that use
>crackle can legitimately be expected to disappear.
This is not a bug.  That behavior is due to the wrong max_gradient value.
The function of the original scene file posted by Warp has extremely
large gradient values.  See the warning message.
Try the following function for the isosurface of that scene,
function{min(1,max(-0.5,(1+Blob_threshold)-Blob_threshold^Funki1(x,y,z)
          -Blob_threshold^Funki2(x,y,z)))}
The maximum gradient in the warning message is much lower than that of
the original function.  Then, it gives us better result.
R. Suzuki
Date: 17 Jan 2002 07:04:41
Message: <3c46bdd9$1@news.povray.org>
In article <yjd### [at] econymdemoncouk> , Mike Williams
>>Cannot duplicate.
Which has already been explained in the thread following the report.
I really don't see what is so difficult to understand about this not being a
bug.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 17 Jan 2002 23:45:23
Message: <3c47a863@news.povray.org>
Mike Williams wrote in message ...
>>> Bugs with string/macro handling
>>> http://news.povray.org/3be76148$1@news.povray.org
>>Partial confirmation.  I can get error cases #1 (Too many nested symbol
>>tables) and #2 ("BCFGHJKLMQSUVWXY") but none of the others.
>>At first glance that the original poster is trying to do with the scene
>>description language is somewhat akin to driving nails with a shoe.  As
>>such I am unsure if this problem should be fixed or if the workaround
>>should be 'reimplement your code in perl, Python, rexx, or C.'
>I think I'll move that into the "not a bug" box, unless anyone has
>serious objections.
This is quite definitely a bug.  Whether it is a bug worth the effort of
fixing or not is another matter.
Mark
Date: 17 Jan 2002 23:57:45
Message: <rOI9MHAuW1R8EwVF@econym.demon.co.uk>
>>Cannot duplicate.
On further investigation, my short version does still collapse under
beta 10. I'd somehow managed to save the scene file with the magic
"three blank lines" missing. As noted (and confirmed) in the original
thread removing the three blank lines causes the scene to render
correctly.
Mike Williams
Gentleman of Leisure
Date: 17 Jan 2002 23:57:47
Message: <f+PwwKAxh1R8Ewwl@econym.demon.co.uk>
>>>Cannot duplicate.
That explanation was proposed in the original thread, but it didn't
explain the fact that decreasing the max_gradient, or changing the
amount reflection or removing three blank lines caused the scene to
render correctly. I've got a nagging suspicion that for such very subtle
changes to cause the scene to go from rendering correctly to being so
badly wrong there may be something nasty deep down that might possibly
come back and bite us later.
(One, irrelevant, side effect of this scene is that the scene will
render completely differently on a render farm than on a single machine.
The machine that renders the bottom third of the image will see the
isosurface, but a single machine that starts at the top and works all
the way down will not see any isosurface in the bottom third of the
image.)
It may well not be a bug (that's why it's not in the confirmed bug
list). If it isn't a bug, then The reason it is not a bug is the one
stated by Thorsten in.
http://news.povray.org/3bb928b1$1@news.povray.org
        "Not a bug, but a limit in the crackle function when used with
        isosurfaces."
Mike Williams
Date: 18 Jan 2002 04:34:27
Message: <3c47ec23@news.povray.org>
That subtle change is due to the "isosurface cache". Following is a simple
example.
#include "functions.inc"
camera { location <0,0,-30> look_at 0 angle 50 }
light_source { <1,2,-3>*10, 1.2 }
isosurface
  function { abs(mod(x+10,1)-0.5)+abs(z)-0.3+select( (f_r(x,y,z/4)-0.08) ,10,
0) }
  contained_by { box{-<2,10,0.3> <2,10,0.3> } }
  max_gradient 2
  pigment { rgb 1 }
  rotate y*0
Try this scene with several different resolutions.  If you see a large
artifact, try to change the max_gradient value or rotation angle of y-axis.
A brief explanation of the cache technique is as follows.
If the minimum function value on a ray, F_min, is a positive
value, the latter calculation will be skipped in case (the distance
from the ray) < F_min/max_gradient.
This works properly if the real maximum gradient is less than the
max_gradient.  But if not, the possibility of improper rendering becomes high.
In the above case, F_min is about 10 in a certain condition.
Then, the latter calculation will be skipped in case
(the distance from the origin) < ~5(=~10/2).
Yes.  But this occurs if the real maximum gradient is much greater than
'max_gradient' in the scene file.
I've not added "cache on/off" option to the original isosurface patch because
I was not sure whether it is really required or not.
Both the original scene and my example scene do not need this option
if we use a 'truncation' (min/max) technique.
R. Suzuki
Date: 18 Jan 2002 17:02:42
Message: <lsseEaAzfHS8EwPU@econym.demon.co.uk>
>example.
>isosurface
>0) }
>  max_gradient 2
>  pigment { rgb 1 }
>  rotate y*0
Thanks. That makes sense.
I think I'll add a simplified version of that to my isosurface tutorial
in a while.
Mike Williams
Date: 2 Feb 2002 03:31:57
Message: <5BmJvIAKH6W8Ew+O@econym.demon.co.uk>
Wasn't it Coridon Henshaw who wrote:
>> Media visible container line in front of object
>> (a visible whitish line appears at the edge of a transparent container
>> box for media)
>> http://news.povray.org/3bf45a3d@news.povray.org
>Confirmed.  This problem can be masked--but not eliminated--with
>antialiasing.
In http://news.povray.org/3c596886@news.povray.org Thorsten says that
this hasn't been confirmed.
Mike Williams
Date: 2 Feb 2002 03:32:02
Message: <1RnK7MAPK6W8Ewet@econym.demon.co.uk>
>> [win gui] line with error highlighted but render finished succesfully
>> http://news.povray.org/va2tvt4tuitd67ik5t9ps334sbg6205bt3@4ax.com
>Not tested specifically, but I've run into this problem before with
>ordinary parsing errors (e.g. undeclared identifiers) not related to
>#fopen.
Thorsten doesn't accept that as confirmation, so I'll move it back into
unconfirmed.
Mike Williams
Date: 2 Feb 2002 03:32:05
Message: <zRBLbRAXL6W8Ew$R@econym.demon.co.uk>
>> media & fog bug?
>> http://news.povray.org/3c1379e0$1@news.povray.org
>Confirmed.
Thorsten says it's not confirmed.
Mike Williams
