![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Thorsten Froehlich" wrote:
>It is by design for _this_ beta and part of the changes to the
>output that have been in progress for several weeks now until a
>final solution can be found. The previous beta versions' output
>was incorrect, the current change only disables the incorrect
>output without providing the correct output yet.
If you want to change the output of 'evaluate' more helpful,
please add "maximum gradient variation" between neighboring rays.
[grad_var = abs(max_grad(Nth ray)-max_grad((N-1)th ray) ) ]
Then, the parameters of 'evaluate' for dynamic max_gradient estimation
should be as follows,
1st parameter < max_grad
1 < 2nd parameter < max_grad/(max_grad - max_grad_var)
1 > 3rd parameter > 1/(2nd parameter)
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Coridon Henshaw wrote in message ...
>> Bugs with string/macro handling
>> http://news.povray.org/3be76148$1@news.povray.org
>Partial confirmation. I can get error cases #1 (Too many nested symbol
>tables) and #2 ("BCFGHJKLMQSUVWXY") but none of the others.
>At first glance that the original poster is trying to do with the scene
>description language is somewhat akin to driving nails with a shoe. As
>such I am unsure if this problem should be fixed or if the workaround
>should be 'reimplement your code in perl, Python, rexx, or C.'
I'm doing this in SDL for much the same reason that Warp wrote the SDL
raytracer and I wrote my POV-Ray Scene Virus -- to show that it can be done.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Wasn't it Coridon Henshaw who wrote:
>Mike Williams <mik### [at] nospam please> wrote in
>news:4gz### [at] econym demon co uk:
>> max_trace_level affects radiosity recursion_limit
>> (Setting max_trace_level 1 disables radiosity and max_trace_level 2
>> sets recursion_limit to 1)
>> http://news.povray.org/3BE40295.6C3D54DE@engineer.com
>I can confirm portions of this report. While reducing max_trace_level to 1
>does not disable radiosity under beta 10, max_trace_level does appear to
>impose an upper bound on recursion_limit. recursion_limit settings in
>excess of the max_trace_level appear to be ignored.
Thanks. Added to known bugs.
I think I'll move that into the "not a bug" box, unless anyone has
serious objections.
>> Philosophical objection to fog distance=0
>> (Fog colour is then ignored)
>> http://news.povray.org/3BE7E897.FEC8EF6@aol.com
>Confirmed that the code provided works as the original poster stated.
I knew that, the question is whether the code should behave that way or
not.
>> Animated textures
>> (memory usage goes quite high)
>> http://news.povray.org/3bea26bf@news.povray.org
>Not tested. I suspect this bug might be another incarnation of one of the
>various memory leaks reported elsewhere.
>> Isosurface *disappears* at high resolution (fwd)
>> http://news.povray.org/3bb0b351@news.povray.org
>Cannot duplicate.
I can duplicate this (although the quick version that I wrote now runs
to completion). The point at which the quick version collapsed into
blankness has varied from beta to beta, and now manages to go all the
way through. The original scene file posted by Warp still fails when
rendered with the specified size and antialliassing.
The question is whether this is a bug, or whether isosurfaces that use
crackle can legitimately be expected to disappear.
>> Media visible container line in front of object
>> (a visible whitish line appears at the edge of a transparent container
>> box for media)
>> http://news.povray.org/3bf45a3d@news.povray.org
>Confirmed. This problem can be masked--but not eliminated--with
>antialiasing.
>> Priority troubles
>> (higher priorities cause slower render)
>Uhhh, message-id? ;-)
3BF4B750.39EA34A7@joplin.com
>> [win gui] line with error highlighted but render finished succesfully
>> http://news.povray.org/va2tvt4tuitd67ik5t9ps334sbg6205bt3@4ax.com
>Not tested specifically, but I've run into this problem before with
>ordinary parsing errors (e.g. undeclared identifiers) not related to
>#fopen.
Thanks. I'll add that to known bugs.
>> var_refl.pov (\scenes\textues\finishes) Beta 8
>> (should #include "functions.inc")
>> http://news.povray.org/3C0A9650.6B98925@compuserve.com
>Cannot duplicate.
>> transform syntax
>> (transform {test_trans} sometimes requires {} and sometimes doesn't)
>> http://news.povray.org/3C09EE1B.A38DC91A@gmx.de
>Confirmed.
>> Win Beta 8: Message window/parse hang error?
>> (hangs after "Degenerate Blob" warning)
>> http://news.povray.org/3c0bdc77@news.povray.org
>Insufficient data to make a determination.
>A generic scene containing a single degenerate blob did not cause pov to
>lock up.
>> another bug I haven't seen mentioned
>> (Yellow band around sky_sphere equator)
>> http://news.povray.org/3c10ef62$1@news.povray.org
>Cannot duplicate with the following scene:
>sky_sphere {pigment {gradient y triangle_wave color_map {[0 rgb 0] [1 rgb
>1]}}}
>If the original poster can provide a sample scene I will try again.
>> media & fog bug?
>> http://news.povray.org/3c1379e0$1@news.povray.org
>Confirmed.
>> bug in sphere_sweep for removing parts of an object
>> (parameterised sphere_sweeps are very slow. May or may not be related
>> to job000176)
>> http://news.povray.org/3C1A5D47.EA38F6E5@amc.uva.nl
>Confirmed.
>> Re: Mosaic... some clarifications
>> (#local A2=P(1,2,3).hf; fails)
>> http://news.povray.org/9n9j1uo0mdlrs4i5toupujr0pqrj4vvb8d@4ax.com
>Confirmed.
>> Re: hollow in light groups
>> http://news.povray.org/3c21172d$1@news.povray.org
>Confirmed.
>> Is there a problem with area light
>> http://news.povray.org/3c22f013@news.povray.org
>Cannot duplicate. area_light settings which produce smooth shadows under
>3.1 also produce smooth shadows under 3.5.
>> Bug with transform syntax
>> http://news.povray.org/chrishuff-5FC1B7.19310427122001@netplex.aussie.or
>> g
>Confirmed.
>> Minor Windows annoyance
>> http://news.povray.org/3c2bec89@news.povray.org
>Chris Cason said (in <3c2c6b4a@news.povray.org>) that he's looking into
>this one.
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Mike Williams" <mik### [at] nospam please> wrote.
>>Cannot duplicate.
This is not a bug. That behavior is due to the wrong max_gradient value.
The function of the original scene file posted by Warp has extremely
large gradient values. See the warning message.
Try the following function for the isosurface of that scene,
function{min(1,max(-0.5,(1+Blob_threshold)-Blob_threshold^Funki1(x,y,z)
-Blob_threshold^Funki2(x,y,z)))}
The maximum gradient in the warning message is much lower than that of
the original function. Then, it gives us better result.
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <yjd### [at] econym demon co uk> , Mike Williams
>>Cannot duplicate.
Which has already been explained in the thread following the report.
I really don't see what is so difficult to understand about this not being a
bug.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Mike Williams wrote in message ...
>serious objections.
This is quite definitely a bug. Whether it is a bug worth the effort of
fixing or not is another matter.
Mark
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>Cannot duplicate.
On further investigation, my short version does still collapse under
beta 10. I'd somehow managed to save the scene file with the magic
"three blank lines" missing. As noted (and confirmed) in the original
thread removing the three blank lines causes the scene to render
correctly.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>Cannot duplicate.
That explanation was proposed in the original thread, but it didn't
explain the fact that decreasing the max_gradient, or changing the
amount reflection or removing three blank lines caused the scene to
render correctly. I've got a nagging suspicion that for such very subtle
changes to cause the scene to go from rendering correctly to being so
badly wrong there may be something nasty deep down that might possibly
come back and bite us later.
(One, irrelevant, side effect of this scene is that the scene will
render completely differently on a render farm than on a single machine.
The machine that renders the bottom third of the image will see the
isosurface, but a single machine that starts at the top and works all
the way down will not see any isosurface in the bottom third of the
image.)
It may well not be a bug (that's why it's not in the confirmed bug
list). If it isn't a bug, then The reason it is not a bug is the one
stated by Thorsten in.
http://news.povray.org/3bb928b1$1@news.povray.org
"Not a bug, but a limit in the crackle function when used with
isosurfaces."
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That subtle change is due to the "isosurface cache". Following is a simple
example.
camera { location <0,0,-30> look_at 0 angle 50 }
light_source { <1,2,-3>*10, 1.2 }
isosurface
function { abs(mod(x+10,1)-0.5)+abs(z)-0.3+select( (f_r(x,y,z/4)-0.08) ,10,
0) }
contained_by { box{-<2,10,0.3> <2,10,0.3> } }
max_gradient 2
pigment { rgb 1 }
rotate y*0
Try this scene with several different resolutions. If you see a large
artifact, try to change the max_gradient value or rotation angle of y-axis.
A brief explanation of the cache technique is as follows.
If the minimum function value on a ray, F_min, is a positive
value, the latter calculation will be skipped in case (the distance
from the ray) < F_min/max_gradient.
This works properly if the real maximum gradient is less than the
max_gradient. But if not, the possibility of improper rendering becomes high.
In the above case, F_min is about 10 in a certain condition.
Then, the latter calculation will be skipped in case
(the distance from the origin) < ~5(=~10/2).
Yes. But this occurs if the real maximum gradient is much greater than
'max_gradient' in the scene file.
I've not added "cache on/off" option to the original isosurface patch because
I was not sure whether it is really required or not.
Both the original scene and my example scene do not need this option
if we use a 'truncation' (min/max) technique.
R. Suzuki
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>example.
>isosurface
>0) }
> max_gradient 2
> pigment { rgb 1 }
> rotate y*0
Thanks. That makes sense.
I think I'll add a simplified version of that to my isosurface tutorial
in a while.
Mike Williams
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
