![](/i/fill.gif) |
Hi again!
A more detailed description:
I created a minimum scene file "test.pov" which can be used to reproduce the
problem.
"test.pov" uses a texture map "test.bmp" located in a separate directory,
which is specified using the +L option.
I also included the exact command line and the output of pvengine for both
3.5 and 3.6b1 (see below).
You will find a zip-file of my test directory in the
povray.beta-test.binaries group.
System:
Dell Inspiron 8600 (Windows XP Prof, Pentium M 1.7GHz, 1024 MB DDR-SDRAM)
Test files:
c:\Test\test.pov
test.pov:
light_source {
<0,0,1>
camera
location <0.5,0.5,3>
look_at <0.5,0.5,0>
#declare texTex1 = texture
uv_mapping pigment { image_map { sys "texture.bmp" interpolate 2 } }
mesh
triangle { <0,0,0>, <1,0,0>, <1,1,0> uv_vectors <1,0>, <0,0>, <0,1>
texture { texTex1 } }
triangle { <0,0,0>, <1,1,0>, <0,1,0> uv_vectors <1,0>, <0,1>, <1,1>
Povray v3.5:
Command Line:
C:\Test>C:\PROGRA~1\POV-RA~1.5\BIN\PVENGINE.EXE /RENDER "c:\test\test.pov"
+Lc:\test\textures
ouput:
Persistence of Vision Ray Tracer(tm) for Windows.
POV-Ray for Windows is part of the POV-Ray(tm) suite of programs.
This is version 3.5.icl.win32.
The POV-Ray software is Copyright 1991-2002 POV-Team(tm).
This Windows version is Copyright 1996-2002 Christopher J. Cason.
It is distributable only under the conditions in POVLEGAL.DOC.
Select Help|About (or press Alt+B) for more information and a copy of
POVLEGAL.DOC.
The terms POV-Ray, POV-Team, and Persistence of Vision Raytracer are
trademarks of the
Persistence of Vision Development Team (POV-Team)
POV-Ray is based on DKBTrace 2.12 by David K. Buck & Aaron A. Collins.
Primary POV-Ray 3.5 Developers: (Alphabetically)
Chris Cason Thorsten Froehlich Nathan Kopp Ron Parker
Primary POV-Ray 3.0 & 3.1 Developers: (Alphabetically)
Steve Anger Dieter Bayer Chris Dailey Andreas Dilger
Steve Demlow Alexander Enzmann Dan Farmer Eduard Schwan
Timothy Wegner Chris Young
Major Contributing Authors: (Alphabetically)
Steve A. Bennett David K. Buck Aaron A. Collins Mark Gordon
Pascal Massimino Jim McElhiney Douglas Muir Bill Pulver
Robert Skinner Zsolt Szalavari Scott Taylor Drew Wells
Other contributors listed in the documentation.
Support libraries used by POV-Ray:
ZLib 1.1.4, Copyright 1995-1998 Jean-loup Gailly and Mark Adler
LibPNG 1.2.1, Copyright 2000, 2001 Glenn Randers-Pehrson
LibJPEG 6b, Copyright 1998 Thomas G. Lane
LibTIFF 3.5.7, Copyright 1988-1997 Sam Leffler, 1991-1997 Silicon Graphics,
Inc.
This Windows port by Christopher J. Cason.
Loaded 8 tools from C:\PROGRAM FILES\POV-RAY FOR WINDOWS
V3.5\INI\PVTOOLS.INI into Tool Menu.
Requested render file is 'c:\test\test.pov'
Calling rendering engine with parameters '+Lc:\test\textures'
Preset INI file is 'C:\PROGRAM FILES\POV-RAY FOR WINDOWS
V3.5\renderer\quickres.ini', section is '[512x384, No AA]'.
Preset source file is 'c:\test\test.pov'.
Rendering using command line '+Lc:\test\textures'.
Persistence of Vision(tm) Ray Tracer Version 3.5 win32 (.icl)
This is an official version prepared by the POV-Ray Team. See the
documentation on how to contact the authors or visit us on the
internet at http://www.povray.org/.
Copyright 1991-2002 POV-Ray Team(tm)
This Windows version by Christopher J. Cason
Parsing Options
Input file: c:\test\test.pov (compatible to version 3.5)
Remove bounds........On Split unions........Off
Library paths: C:\Program Files\POV-Ray for Windows v3.5\INCLUDE
C:\WINDOWS\Fonts c:\test\textures
Output Options
Image resolution 512 by 384 (rows 1 to 384, columns 1 to 512).
Output file: test.bmp, 24 bpp (system format)
Graphic display......On (type: 0, palette: 3, gamma: 2.2)
Povray v3.6b1:
Command Line:
C:\Test>C:\PROGRA~1\POV-RA~1.6\BIN\PVENGINE.EXE /RENDER "c:\test\test.pov"
+Lc:\test\textures
output:
Jim McElhiney Douglas Muir Juha Nieminen Bill Pulver
Eduard Schwan Wlodzimierz Skiba Robert Skinner Yvo
Smellenbergh
Zsolt Szalavari Scott Taylor Massimo Valentini Timothy Wegner
Drew Wells Chris Young
Other contributors are listed in the documentation.
LibPNG 1.2.5, Copyright 1998-2002 Glenn Randers-Pehrson
LibTIFF 3.5.7, Copyright 1988-1997 Sam Leffler, 1991-1997 SGI
Redirecting Options
All Streams to console..........Off
Debug Stream to console.........Off
Fatal Stream to console.........Off
Render Stream to console........Off
Statistics Stream to console....Off
Warning Stream to console.......Off
Parsing Options
Input file: c:\test\test.pov (compatible to version 3.60)
Split unions.........Off
Library paths:
C:\Program Files\POV-Ray for Windows v3.6\INCLUDE
C:\WINDOWS\Fonts
Output Options
Graphic display......On (gamma: 2.2)
Mosaic preview.......Off
CPU usage histogram..Off
Continued trace......Off
Tracing Options
Quality: 9
Bounding boxes.......On Bounding threshold: 3
Light Buffer.........On
Vista Buffer.........On Draw Vista Buffer....Off
Antialiasing.........Off
Clock value: 0.000 (Animation off)
File: c:\test\test.pov Line: 14
File Context (5 lines):
Parse Error: Error opening BMP image 'texture.bmp'.
Total Scene Processing Times
Parse Time: 0 hours 0 minutes 0 seconds (0 seconds)
Photon Time: 0 hours 0 minutes 0 seconds (0 seconds)
Render Time: 0 hours 0 minutes 0 seconds (0 seconds)
Total Time: 0 hours 0 minutes 0 seconds (0 seconds)
CPU time used: kernel 0.09 seconds, user 0.00 seconds, total 0.09 seconds
POV-Ray finished
Stefan
![](/i/fill.gif) |
![](/i/fill.gif) |
command line:
pvengine -ic:\test\test.pov
Pov3.5:
ok
Pov3.6:
a dialog box pops up:
"Don't know what to render!"
"No source file specified, either directly or via an INI file."
platforms:
WinXP Prof, Pentium M, 1.7GHz, 1GB RAM
Win 2000 Server, Pentium 4 HT, 3 GHz, 1 GB RAM
Win NT 4, Pentium 4, 2.4GHz, 512 MB RAM
Stefan
![](/i/fill.gif) |
