POV-Ray : Newsgroups : povray.beta-test : POV-Ray v3.8.0-alpha.9861167 Server Time
27 Apr 2024 04:43:14 EDT (-0400)
  POV-Ray v3.8.0-alpha.9861167 (Message 19 to 28 of 28)
Subject: Re: POV-Ray v3.8.0-alpha.9861167
Date: 22 Oct 2018 17:33:36
Message: <5bce4230@news.povray.org>
Am 21.10.2018 um 09:29 schrieb Thomas de Groot:
> On 6-10-2018 13:14, William F Pokorny wrote:
>> Aside 2: IIRC there is still a thread collision in the current
>> implementation (which Thomas, in 3.8 no longer needs to be "naked"
>> thanks to Christoph's updates) -
> Hmmm... is that so? I am currently using an isosurface and the
> max_gradient warning only shows if the isosurface is "naked" i.e.
> without #declare.
> Using v 3.8.0-xtokenizer.9844488+av609.msvc with Win7
It doesn't matter whether you use `#declare` or not; what really matters
is whether there are actually rays shot at the isosurface during the render.
So a `#declare`d isosurface that is never actually inserted into the
scene will never get a warning.
Date: 23 Oct 2018 02:40:16
Message: <5bcec250$1@news.povray.org>
@ clipka and Bill:
I am probably totally misunderstanding something, but I attach here a
simple scene of the Kluchikov Ring with a on/off switch between a
'declared' and a 'non-declared' isosurface. The 'non-declared' one shows
a max_gradient warning at the end of the render; the 'declared' one does
not.
Download 'ak_my favourite isosurface test.7z.zip' (2 KB)
Date: 23 Oct 2018 03:25:01
Message: <web.5bcecc5fef23b9626427f7f90@news.povray.org>
hi,
> Am 21.10.2018 um 01:51 schrieb clipka:
> >> did you receive the email?
> Nevermind. I was a bit confused. Yes, the e-mail did reach me,
phew.
> and I
> managed to come up with a fix in no time flat(*), but hadn't gotten
> around to providing feedback yet, or push the fix to the repo for that
> matter.
I saw the weather you were having the past two weeks, and suspected you might be
out sunbathing.  :-)
> (*Interestingly, the bug was in a piece of code I had always been
> suspicious about whether I had implemented it correctly. Turns out I
> hadn't.)
regards, jr.
Date: 23 Oct 2018 12:14:05
Message: <5bcf48cd$1@news.povray.org>
Am 23.10.2018 um 08:40 schrieb Thomas de Groot:
>> render.
> @ clipka and Bill:
> not.
You are aware that the two isosurfaces are not identical? They differ in
the max_gradient setting.
Not that it would make any difference though - I do get a warning for
both of them.
Did you double-check that you're really seeing what you think you're seeing?
What version of POV-Ray are we talking about?
Date: 24 Oct 2018 02:40:46
Message: <5bd013ee$1@news.povray.org>
>>> render.
>> @ clipka and Bill:
>> shows a max_gradient warning at the end of the render; the 'declared'
>> one does not.
Correct. My bad. Both max_gradients should be 0.75 (or what ever).
> both of them.
I do not. I only get a warning when the isosurface is /not/ declared.
> seeing?
Yes, absolutely!!
You are right (of course you are right!): I had not yet used the alpha
version 3.8.0-alpha.9861167+av620.msvc14.win as I thought they were more
or less identical. It shows the warning for both cases indeed. I had not
been aware that the case had been solved in between. Thanks!
Phwwww..... That was close! I am glad I do not have to put myself under
psychiatric treatment after all ;-)
[where are my dried frog pills...?]
Date: 25 Oct 2018 02:05:06
Message: <5bd15d12$1@news.povray.org>
Am 24.10.2018 um 08:40 schrieb Thomas de Groot:
Ah, the experimetal new tokenizer! Now that changes things. Since we're
talking about alpha.9861167, I had presumed that you were using at least
some alpha as well.
Has it? I don't recall any such fix, nor it even being necessary. So
looks like something broke during the refactoring for the tokenizer
changes. That's conceivable.
I'll investigate that once I turn my attention back to the tokenizer.
Probably right where I left my glasses.
Date: 25 Oct 2018 02:39:27
Message: <5bd1651f$1@news.povray.org>
> some alpha as well.
Yes, it is bad practice to mix posts on different versions like I did. I
apologise.
>> more or less identical. It shows the warning for both cases indeed. I
>> had not been aware that the case had been solved in between. Thanks!
Well, it definitely was an issue with versions 3.6 and below, and, as
far as I recall, with version 3.7.
>> under psychiatric treatment after all ;-)
That might well be the case indeed.
Date: 26 Oct 2018 03:28:21
Message: <5bd2c215@news.povray.org>
Just to confirm, after testing: Also an issue with version
3.7.0.msvc10.win64
The correction must have been made in one of the 3.8.0 alphas.
Date: 26 Oct 2018 11:50:33
Message: <5bd337c9$1@news.povray.org>
Am 26.10.2018 um 09:28 schrieb Thomas de Groot:
> 3.7.0.msvc10.win64
Having dug a bit in the revision history (my memory isn't as good as it
used to be), there has indeed been such a fix, but that was already back
in v3.7.1-alpha.8913469. Commit 3f1de0d6, dated 2016-12-11.
Date: 27 Oct 2018 02:47:08
Message: <5bd409ec@news.povray.org>
>> 3.7.0.msvc10.win64
Ah OK. As a matter of fact, I do not have any of the 3.7.1 versions any
more... except UberPOV: 1.37.1.1-alpha.8871946.msvc14.win64, which also
shows the issue as it happens.
