POV-Ray : Newsgroups : povray.beta-test : A few possible bugs in POV-Ray 3.6 beta 2 Server Time
30 Sep 2024 02:12:32 EDT (-0400)
  A few possible bugs in POV-Ray 3.6 beta 2 (Message 1 to 7 of 7)
Subject: A few possible bugs in POV-Ray 3.6 beta 2
Date: 16 Mar 2004 12:33:21
Message: <40573a61$1@news.povray.org>
This is about Windows version of POV-Ray 3.6 beta 2 on Windows 2000.
First create a file "temp.dat" that has only one numerical value in it
("0", without quotes for example) in the same directory as the scene
below. When I try to render the scene, I get 'The instruction at ".."
referenced memory at "..". The memory could not be "read"'. This is the
scene:
#declare A = 0;
#macro Read_Data()
     #fopen File "temp.dat" read
     #read(File, A)
     #fclose File
Read_Data()
If the first line (#declare A=0;) is commented out I get the same error
expect '...could not be "written"'. In both cases I can read the next in
the message window:
"File context (5 lines):
0
Parse error: End of file reached but #end expected".
Now, if I place a comma after the "0" in temp.dat the scene parses
normally in both cases.
Interestingly the next scene renders normally even _without_ the comma
mentioned above - also without the declaration. The only difference is
that macro is not used.
#declare A = 0;
#read(File, A)
#fclose File
Also, if the "temp.dat" file does not exist POV-Ray gives "Runtime
Error!" and exits instantly.
Severi Salminen
Subject: Re: A few possible bugs in POV-Ray 3.6 beta 2
Date: 16 Mar 2004 14:14:41
Message: <40575221@news.povray.org>
In article <40573a61$1@news.povray.org> , Severi Salminen
> below.
Is the number followed by a newline?
    Thorsten
e-mail: tho### [at] trfde
Date: 16 Mar 2004 14:23:51
Message: <40575447$1@news.povray.org>
>>below.
It doesn't seem to matter: it crashes with or without a newline (when
the macro is being used).
Severi S.
Date: 25 Mar 2004 04:58:18
Message: <pan.2004.03.25.09.58.33.115885@gmx.ch>
I'm experiencing some similar problems connected to file I/O in 3.6b2 on
Mac OS (3.6b2 build 189, Mac OS X 10.3.2, PPC G4 867MHz, 768MB RAM).
The minimal scene is the following, the (slightly modified) example from
the docs (2.1.2.3.3):
#fopen MyFile "mydata.txt" read
#while (defined(MyFile))
  #read(MyFile, Var1, Var2, Var3)
  #debug concat(
    str(Var1, 0, 3), " ",
    str(Var2, 0, 3), " ",
    str(Var3, 0, 3), "\n"
When mydata.txt doesn't exist, I get "Possible Parse Error: Could not find
file 'mydata.txt' File test.pov line 1" in the Messages window, and the
Render Progress window indefinitely displays "00:00:00 Reclaiming memory"
with a barber pole. When I click "Stop", the Message window says "Stopping
render, please wait...", but nothing else happens - I have to quit POV-Ray
and restart it to get it into a working state again.
When mydata.txt contains N comma-terminated floats, and possibly one more
without trailing comma, the first (floor(N/3)) #reads succeed and the
corresponding debug messages appear, afterwards the Messages window says
"Parse Error: End of file reached but #end expected. File test.pov line 3"
and POV-Ray crashes shortly after (I can send the crash log if it helps).
By the way, #read and #write are not syntax-colored in the editor window.
 -Christian
Subject: Re: A few possible bugs in POV-Ray 3.6 beta 3
Date: 13 Apr 2004 07:14:07
Message: <407bcb7f$1@news.povray.org>
The same comma/macro related bug(s) exist (excluding the last bug when
the file doesn't exist - that is handled now correctly) also in Windows
version of POV-Ray 3.6 beta 3.
Severi S
Date: 13 Apr 2004 16:15:03
Message: <407c4a47$1@news.povray.org>
In article <407bcb7f$1@news.povray.org> , Severi Salminen
I am missing the context.  Please post a small example for what exactly is
still wrong.  Only the example is important.
    Thorsten
Date: 14 Apr 2004 03:43:19
Message: <407ceb97$1@news.povray.org>
Sorry, I was referring to my previous report. It is included below:
("0", without quotes, newline doesn't matter) in the same directory as
the scene below. When I try to render the scene, I get 'The instruction
at ".." referenced memory at "..". The memory could not be "read"'. This
is the scene:
#declare A = 0;
#macro Read_Data()
     #read(File, A)
     #fclose File
Read_Data()
Now, if I place a comma "," (no quotes) after the "0" in temp.dat the
scene parses normally in both cases.
Interestingly, the next scene renders normally even _without_ the comma
mentioned above - also without the first declaration. The only
difference is that macro is not being used.
#declare A = 0;
#read(File, A)
#fclose File
Severi S.
