POV-Ray : Newsgroups : povray.beta-test Server Time
14 Oct 2026 20:54:24 EDT (-0400)
  povray.beta-test (Thread 1 to 50 of 2453)
Older 50 Threads >>>
  Post a new message to this group
Date Last Post Subject Author
12 Jan 2026 12 Jan 2026 Demo POV +RTR at a "real time" SIGGRAPH thematic... (1) Mr
14 Oct 2025 16 Oct 2025 Version 3.8, status? (7) Paul Bourke
25 Sep 2025 25 Sep 2025 Cylinder / cone bounding (1) Bald Eagle
24 Sep 2025 10 Oct 2025 CSG Issues with disc shape. v38 beta 2. (18) William F Pokorny
13 Feb 2025 13 Feb 2025 Seam bugs / issues with bump_map. (3) William F Pokorny
16 Jan 2025 21 Jan 2025 material_map bug in v3.8 beta 2 (10) William F Pokorny
11 Dec 2024 11 Dec 2024 Collection of polygon object bugs / issues (1) William F Pokorny
27 Nov 2024 30 Nov 2024 Difference in wrapped vs raw wood in normal{} (6) William F Pokorny
19 Jun 2024 20 Jun 2024 Photons are broken with true inverse squared lig... (3) Cousin Ricky
8 Jun 2024 18 Nov 2024 v3.8+ crackle instability (facets?) with >1 uses... (28) William F Pokorny
11 May 2024 11 May 2024 Dynamic, CPU optimization, build bug and a patch. (1) William F Pokorny
27 Mar 2024 27 Mar 2024 A v3.8 / v4.0 divide by zero exposure AA samplin... (1) William F Pokorny
20 Mar 2024 2 May 2024 Re-discovering issues with finding ini files in ... (3) William F Pokorny
16 Mar 2024 16 Mar 2024 The github issue #458 affects v3.8 beta 2 / v4.0... (1) William F Pokorny
1 Mar 2024 2 Mar 2024 Stream <type>_file=false ini options not working. (4) William F Pokorny
27 Feb 2024 27 Feb 2024 Command line parsing bugs with '-v+w700' (1) William F Pokorny
27 Feb 2024 27 Feb 2024 Bugs related to the shell out string substitutions (1) William F Pokorny
7 Feb 2024 7 Feb 2024 v3.8 beta 2 unix / linux ini / flag parsing mess... (1) William F Pokorny
3 Feb 2024 7 Feb 2024 v3.8 beta 2. Some inconsistent gamma defaulting. (6) William F Pokorny
28 Jan 2024 28 Jan 2024 A v3.8 onward bug in version initialization. (1) William F Pokorny
4 Nov 2023 11 Nov 2023 A v3.8 / v4.0 / yuqk vector tuple assignment iss... (5) William F Pokorny
25 Oct 2023 25 Oct 2023 v3.8. Other than macro use of optional feature? (2) William F Pokorny
22 Oct 2023 22 Oct 2023 v3.8 b2. Bug(s) with deprecated feature (1) William F Pokorny
21 Oct 2023 30 Oct 2023 v3.8 b2. Deprecated feature doesn't work with ps... (11) William F Pokorny
21 Oct 2023 21 Oct 2023 v3.8 parse issue related to bare 'global' and 'l... (1) William F Pokorny
20 Oct 2023 22 Oct 2023 Bug and detail for, new at v3.8, global and loca... (3) William F Pokorny
7 Aug 2023 7 Aug 2023 Broken sqr() function implementation. (1) William F Pokorny
9 May 2023 28 Jul 2023 Assigning an interior crashes 3.8 beta 2 (7) Cousin Ricky
6 Apr 2023 7 Apr 2023 Possible v3,8 b2ta 2 fix for "Borked diacritical... (4) William F Pokorny
17 Mar 2023 17 Mar 2023 v3.8 b2. Exposure with number_of_waves parse vs ... (1) William F Pokorny
15 Mar 2023 15 Mar 2023 Image_map out of bounds color channel issue. v3.... (1) William F Pokorny
14 Mar 2023 15 Mar 2023 v3.8 beta 2. Bug with image_pattern use_index ke... (3) William F Pokorny
13 Mar 2023 13 Mar 2023 Intended image_pattern, etc, warning not generat... (1) William F Pokorny
15 Feb 2023 25 Mar 2026 v3.8b2. height_field input values at 0.0 not cle... (23) William F Pokorny
8 Feb 2023 14 Feb 2023 Spline causing 3.8 beta 2 to crash (22) Chris R
11 Jul 2022 14 Jul 2022 typ error (8) Saul Luizaga
26 May 2022 4 Nov 2022 Is this version still moving forward? (3) The Traveler
7 Mar 2022 13 Jan 2026 Ambient and diffuse for include files? (27) Cousin Ricky
28 Feb 2022 22 Nov 2024 Concerns with the tiling pattern's numerical sta... (3) William F Pokorny
13 Jan 2022 24 Jan 2022 weird white stain with beta povray v3.8.0 (not w... (23) Warren
1 Dec 2021 2 Dec 2021 v3.8 beta 2 command line option parsing (2) Chris R
26 Aug 2021 5 Oct 2021 v3.8 beta 2 seg fault. 32 bit raspbian os on 64 ... (3) William F Pokorny
22 Aug 2021 22 Aug 2021 return dict from macro (1) ingo
11 Aug 2021 12 Aug 2021 Call to Arms: Datetime (21) clipka
9 Aug 2021 13 Aug 2021 POV-Ray v3.8.0-beta.2 (6) clipka
8 Aug 2021 12 Aug 2021 `datetime(now)` issue - suggestions for a solution (16) clipka
7 Aug 2021 11 Aug 2021 LDD to POV ? (4) Denver Dave
3 Aug 2021 9 Aug 2021 POV-Ray v3.8.0-beta.1 issue #410 (23) jr
25 Jul 2021 12 Aug 2021 POV-Ray v3.8.0-beta 1 - Parse error using "%s" i... (36) Thomas de Groot
15 Jul 2021 16 Jul 2021 spline in, out array bug (5) ingo
