POV-Ray : Newsgroups : povray.beta-test : Re: crash when smooth heightfield Server Time
26 Sep 2024 17:44:27 EDT (-0400)
  Re: crash when smooth heightfield (Message 1 to 10 of 13)
Subject: Re: crash when smooth heightfield
Date: 11 May 2002 13:27:02
Message: <kqkqduocsbt16im7c4125n3pokid69jc36@4ax.com>
On Sat, 11 May 2002 18:58:23 +0200 peter wrote:
>attached heightfield makes RC4 win binary crash on my intel pentium machine.
>only happens when I use smooth option
  Oh, gosh... Thanks for the report, but the next time could you post
the binary to the p.beta-test.binaries group? You've also omitted
important system specs, which are requested here:
Message-ID <3B94E1CF.7498B010@pacbell.net>, in this group.
Alan
ako### [at] povrayorg
a k o n g <at> p o v r a y <dot> o r g
Date: 11 May 2002 14:35:16
Message: <3cdd6463@news.povray.org>
> machine. only happens when I use smooth option
Maybe it would be a great idea to supply some code which can't only be
executed on your own system.
Felix Wiemann
Date: 11 May 2002 19:56:04
Message: <3cddaf94@news.povray.org>
In article <3cdd6463@news.povray.org> , Felix Wiemann <Fel### [at] gmxnet>
All the include files were unnecessary :-(
I have been able track this down to a very odd way of parsing height_fields.
Even more interesting, even the docs showed this odd way.  A check in the
sample scenes showed no use of the odd "feature" so it will be gone in the
next beta as will be the problem:
Essentially the "smooth" is not supposed to be outside the height_field.  In
the scene it was in the object block, which was what caused the problem.  So
next time the parser will catch it as an error.  Moving the smooth into the
height_field block solves the problem.
Oh, and did I mention that this bug has been around at least since 3.1?  Well,
it actually has been around since smooth height_fields were introduced as far
as I can tell.  Anybody remember when they were introduced?
    Thorsten
BTW, the original post with its big attachment has been removed.
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 14 May 2002 11:12:39
Message: <3ce12967@news.povray.org>
>Well, it actually has been around since smooth height_fields were
>introduced as far as I can tell.  Anybody remember when they were
>introduced?
Well, since you're asking...
That must have been the legendary version 2.0 back in 1993.
Remember..., when clock was introduced? And automatic bounding slabs?
Getting quite melancholic here.
Good luck,
Jan Maarten van der Valk
Date: 14 May 2002 16:33:04
Message: <3ce1747f@news.povray.org>
  Wasn't automatic bounding introduced in 3.0?
Date: 15 May 2002 00:23:05
Message: <3CE1E336.E8C9D101@pacbell.net>
Yes.
Ken Tyler
Date: 16 May 2002 08:04:35
Message: <3ce3a053@news.povray.org>
Ken wrote:
>Yes.
No, in 2.0. (You challenged me into checking the docs ;-)
JM
Date: 16 May 2002 08:22:16
Message: <3ce3a478@news.povray.org>
>>Yes.
  I quite clearly remember that in 2.2 you had to bound objects by hand
if you wanted speed, but in 3.0 POV-Ray started to remove those user-specified
bounding objects (because it thought it could do better than me).
Date: 16 May 2002 12:12:07
Message: <3ce3da57$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3ce3a478@news.povray.org...
Which doesn't nec. mean that 2.2 didn't have auto-bounding, but it would
indicate that it was a) a bit crap and b) the developers knew that.
Date: 16 May 2002 20:55:56
Message: <3CE455B1.301CD5@pacbell.net>
> >>Yes.
From the POV-Ray v2.2 docs --
3.3.12 BOUNDING SLABS CONTROL
      -MB         Turn off bounding slabs
      +MBnnn      Use bounding slabs if more than nnn objects in scene.
New in POV-Ray 2.0 is a spatial sub-division system called bounding slabs.
It compartmentalizes all of the objects in a scene into rectangular slabs
and computes which slabs a particular ray hits before testing the objects
within the slab.  This can greatly improve rendering speed.  However for
scenes with only a few objects the overhead of using slabs is not worth the
effort.  The +MB switch sets the minimum number of objects before slabs are
used.  The default is +MB25.  The -MB switch turns off slabs completely.
I too thought they were introduced in 3.0 but it appears we both were wrong.
Ken Tyler
