POV-Ray : Newsgroups : povray.beta-test : known bugs 28 Jan 2002 Server Time
4 Jul 2026 00:41:28 EDT (-0400)
  known bugs 28 Jan 2002 (Message 8 to 17 of 17)
<<< Previous 7 Messages Goto Initial 10 Messages
Subject: Re: known bugs 28 Jan 2002
Date: 1 Feb 2002 17:50:21
Message: <Xns91A8B578C5E09CQ@204.213.191.226>
"Thorsten Froehlich" <tho### [at] trfde> wrote in
news:3c5a585f$1@news.povray.org:
> Note sure if this was noted before, but after resizing the mouse
> position needs to be inside the message window area.  If it is not,
> nothing happens of course.
Yep; it's been noted.  I posted that observation a while back.
Date: 2 Feb 2002 03:31:47
Message: <byOxjCApn5W8EwI1@econym.demon.co.uk>
Wasn't it Thorsten Froehlich who wrote:
>> Shadow faults
>> http://news.povray.org/3c53b38e@news.povray.org
>The simplified version works correctly.
No way! The shadows are missing until the boxes are put into a merge.
Mike Williams
Gentleman of Leisure
Date: 4 Feb 2002 05:53:11
Message: <rins5u8f9j7nnqhiu062nu0v1etb1dfqp0@4ax.com>
On Thu, 31 Jan 2002 16:53:39 +0100, "Thorsten Froehlich" <tho### [at] trfde>
wrote:
> > [win gui] line with error highlighted but render finished succesfully
> > http://news.povray.org/va2tvt4tuitd67ik5t9ps334sbg6205bt3@4ax.com
> Isn't the highlighted error simply a text selection?
Text selection is black on my computer while highlighted error makes whole line
yellow.
> Either way, the bug has not been confirmed.
confirmed in http://news.povray.org/Xns9198AD4D5BBF4CQ@204.213.191.226
I can describe additional situation when it appear if necessary.
> > another crash with max_intersections
> > http://news.povray.org/j8fo2u8mbo97gi3as0udmab7t9ttap2iom@4ax.com
> Note that setting "max_intersection 0" is simply brain-dead.
Is this logged or not ? When I reported it I know nonsense of this but when
somebody do this with wrongly constructed loop he shouldn't crash his engine.
> > rare conic prism bug
> > (strange behaviour of illumination/texture of conic prisms)
> > http://news.povray.org/3C51212E.9090707@irrwerk.de
> Not properly confirmed.  Just being able to reproduce the exact behavior is
> not enough.  At least a tiny bit of experimentation should be done to be able
> to say it is a bug and not a precision problem.
I confirmed this behaviour but you are right, this can be typicall precision
problem of orthographic camera. removing of "orthographic" keyword returns
functionality. Adding rotate y*3 to prism with orthographic camera also makes
all parts visible. So it is possible that it precision problem just like my old
report about tours in orthographic camera.
> > macros without commas takes parameter wrongly
> > http://news.povray.org/bp925u4upa1gl9kih2pikg4qusf0lr03kg@4ax.com
> Works as designed - not a bug.  Commas between macro parameters are required.
If commas are required then why parser not stoped parsing at macro declaration
with message like: "comma expected but T found" ? If it looks like feature
request then ignore it.
ABX
Date: 4 Feb 2002 07:44:48
Message: <3c5e8240@news.povray.org>
> line yellow.
Ah, I see.  As i don't use the Windows version a lot I justed wanted to make
sure it is not just some misunderstanding regarding the text selection (I.e.
on Macs it gets selected...)
It would automatically (without a message) set it to at least one, and I
changed it to 2 as minimum for the next beta some time ago.
By design all commas can be option for backward compatibility, but in many
cases the parser then can no longer tell what the user wants to do.  Possible
solutions are to make all commas mandatory (which IMO is a bad idea), or to
wait for a rewrite and then define more restrictive but variable rules for
comma requirements/options.
    Thorsten
e-mail: tho### [at] trfde
Date: 5 Feb 2002 20:50:46
Message: <slrna612vq.3h2.ron.parker@fwi.com>
On Thu, 31 Jan 2002 20:20:10 +0100, Simon Adameit wrote:
> The following code produces this error:
>  #local ohh=ahh <----ERROR
> Parse Error: Cannot assign uninitialized identifier.
And why is this a bug?
> Code:
> #fopen wfile "nothing.txt" write
> #fclose wfile
> #fopen rfile "nothing.txt" read
> #read(rfile,ahh)
This #read has to fail.  There's nothing for it to read.
> #ifdef(ahh)
>   #local ohh=ahh;
> #end
So it's defined but not initialized.  What's so wrong with that?
Aren't you supposed to check whether rfile is defined to detect
EOF rather than checking whether ahh is defined?
> #fclose rfile
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 5 Feb 2002 21:35:57
Message: <slrna615kh.3iv.ron.parker@fwi.com>
On Mon, 28 Jan 2002 02:05:17 +0000, Mike Williams wrote:
> crash during debugging of parsing (job0205)
> http://news.povray.org/332m2uspk9nfqfq6g7oc8qtmkcu5higjs7@4ax.com
Fixed for next beta.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 5 Feb 2002 21:40:50
Message: <slrna615tm.3iv.ron.parker@fwi.com>
> crash with loop (job000205)
> (infinite loop of "#local"s causes stack fault)
> http://news.povray.org/3c2cb9b7@news.povray.org
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 5 Feb 2002 22:06:00
Message: <slrna617cs.3iv.ron.parker@fwi.com>
> #while crash..
> http://news.povray.org/3c38646f@news.povray.org
Fixed in next beta.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 8 Feb 2002 21:30:19
Message: <slrna692dv.dae.ron.parker@fwi.com>
> #macro crush (job000206)
> http://news.povray.org/3c2c78cf$1@news.povray.org
Fixed, but probably not in the next beta.
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
Date: 8 Feb 2002 22:43:04
Message: <slrna696mc.db3.ron.parker@fwi.com>
> Array assignment crash (job000203)
> (It should overwrite the old array with the newly created, correct
> array, but crashes)
> http://news.povray.org/3bcc54ab$1@news.povray.org
Fixed, but not in beta 11.
