POV-Ray : Newsgroups : povray.animations : phase and bumps Server Time
8 Jul 2024 11:19:44 EDT (-0400)
  phase and bumps (Message 1 to 8 of 8)
Subject: phase and bumps
Date: 14 Oct 2003 21:20:01
Message: <web.3f8ca0086f671e0faeb8ce9d0@news.povray.org>
Hello to all,
I am trying to make an animation on a very low level, simulating the
movement of sand dunes. I tried to make it this way:
plane {
y, 0
    bumps
    color_map {
    [0.00 Yellow*0.1 ]
    [0.25 Yellow*0.3 ]
    [0.55 Yellow ]
    [1.00 Yellow*0.6 ]
    } scale <0.5,1,1.5> }
    normal { bumps 30 phase clock  scale <0.5,1,1.5> }
    finish{
      diffuse 0.8
      ambient 0.1
when replacing "bumps" with "gradient" or "marble" or other patterns, I can
see the effect I expected, but with bumps there is only an effect in the
background, near the horizon, and in the foreground happens nothing.
What am I making wrong?
TIA
Rm
Subject: Re: phase and bumps
Date: 15 Oct 2003 10:15:30
Message: <3f8d5682@news.povray.org>
"Steely" <Rob### [at] hamburgde> wrote in message
news:web.3f8ca0086f671e0faeb8ce9d0@news.povray.org...
can
Nothing... except for using phase in the bumps normal instead of the
color_map. It's just that phase doesn't work some patterns at all; and for a
few others, not in normals. So you can still animate the colors, just not
the surface normal. Unless you use a different pattern, of course.
The background might be appearing to change a little due to pixel jitter,
perhaps.
See the documentation index, look for phase. Section 6.7.12.2 Frequency and
Phase tells about it.
Bob H.
http://www.3digitaleyes.com
Date: 16 Oct 2003 04:55:01
Message: <web.3f8e5ccb5792a3403a2ad9f30@news.povray.org>
You are right, I should have read there before, it says clear that it
Thank You
Rm
Date: 16 Oct 2003 10:05:39
Message: <3f8ea5b3@news.povray.org>
Very welcome.
Maybe you could use an isosurface made from a pigment function which would
use your color map and phase in that. I'm not positive that the texture will
match up onto the isosurface, just reasons that it should.
If you haven't used color mapped patterns to create isosurfaces before it
goes about like this:
#declare F_Bumps=function {
    bumps
    color_map {
    [0.00 rgb 0.1 ] // color is ignored, only gray levels used
    [0.25 rgb 0.3 ]
    [0.55 rgb 1.0 ]
    [1.00 rgb 0.6 ]
     } phase clock }
isosurface {
 function {
  y
  F_Bumps(x,y,z).gray
  0.25 // rescale
 contained_by {box {<-10,-1,-10>,<10,0,10>}}
 accuracy 0.01
 max_gradient 30
    bumps
    color_map {
    [0.00 rgb <1,1,0>*0.1 ]
    [0.25 rgb <1,1,0>*0.3 ]
    [0.55 rgb <1,1,0> ]
    [1.00 rgb <1,1,0>*0.6 ]
    } phase clock }
    finish{
      diffuse 0.8
      ambient 0.1
   scale <0.5,1,1.5>
Bob H.
Date: 17 Nov 2003 19:40:01
Message: <web.3fb969855792a3401e2d84430@news.povray.org>
try that. Thanks.
Rm
Date: 18 Nov 2003 12:38:07
Message: <3fba58ff@news.povray.org>
news:web.3fb969855792a3401e2d84430@news.povray.org...
would
will
will
> try that. Thanks.
I'm lucky to remember this at all, where've you been?  :-D Only joking.
IIRC that isosurface and phase-shifting wasn't keeping to a single surface.
That meaning, there were parts filling the voids where the bump pattern
hollowed out, as it changed. Similar to a boiling lava lamp fluid. If you
get what I'm saying. At least that it seemed likely to need a way to retain
a singular surface to resemble what you wanted to do. Like a turbulent water
surface yet no splashes, that's a better way of saying it rather than
boiling lava lamp I guess. Off-hand I'm not sure how that would be
accomplished without trial and error to modify the pattern (mix with
gradient y?).
Date: 21 Feb 2008 01:50:01
Message: <web.47bd1e855792a34085a1c64d0@news.povray.org>
The same problem - "bumps" is not affected by the "phase keyword"...
Date: 21 Feb 2008 10:11:15
Message: <47bd9493$1@news.povray.org>
Do you realize you replied to a 5-year-old thread?
