POV-Ray : Newsgroups : povray.advanced-users : Smooth, continuous Bezier splines (again) Server Time
10 Nov 2025 17:25:01 EST (-0500)
  Smooth, continuous Bezier splines (again) (Message 6 to 15 of 25)
<<< Previous 5 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Smooth, continuous Bezier splines (again)
Date: 28 Jan 2025 15:55:00
Message: <web.679943ee96675d9f327467e125979125@news.povray.org>
> but then I need to figure out how to solve for sets of control point coordinates
> that give me matching curvatures.
.. . . and this must be just the thing:
https://ntrs.nasa.gov/api/citations/19900012238/downloads/19900012238.pdf
Date: 29 Jan 2025 10:55:00
Message: <web.679a4e6d96675d9fdd186bde89db30a9@news.povray.org>
> "ingo" <nomail@nomail> wrote:
> > The bisect of the angles in the current lines are the normals to the handles in
> > that point. The handles should be equally long to get C1/G1 (?) continuity.
> > I think, without testing,
> Yes, excellent idea.
Hi Bill
The code below shows the results of what I think Ingo suggested.
Tor Olav
http://subcube.com
https://github.com/t-o-k
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.7;
global_settings { assumed_gamma 1.0 }
default {
        pigment { color White }
        finish {
            diffuse 0
            emission color White
#macro CubicBezierFn(c0, c1, c2, c3)
    function(s) {
        0
        + pow(1 - s, 3)*c0
        + 3*pow(1 - s, 2)*s*c1
        + 3*(1 - s)*pow(s, 2)*c2
        + pow(s, 3)*c3
#end // macro CubicBezierFn
#macro Plot(FnX, FnY, FnZ, NoOfSegments, Radius)
    #local dS = 1/NoOfSegments;
    union {
        #local S0 = 0;
        #local p0 = <FnX(S0), FnY(S0), FnZ(S0)>;
        // sphere { p0, Radius }
        #for (I, 0, NoOfSegments - 2)
            #local S1 = S0 + dS;
            #local p1 = <FnX(S1), FnY(S1), FnZ(S1)>;
            cylinder { p0, p1, Radius }
            sphere { p1, Radius }
            #local S0 = S1;
            #local p0 = p1;
        #end // for
        // sphere { p1, Radius }
#end // macro Plot
#declare Debug = false;
#declare NoOfPoints = 9;
#declare Points =
    array[NoOfPoints] {
        <-0.297/2, -1.000, 0.000>,
        <-0.203/2, -0.500, 0.000>,
        <-0.115/2, -0.250, 0.000>,
        <-0.069/2, -0.125, 0.000>,
        < 0.000/2,  0.000, 0.000>
        <+0.069/2, -0.125, 0.000>,
        <+0.115/2, -0.250, 0.000>,
        <+0.203/2, -0.500, 0.000>,
        <+0.297/2, -1.000, 0.000>,
#declare R = 0.006;
#if (true)
    union {
        #for (I, 0, NoOfPoints - 1)
            sphere { Points[I], R }
        #end // for
#end // if
#declare NoOfOrthogonalVectors = NoOfPoints - 1;
#declare OrthogonalVectors = array[NoOfOrthogonalVectors];
#for (I, 0, NoOfOrthogonalVectors - 1)
    #declare OrthogonalVectors[I] = vnormalize(vcross(Points[I+1] - Points[I],
z));
#end // for
#if (Debug)
    union {
            cylinder {
                0*z, OrthogonalVectors[I], R/4
                translate (Points[I] + Points[I+1])/2
        #end // for
        pigment { color Red }
#end // if
#declare NoOfBisectingVectors = NoOfPoints;
#declare BisectingVectors = array[NoOfBisectingVectors];
#declare BisectingVectors[0] = OrthogonalVectors[0];
#for (I, 1, NoOfBisectingVectors - 2)
    #declare BisectingVectors[I] = vnormalize(OrthogonalVectors[I-1] +
OrthogonalVectors[I]);
#end // for
#declare BisectingVectors[NoOfBisectingVectors-1] =
OrthogonalVectors[NoOfOrthogonalVectors-1];
#if (Debug)
    union {
        #for (I, 0, NoOfBisectingVectors - 1)
            cylinder {
                0*z, BisectingVectors[I], R/4
                translate Points[I]
        #end // for
        pigment { color Magenta }
#end // if
#declare NoOfTangentVectors = NoOfBisectingVectors;
#declare TangentLengths =
    array[NoOfTangentVectors] {
        0.10,
        0.10,
        0.08,
        0.04,
        0.01,
        0.04,
        0.08,
        0.10,
        0.10
#declare TangentVectors = array[NoOfTangentVectors];
#for (I, 0, NoOfTangentVectors - 1)
    #declare TangentVectors[I] = TangentLengths[I]*vcross(+z,
BisectingVectors[I]);
#end // for
#if (Debug)
    union {
            cylinder {
                0*z, +TangentVectors[I], R/4
                translate Points[I]
            cylinder {
                0*z, -TangentVectors[I], R/4
                translate Points[I]
        #end // for
        pigment { color Blue }
#end // if
#declare NoOfSegments = 16;
#for (I, 0, NoOfPoints - 2)
    #declare pA = Points[I  ];
    #declare pB = Points[I  ] + TangentVectors[I  ];
    #declare pC = Points[I+1] - TangentVectors[I+1];
    #declare pD = Points[I+1];
    #if (Debug)
        union {
            // sphere { pA, R }
            sphere { pB, R }
            sphere { pC, R }
            // sphere { pD, R }
    #end // if
    object {
        Plot(
            CubicBezierFn(pA.x, pB.x, pC.x, pD.x),
            CubicBezierFn(pA.y, pB.y, pC.y, pD.y),
            CubicBezierFn(pA.z, pB.z, pC.z, pD.z),
            NoOfSegments,
            R/4
        pigment { color Black }
        translate -1.0*z
#end // for
background { color Gray40 }
#declare AR = image_width/image_height;
    orthographic
    location < 0.0, -0.5, -2.0>
    right AR*x
    up y
    direction z
    angle 30
Date: 29 Jan 2025 12:34:11
Message: <679a6693$1@news.povray.org>
>      function(s) {
>          0
>          + pow(1 - s, 3)*c0
>          + pow(s, 3)*c3
Perhaps time to add an inbuilt f_bezier_cubic() to yuqk too. :-)
Bill P.
Date: 29 Jan 2025 13:30:00
Message: <web.679a730696675d9fdd186bde89db30a9@news.povray.org>
> >      function(s) {
> >          0
> >          + pow(1 - s, 3)*c0
> >          + pow(s, 3)*c3
Yes, that would be nice.
Then comes the question if adding f_bezier_quadratic() and f_bezier_quartic()
also is a good idea.
And then if the various derivative functions of them should be added...
Tor Olav
http://subcube.com
Date: 29 Jan 2025 14:20:00
Message: <web.679a7ef296675d9f327467e125979125@news.povray.org>
I thought there was already some kind of Bezier spline function - but maybe not
as a proper function.  We have that spline in prism {}.  Unless we consider
user-defined spline functions "good enough".
Might it not be "easier", more useful, and more general to have a single
Bezier/Bernstein function that takes the number of control points as an
argument, and can just assemble the spline on the fly? Then you wouldn't need
multiple functions.
And aren't the derivatives just other Bezier splines?
I'm just thinking that if it was done that way, people could really begin to
harness the power of these splines without having to ascend the steep learning
curve.
Also having a feature where the user could just switch over to a linear spline
would allow looping through the control points - perhaps to draw out the control
points and polygon - without having to write another whole block of code to do
so.
Degree elevation and reduction would be super sweet to have as well.
And, if you want, I can provide the curvature functions - which are useful for
designing function-driven textures, examining how splines fit together, etc.
Big rabbit hole to go down, but IMHO, in 2025, a computer graphics program
really ought to have an entire in-built Bezier spline library.
- BW
Date: 29 Jan 2025 15:02:39
Message: <679a895f$1@news.povray.org>
On 1/29/25 13:27, Tor Olav Kristensen wrote:
>> Perhaps time to add an inbuilt f_bezier_cubic() to yuqk too. 🙂
I've grabbed code over time for some 2D functions I planned to call
f_bezier_2d_quartic() and f_bezier_2d_quintic().
Do you have - or know of - 3D code for either of these?
Or for a 3D quadratic?  I might have the quadratic 3D form in my notes
notes somewhere or in my TCL wrapper script (where I'd coded up some
simpler spline by segment types maybe 15 years ago). I wonder if
quadratic that useful excepting having better performance?
FYI. As yuqk inbuilt functions the convenient versions (packed vectors)
for 3D forms would be limited to a -10 to +10 box and single float
accuracy rather than double for the any 2D forms.
As for the derivative forms, if you have code in hand, maybe we do a few
  near term? I don't have anything ready to go.
The question too is whether some of this 'spline stuff' better fits in
spline{} like SDL feature - one supporting the Bezier segment control
point forms. We can describe many segment curves, function wrap, but
what we can do dynamically from the render time VM is limited.
Aside: Jerome coded up a bunch of spline extensions in his hgpovray38
fork (which 'maybe' came from megapov?). I don't recall any additional
Bezier support, but my memory is not great these days.
Bill P.
Date: 29 Jan 2025 15:30:00
Message: <web.679a8f9996675d9f327467e125979125@news.povray.org>
Maybe I'm misunderstanding, but:
They're not dimensional - they're parametric.
Take any N-D point and the spline just interpolates ALL of the dimensions with
the same equations.
Right?
Date: 29 Jan 2025 15:50:00
Message: <web.679a939896675d9f327467e125979125@news.povray.org>
Thank you.  I thought this would grab your attention - however I was hoping to
get some free time to do something with it before you submitted the solution!
:D
Too late.  You win.
I'll take a look when I get home in an hour.
Date: 29 Jan 2025 16:30:00
Message: <web.679a9cb296675d9f5ad2295d89db30a9@news.povray.org>
> :D
> Too late.  You win.
Ingo is guilty too..
You are aware that you do not HAVE to look at my code, or?
You have probably noticed that I have only provided a 2D solution, with all the
points within a XY-plane.
Now, if you like a little extra challenge, you can rewrite the code so that it
can provide a full 3D solution.
Tor Olav
http://subcube.com
Date: 29 Jan 2025 19:10:00
Message: <web.679ac2e996675d9fcc90517889db30a9@news.povray.org>
That is actually not a simple challenge: There are difficult decisions to
be made if 3 of the given points lies on a line.
A simpler challenge is to change the code so that your endpoints are joined
smoothly too.
Tor Olav
http://subcube.com
