POV-Ray : Newsgroups : povray.advanced-users : Negative subscript in while loop Server Time
14 Dec 2025 14:55:37 EST (-0500)
  Negative subscript in while loop (Message 1 to 4 of 4)
Subject: Negative subscript in while loop
Date: 15 Jan 2023 18:15:00
Message: <web.63c487f2edb901151f9dae3025979125@news.povray.org>
So, I'm trying to convert some online code to SDL,
( https://github.com/xmdi/CAD-from-Scratch/blob/main/016/geom.c  )
and the conditions in the while statement
     #while( j >= 0 & bins[j] > key)
don't protect against j being negative.
"C:\Users\Mini\Documents\POV-Ray\v3.8-beta\scenes\DelaunayTriangulateTest1.pov"
line 226: Parse Error: Negative subscript
Render failed
Probably because they're collected in one line / statement and are therefore all
evaluated together, and the while loop doesn't terminate until that expression
is fully evaluated.
I managed to hacktastically bypass / protect against this with some additional
protective wrappers to the loop, but this doesn't seem like it ought to be
necessary, or else there ought to be a more elegant way to correct this in SDL.
Unless the while source code has a bug that I've triggered, and _I've broken
POV-Ray AGAIN_.   :\
 // sort points by proximity
 #local NbinRows = ceil(pow(numpoints, 0.25));
 #local bins = array [numpoints+1];
 #for (i, 0, numpoints)
  #local  p = (points[i][1] * NbinRows*0.999); // bin row
  #local  q = (points[i][0] * NbinRows*0.999); // bin column
  #if (mod(p, 2))
   #local bins[i] = (p+1) * NbinRows - q;
  #else
   #local bins[i] = p * NbinRows + q + 1;
 #for (i, 1, numpoints) // insertion sort
  #local key = bins[i];
  #local tempF = array {points[i][0], points[i][1]};
  #local  j = i - 1;
  #debug "------------------------------------------------\n"
  #debug concat ("      i = ", str (i, 0, 0), "\n")
  #debug concat ("bins[i] = ", str (bins[i], 0, 0), "\n")
  #debug concat ("bins[j] = ", str (bins[j], 0, 0), "\n")
  #if (j > 0)
   #local bins[j+1] = bins[j];
   #local points[j+1][0] = points[j][0];
   #local points[j+1][1] = points[j][1];
   #local j = j-1;
   #debug concat ("j = ", str (j, 0, 0), "\n")
   #if (j<0) #break #end
  #end // end while
  #local bins[j+1] = key;
  #local points[j+1][0] = tempF[0];
  #local points[j+1][1] = tempF[1];
Also, if anyone can tell me if this is C, C++, or C#, and how to properly
interpret and convert statements such as:
int* bins=malloc(numPoints*sizeof(int));
points=realloc(points,(3+numPoints)*2*sizeof(float));
int (*verts)[3]=malloc(3*sizeof(int));
int (*tris)[3]=malloc(3*sizeof(int));
int *triangleStack=malloc((numPoints-3)*sizeof(int));
tris=realloc(tris,(nT)*3*sizeof(int));
verts=realloc(verts,(nT)*3*sizeof(int));
int *renumberAdj=calloc(nT,sizeof(int));
bool *deadTris=calloc(nT,sizeof(bool));
int (*verts_final)[3]=malloc(3*nT_final*sizeof(int));
int (*tris_final)[3]=malloc(3*nT_final*sizeof(int));
that would be great.  I kinda get it, but a clear explanation from someone who
know the native language PLUS SDL, would help doing any such future conversions.
Maybe I could even write a small macro to make declaring such arrays a bit more
foolproof.
Subject: Re: Negative subscript in while loop
Date: 15 Jan 2023 21:15:00
Message: <web.63c4b23631017364383c879289db30a9@news.povray.org>
> Render failed
> is fully evaluated.
You may want to have a look at these questions, answers and comments::
What is "short-circuiting" in C like languages?
https://softwareengineering.stackexchange.com/questions/201896/what-is-short-circuiting-in-c-like-languages
What is short-circuit evaluation in C?
https://stackoverflow.com/questions/45848858/what-is-short-circuit-evaluation-in-c
Is short-circuiting logical operators mandated? And evaluation order?
https://stackoverflow.com/questions/628526/is-short-circuiting-logical-operators-mandated-and-evaluation-order
My opinion is that writing code that depends on short circuiting is
bad practice (i.e. hard to understand and debug - and not so portable,
as you have now experienced).
> POV-Ray AGAIN_.   :\
>   #if (mod(p, 2))
>   #else
>   #end
>  #end
>   #local  j = i - 1;
>   #if (j > 0)
>    #local j = j-1;
>   #end // end while
>   #end
>  #end
You can try something like this:
(NB: Untested code)
// Sort points by proximity
#local NoOfBinRows = ceil(pow(NoOfPoints, 0.25));
#local Bins = array[NoOfPoints+1];
#for (I, 0, NoOfPoints)
    #local P = Points[I][1]*NoOfBinRows*0.999; // bin row
    #local Q = Points[I][0]*NoOfBinRows*0.999; // bin column
    #local Bins[I] = P*NoOfBinRows + (mod(P, 2) = 0 ? Q + 1 : NoOfBinRows - Q);
#end // for
// Insertion sort
#for (I, 1, NoOfPoints)
    #local Key = Bins[I];
    #local TempF_0 = Points[I][0];
    #local TempF_1 = Points[I][1];
    #local J = I - 1;
    #local Continue = (Bins[J] > Key);
    #while (Continue)
        #local Bins[J+1] = Bins[J];
        #local Points[J+1][0] = Points[J][0];
        #local Points[J+1][1] = Points[J][1];
        #local J = J - 1;
        #local Continue = (J >= 0);
        #if (Continue)
        #end // if
    #end // while
    #local Bins[J+1] = Key;
    #local Points[J+1][0] = TempF_0;
    #local Points[J+1][1] = TempF_1;
#end // for
Btw.: I'm suspicious of the *0.999 calculations.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 15 Jan 2023 21:35:00
Message: <web.63c4b7a931017364383c879289db30a9@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> // Insertion sort
>     #local J = I - 1;
>     #while (Continue)
>         #local J = J - 1;
>         #if (Continue)
>         #end // if
>     #end // while
> #end // for
If the assignments after the while loop goes wrong, then you can try
to change lines at the end of the while loop like this:
        #local Continue = (J >= 1);
        #if (Continue)
            #local J = J - 1;
        #end // if
Tor Olav
http://subcube.com
Subject: rt_circuiting_is_veeeery_common_in_C=2e?
Date: 17 Jan 2023 01:40:27
Message: <63c642db@news.povray.org>
But in C those expressions are a quite common idiome, like
#define IsNullOrEmpty(s)  ((s)==NULL || (s)[0]=='\0')
or – even more common - in expressions like this:
if( s && s->value )
and a lot of C code rely on the short circui rule in these expressions.
And – IMHO – these expressions are not hard to debug, because 's' can be
evaluated easily e.g. in a debugger.
But of course, PovRay scene files are not C. :-)
Lars R.
