POV-Ray : Newsgroups : povray.advanced-users : run povray from matlab Server Time
30 Mar 2026 06:18:16 EDT (-0400)
  run povray from matlab (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: run povray from matlab
Date: 13 Feb 2006 02:13:19
Message: <43f0318f$1@news.povray.org>
Hi!
> 1. I'm a new user and I need examples to understand you, if you do'nt mind.
That's no problem at all. Keep in mind, though, that this newsgroup is
for advanced questions. I saw you tried povray.newusers first, so you
know about that. For a question like yours, povray.general would've been
the best group. But here we go :)
> 2. first i'm using ver pov3.6 for windows, and i have xp windows version.
Okay. This version of POV-Ray will *always* open the POV-Ray window, and
you have no option to change that. But you can use another version of
POV-Ray, an unofficial compile called MegaPOV, which can be run from the
command line without opening a window (MegaPOV allows you to do the same
things as normal POV-Ray but has some extra patches for experimental
features added). You can get MegaPOV from http://megapov.inetart.net.
Download and install it.
> 3. second, i want to run pov lot's of time from matlab, and every time the
>    same pov file but with new values (which given from malab function) other
>    the last time, without open the pov window.
You'll have to find a way to pass your values to the POV scene file, if
they are different all the time. Or do you write your scene file on the
fly? If not, write the values into an include file which is then
included via "#include" by your scene file.
When calling MegaPOV, make sure you use the command line executable, not
the graphical interface one (it comes with two executables, both are
placed in the same folder as the original POV-Ray executable IIRC).
> 4. i want to read the gray level values in the pov program.
Let's leave that question unanswered until we finished your problems
above. Better to concentrate on one thing at a time :)
> 5. again, lot's of thanks.
You're welcome. If you still have problems with the explanations above,
just ask again (and add some details about what's not working as expected).
Florian
Date: 13 Feb 2006 03:15:00
Message: <web.43f03ee73493ed528f0d338e0@news.povray.org>
Florian Brucker <tor### [at] torfboldcom> wrote:
> Hi!
> Florian
Hoo my friend Florian
1. sorry to disturb u, but...
2. I have download the megapov, and i want to know how to run my plan from
   matlab without openinig the pov window.
3. I want to continue step by step as your good offer.
4. Thanks again.
shimon
Date: 13 Feb 2006 14:12:39
Message: <43f0da27$1@news.povray.org>
Hi Shimon!
Okay, so you've downloaded (and installed?) MegaPOV. Fine! Now look into
your folder where the original POV-Ray executable is stored (By default
that's somewhere in C:\Program Files\POV-Ray\binaries, I'm not on
Windows here, so I can't check, sorry). There should also be 2 MegaPOV
executables in that directory. Try which one is the command line one in
case you can't make it out from the filenames (Just doubleclick on them
and see which one does not popup the usual POV-Ray window).
Then replace your call to POV-Ray with the call to the command line
MegaPOV. How are you calling POV-Ray right now? I'm not using Matlab too
much, so I guess your code looks like
     !C:\Program Files\POV-Ray\binaries\pvengine.exe
or
    system('C:\Program Files\POV-Ray\binaries.pvengine.exe')
Just replace 'pvengine.exe' with the filename you just found out - Your
script should now run without opening a POV-Ray window.
Did that work so far? If not, what went wrong? Can you please post the
Matlab code you're using to run POV-Ray?
HTH,
Florian
Date: 16 Feb 2006 16:25:01
Message: <web.43f4ecf13493ed526a80623e0@news.povray.org>
> Hi Shimon!
> that's somewhere in C:Program FilesPOV-Raybinaries, I'm not on
>      !C:Program FilesPOV-Raybinariespvengine.exe
> or
>     system('C:Program FilesPOV-Raybinaries.pvengine.exe')
> HTH,
> Florian
Hi for my friend Florian Brucker
1. I've replaced the 'pvengine.exe' to 'mpengine.exe', and it open the
   megapov window when the file is runinig. which means that my script
   dosen't
2. now my old friend i need your help.
3. have all bless.
4. bye.
shimon
Date: 16 Feb 2006 16:51:18
Message: <43f4f3d6$1@news.povray.org>
According to the MegaPOV website, the current version is shipped with
*two* executables: One which behaves like the standard POV-Ray (i.e.
opening a window) and another which is a command line version (which
doesn't open a window). In the zip-file there's a mpengine.exe and a
megapov.exe. Did you try both?
HTH,
Florian
Date: 16 Feb 2006 17:05:00
Message: <web.43f4f6163493ed526a80623e0@news.povray.org>
> Hi Shimon!
> or
> HTH,
> Florian
Hi Florian
1. the matlab code that i'm using is
! mpengine +Ipovfile.pov +V +Wscreen_width +Hscreen_height
2. bye
shimon
Date: 18 Feb 2006 12:10:00
Message: <web.43f7546d3493ed52af74ad090@news.povray.org>
> HTH,
> Florian
Florian Florian my friend
1. I've tried the two option's, and the megapov.exe file dose'nt runing the
   povfile, and is opening DOS window insted of runing the povfile.
2. help me please...
3. little of houmer..
4. lots of thanks.
shimon
Date: 19 Feb 2006 12:41:08
Message: <43f8adb4$1@news.povray.org>
Hm. It should do the job, though. I'm not sure what goes wrong, and as I
said before I'm on Linux and haven't done any Windows in ages. Perhaps
you could ask in povray.unofficial.patches.
HTH,
Florian
Date: 21 Feb 2006 08:51:10
Message: <43fb1ace$1@news.povray.org>
shimon_a10 wrote:
> I'll be glad if you help me with:
> 1. i run pov files from matlab, but the curser do'nt return to matlab
>    command window ,and even if it's return to matlab ,i have to close pov
>    for run other file of pov from matlab.
Of course, you have to tell POV-Ray to close after it is done. Please check
the section "Special Command-Line Options" in the Windows specific part of
the documentation: <http://www.povray.org/documentation/view/3.6.1/603/>
If you execute another program, usually the program from within you do so
will wait until the program it executes terminates. usually you can disable
this feature, which means you have to look for that in the Matlab documentation.
However, it will be a lot more practical to just tell POV-Ray for Windows to
terminate after rendering using the "/EXIT" command-line option.
	Thorsten
Date: 22 Feb 2006 15:55:01
Message: <web.43fcce633493ed5219d73fb90@news.povray.org>
>  Thorsten
lots thanks for u Thorsten
1. as amemmber of POV-Team i want to ask u how to run MegaPov without
   opening the MegaPov window.
2. thanks again.
shimon
