POV-Ray : Newsgroups : povray.advanced-users : Non ascii characters Server Time
10 Apr 2026 16:24:09 EDT (-0400)
  Non ascii characters (Message 1 to 10 of 11)
Subject: Non ascii characters
Date: 14 Sep 2005 08:35:01
Message: <web.432818c5c895b29ca14d5b880@news.povray.org>
with a space character):
example:
without the utf8 option i've the following errors:
File: etat.txt  Line: 4
Possible Parse Error: Non-ASCII character has been replaced by space
character.
character.
with the option, the precedent errors disappear, but i've got new ones:
File: titreSimulation.pov  Line: 7
Parse Warning: Character 105 (0x8C69) not found in ariblk.ttf
Parse Warning: Character 47 (0x8B2F) not found in ariblk.ttf
Thanks for your help
ben
Subject: Re: Non ascii characters
Date: 14 Sep 2005 11:32:58
Message: <432842aa$1@news.povray.org>
It seems that the font you are using does not include this letter. Each
font does only provide graphics (they're called glyphs IIRC) for a
limited subset of all letters. You'll have to choose a different font or
letter to solve the problem...
To see which glyphs your font provides, use the font-viewer of your
operating system.
HTH,
Florian
Date: 14 Sep 2005 17:28:32
Message: <MPG.1d9242dafcfb98ec989df2@news.povray.org>
In article <432842aa$1@news.povray.org>, tor### [at] torfboldcom says...
> operating system.
> HTH,
> Florian
Was going to suggest checking with UnicodeView http://www.lischke-
online.de/FontViewer.php then realized that since UTF8 is supported, but
Unicode isn't (I think), it probably doesn't do any good at all. :(
Still, useful gadget to have around.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 15 Sep 2005 00:00:00
Message: <web.4328f0c359bee683b0677c700@news.povray.org>
> example:
> character.
> character.
> Regards,
> ben
That's odd. I vaguely remember using non-standard characters before using
[alt + ####]. Alt-130 shows the character in the text editor, but it
doesn't render. Try just putting a ' over an e.
Date: 15 Sep 2005 04:45:00
Message: <web.432933be59bee683a14d5b880@news.povray.org>
global_settings{
#declare title = "Su00e9rie";
And as suggested by Florian, i've changed my font to Arial.ttf then it
works...
Date: 26 Nov 2005 13:00:00
Message: <web.4388a0eb59bee683c181fd400@news.povray.org>
I've always been able to create text objects including letters with marks
like accents, tildes, diaeresis, etc., just denoting them with their
"charset" sentence in "global_settings"...
Moreover, I've written an include file declaring string variables, each one
containing a single Unicode character.
Date: 26 Nov 2005 13:20:51
Message: <4388a783$1@news.povray.org>
FYI, UFT8 *is* an Unicode encoding.
	Thorsten
Date: 26 Nov 2005 16:02:55
Message: <MPG.1df27b12119b6afd989e80@news.povray.org>
In article <4388a783$1@news.povray.org>, tho### [at] trfde says...
> 	Thorsten
How can it be, given that it doesn't allow access to all unicode
characters? It by definition can't, since true unicode requires a
'section' code, followed by a 'character' code, of *always* two bytes.
UTF8 treats only specific characters as a 'section' code, so part of the
unicode set if unavailable. Unless I am completely missing something...
But I have seen people complain before about how they can't use some
character with POV-Ray and the reason always given is that UTF8 doesn't
support them. If I am wrong, then why does this problem crop up all the
time?
void main () {
  else
Date: 26 Nov 2005 16:31:24
Message: <4388d42c$1@news.povray.org>
There is no such thing as a "section code" in Unicode. Unicode defines one
continuous set of character codes. UTF8 is an encoding of Unicode, providing
access to all Unicode character codes. You definition is clearly wrong; I
suspect you are confusing Unicode with "code pages" from long forgotten DOS
and early Windos times.
> time?
Because* people do not realise that most editors, including those included
with POV-Ray for Windows and POV-Ray for Macintosh do *not* save text files
in UTF8 but ISO-8859-1 and MacRoman respectively.  As such, entering any
character outside the ASCII range and setting "charset" to "utf8" causes
POV-Ray to try to interpret those an UTF8 sequences, which they are not.
This of course yields all kinds of strange errors, with POV-Ray rejecting
characters many times, or replacing them with blanks after issuing a warning
(it depends).
	Thorsten
* This applies to POV-Ray 3.5 and later only.
Date: 27 Nov 2005 15:48:22
Message: <MPG.1df3c8fc63d04152989e81@news.povray.org>
In article <4388d42c$1@news.povray.org>, tho### [at] trfde says...
No, I am not confusing them, I just don't know the right term, so guessed
at one. But to be clear, what would this $2039 be in UTF8? Would it be a
space and a 0, or the 0/00 symbol? If the later, then Ok, sorry for the
confusion. If that is the case, then we need to fix the editor so it
correctly supports the characters.
> > time?
> (it depends).
Sounds like there are serious bugs in the support.. Maybe a binary field
type would be useful, like the html # numbers? It seems quite ridiculous
to support it, but have that support be effectively broken.
void main () {
  else
