POV-Ray : Newsgroups : povray.advanced-users : Non ascii characters Server Time
17 Apr 2026 02:15:24 EDT (-0400)
  Non ascii characters (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Non ascii characters
Date: 14 Sep 2005 11:32:58
Message: <432842aa$1@news.povray.org>
> with the option, the precedent errors disappear, but i've got new ones:
> File: titreSimulation.pov  Line: 7
> Parse Warning: Character 105 (0x8C69) not found in ariblk.ttf
It seems that the font you are using does not include this letter. Each
font does only provide graphics (they're called glyphs IIRC) for a
limited subset of all letters. You'll have to choose a different font or
letter to solve the problem...
To see which glyphs your font provides, use the font-viewer of your
operating system.
HTH,
Florian
Date: 14 Sep 2005 17:28:32
Message: <MPG.1d9242dafcfb98ec989df2@news.povray.org>
In article <432842aa$1@news.povray.org>, tor### [at] torfboldcom says...
> operating system.
> HTH,
> Florian
Was going to suggest checking with UnicodeView http://www.lischke-
online.de/FontViewer.php then realized that since UTF8 is supported, but
Unicode isn't (I think), it probably doesn't do any good at all. :(
Still, useful gadget to have around.
void main () {
    call functional_code()
  else
    call crash_windows();
Date: 15 Sep 2005 00:00:00
Message: <web.4328f0c359bee683b0677c700@news.povray.org>
"benahpets" <ben### [at] hotmailcom> wrote:
> with a space character):
> example:
> without the utf8 option i've the following errors:
> File: etat.txt  Line: 4
> Possible Parse Error: Non-ASCII character has been replaced by space
> character.
> character.
> Parse Warning: Character 47 (0x8B2F) not found in ariblk.ttf
> Thanks for your help
> Regards,
> ben
That's odd. I vaguely remember using non-standard characters before using
[alt + ####]. Alt-130 shows the character in the text editor, but it
doesn't render. Try just putting a ' over an e.
Date: 15 Sep 2005 04:45:00
Message: <web.432933be59bee683a14d5b880@news.povray.org>
global_settings{
#declare title = "Su00e9rie";
And as suggested by Florian, i've changed my font to Arial.ttf then it
works...
Date: 26 Nov 2005 13:00:00
Message: <web.4388a0eb59bee683c181fd400@news.povray.org>
I've always been able to create text objects including letters with marks
like accents, tildes, diaeresis, etc., just denoting them with their
"charset" sentence in "global_settings"...
Moreover, I've written an include file declaring string variables, each one
containing a single Unicode character.
Date: 26 Nov 2005 13:20:51
Message: <4388a783$1@news.povray.org>
FYI, UFT8 *is* an Unicode encoding.
	Thorsten
Date: 26 Nov 2005 16:02:55
Message: <MPG.1df27b12119b6afd989e80@news.povray.org>
In article <4388a783$1@news.povray.org>, tho### [at] trfde says...
> 	Thorsten
How can it be, given that it doesn't allow access to all unicode
characters? It by definition can't, since true unicode requires a
'section' code, followed by a 'character' code, of *always* two bytes.
UTF8 treats only specific characters as a 'section' code, so part of the
unicode set if unavailable. Unless I am completely missing something...
But I have seen people complain before about how they can't use some
character with POV-Ray and the reason always given is that UTF8 doesn't
support them. If I am wrong, then why does this problem crop up all the
time?
void main () {
  else
Date: 26 Nov 2005 16:31:24
Message: <4388d42c$1@news.povray.org>
There is no such thing as a "section code" in Unicode. Unicode defines one
continuous set of character codes. UTF8 is an encoding of Unicode, providing
access to all Unicode character codes. You definition is clearly wrong; I
suspect you are confusing Unicode with "code pages" from long forgotten DOS
and early Windos times.
> time?
Because* people do not realise that most editors, including those included
with POV-Ray for Windows and POV-Ray for Macintosh do *not* save text files
in UTF8 but ISO-8859-1 and MacRoman respectively.  As such, entering any
character outside the ASCII range and setting "charset" to "utf8" causes
POV-Ray to try to interpret those an UTF8 sequences, which they are not.
This of course yields all kinds of strange errors, with POV-Ray rejecting
characters many times, or replacing them with blanks after issuing a warning
(it depends).
	Thorsten
* This applies to POV-Ray 3.5 and later only.
Date: 27 Nov 2005 15:48:22
Message: <MPG.1df3c8fc63d04152989e81@news.povray.org>
In article <4388d42c$1@news.povray.org>, tho### [at] trfde says...
No, I am not confusing them, I just don't know the right term, so guessed
at one. But to be clear, what would this $2039 be in UTF8? Would it be a
space and a 0, or the 0/00 symbol? If the later, then Ok, sorry for the
confusion. If that is the case, then we need to fix the editor so it
correctly supports the characters.
> > time?
> (it depends).
Sounds like there are serious bugs in the support.. Maybe a binary field
type would be useful, like the html # numbers? It seems quite ridiculous
to support it, but have that support be effectively broken.
void main () {
  else
Date: 5 Dec 2005 07:48:52
Message: <slrndp8dpk.joc.bisqwit@bisqwit.iki.fi>
You must be confusing something.
Unicode is a character-set with integer range 00000-1FFFF mapping to
different characters.
You can use http://bisqwit.iki.fi/japtools/unicodemap.php to browse it,
for example.
For example, the character U+05E1 always means the hebrew letter samekh,
and nothing else. There is no "section code" (whatever that means).
In UTF-8, the unicode characters are encoded in varying number of bytes.
UTF-8 encoding:
bytes	bits	representation
1	7	0bbbbbbb
2	11	110bbbbb 10bbbbbb
3	16	1110bbbb 10bbbbbb 10bbbbbb
4	21	11110bbb 10bbbbbb 10bbbbbb 10bbbbbb
Each b represents a bit that can be used to store character data.
So, the character U+05E1, which is in 010111100001 in binary,
is encoded as 11010111 10100001, that is, E7 A1.
The character U+0041, that is the latin capital letter "A",
is encoded as 01000001, that is, 41, which, not coincidentally,
is exactly the same as "A" in ASCII.
Joel Yliluoma - http://bisqwit.iki.fi/
: comprehension = 1 / (2 ^ precision)
: Try to be as precise as can be and no one will comprehend what you mean.
: Say nothing, and everybody will understand.
