POV-Ray : Newsgroups : povray.advanced-users : function optimization question Server Time
24 Mar 2026 12:59:06 EDT (-0400)
  function optimization question (Message 36 to 45 of 65)
Subject: Re: function optimization question
Date: 19 Mar 2002 11:20:52
Message: <slrna9epb4.ejm.ron.parker@fwi.com>
> On 19 Mar 2002 10:41:16 -0500, Ron Parker <ron### [at] povrayorg> wrote:
>> What, assembly-language-like bytecode isn't good enough for you?  Kids these
>> days...
> My asked for my daughter. She likes building functions in macros and render in
> one pass ;-)
>> I think at the moment that it's a bonus pack for patch writers.  I don't know
>> what the Team's plans are WRT the debugging features
> http://news.povray.org/3c2caae6@news.povray.org
Well, there ya go then.  Straight from the horse's mouth.  Of course, since
it's just turned off with a compile-time switch, enterprising patch writers
will be able to turn it back on easily.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 19 Mar 2002 11:21:51
Message: <0ape9uormom5m6kg6v7hn5ld9nm2o92mmk@4ax.com>
On 19 Mar 2002 11:11:22 -0500, Ron Parker <ron### [at] povrayorg> wrote:
> That documentation looks something like this:
and it's very similiar to 6.1.6.6 chapter :-)
ABX
Date: 19 Mar 2002 11:26:13
Message: <slrna9epl7.ejm.ron.parker@fwi.com>
I'm obviously missing something... there is no 6.1.6.6???
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 19 Mar 2002 11:29:28
Message: <pnpe9uk2an43j2rvp72b6b8qrominjqgpd@4ax.com>
It was supposed to be a joke since there is also no "else if(Token.Token_Id ==
STRING_LITERAL_TOKEN)" in my installation of documentation ;-)
ABX
Date: 19 Mar 2002 11:32:46
Message: <slrna9eq1g.eln.ron.parker@fwi.com>
That's because you don't have the source code package, and all the
documentation it customarily comes with.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 19 Mar 2002 11:39:43
Message: <3C9769CB.293D5093@gmx.de>
Ron Parker wrote:
> There is no source code package yet, right?  And when there is, there will
> be the same documentation I used to find this feature.
>     else if(Token.Token_Id == STRING_LITERAL_TOKEN)
This of course was not what i meant, i meant a description of how to write
those assembly instructions.  A list of available commands and some
documented samples would help a lot.
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Mar 2002 11:41:12
Message: <slrna9eqha.emg.ron.parker@fwi.com>
Oh.  Well, you're in luck there.  There is a significant amount of
documentation for the bytecode in the appropriate source file.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 19 Mar 2002 11:46:58
Message: <3C976B7F.FB30FD25@gmx.de>
Great.
I'm eagerly waiting to see it...
Date: 19 Mar 2002 14:35:50
Message: <3c979316@news.povray.org>
  That's luxury!
  The only valid input for functions should be opcodes written in hexadecimal!
Date: 30 Mar 2002 05:09:45
Message: <3ca58ee9@news.povray.org>
>   That's luxury!
I'm wondering, what kind of instruction word this ASM-interpreter uses ...
are they more CISC- or more RISC- like ? ...
BTW: What 'bout self-modifying code ? ... that would be nice ... back to oldschool
