Here is another result...
> Bald Eagle writes:
>> Even if I were to simply use a POV-Ray scene, where I rendered two ima
ges with
>> different camera locations - then I'm assuming that I could calculate
a vector
>> field and a projection matrix. (something simple like cubes, spheres,
and cylinders)
>> Given The projection matrix and one of the two renders, would I then h
ave the
>> necessary and sufficient information to write a .pov scene to recreate
the
>> render from scratch?
>> - BW
> For the moment, the work with depth from monocular vision is not enough
> advanced that we can recreate the visible scene. Vision with two camera
s
> or more, gives a much advanced result for 3D reconstruction of scenes.
> Let remind us the starting point from this thread... We've redone the
> experiment from Hernan Badino, who is walking with a camera on his head
> Hernan determines his 2D ego-motion in the x-y plane, from correspondin
g
> interest points that persist in the video stream. That means he is
> calculating the projection matrix of the movement to deduce translation
s
> in the ground plane. With time integration, it gives him the trajectory
> We're doing almost the same, but I work with OpenCV's optical-flow, and
> not interest points. And my motion model is 3D, to obtain 8 parameters
> in rotation and translation, that I can use in Persistence Of Vision.
> I hope you're understanding... I'm reconstituting the 3D movement, and
I
> discover it's giving "temporal disparity", that is depth from motion.
An instrumented motorcycle rolls on the track of a speed circuit. Thanks
to the approximation of optical flow (DIS - OpenCV) by the dominant
projective movement, we determine translations on the ground plane,
roll and yaw. That is to say the trajectory by projective parameters
(Tx,Tz,Ry,Rz).
<https://www.youtube.com/watch?v=-QLJ2ke9mN8>
Image data comes from the publication:
Bastien Vincke, Pauline Michel, Abdelhafid El Ouardi, Bruno Larnaudie,
o
Rodriguez, Abderrahmane Boubezoul. (Dec. 2024). Real Track Experiment
Dataset for Motorcycle Rider Behavior and Trajectory Reconstruction.
Data in Brief, Vol. 57, 111026.
The instrumented motorcycle makes a complete lap of the track. The
correlation threshold is set at 90% between successive images, to
reset the calculation of the projective dynamic model.
Best regards,
<https://eureka.atari.org/>
Monocular Depth :
<https://www.youtube.com/watch?v=34zUDqEzHos>
A drone flies between the trees of a forest. Thanks to the optical-flow
measured on successive images, the temporal disparity reveals the
forest of trees... We take a reference image, the optical-flow is
measured on two rectified images. Then we change the reference when
the inter-correlation drops below 60%. We can perceive the relief in
depth with a single camera, over time.
In fact, when we watch images captured by a drone, although there is
only one camera, we often see the relief. This is particularly marked
for trees in a forest. The goal here is to evaluate this relief, with a
measurement of "optical-flow", which allows one image to be matched with
another, when they seem to be close (we say they are "correlated").
We have two eyes, and the methods for measuring visible relief by
stereoscopy are very developed. Since the beginning of photography,
there were devices like the “stereoscope” which allows yo
u to see the
relief with two pictures, naturally. It is possible to measure relief,
thanks to epipolar geometry, and well-known mathematics. There are many
measurement methods, very effective and based on human vision.
When it comes to measuring relief with a single camera, knowledge is
less established. There are 3D cameras, called "RGBD" with a "D" for
"depth". But how do they work? Is it possible to improve those? What
I am showing here does not require the use of any “artificial neu
ral
network”. It is a physical measurement, with a classic algorithm,
which does not come from A.I. nor a big computer :-)
Best regards,
François LE COAT
Francois LE COAT writes:
> Monocular Depth :
h
you to see the
eural
m,
A WEB page was made to illustrate Monocular Depth...
<https://hebergement.universite-paris-saclay.fr/lecoat/demoweb/monocular_
depth.html>
This is about measuring monocular depth, just as stereoscopic disparity
is measured. It means quantifying the depth, with images from a single
camera. We can see this relief naturally, but it is a matter of
measuring it with the optical-flow :-)
Best regards,
François LE COAT
>> Monocular Depth:
w
a
th
you to see the
y
neural
hm,
r_depth.html>
Until now, drone images came from forests in France. The first images
were obtained in the French Vosges.
<https://www.youtube.com/watch?v=245yJJrwMQ0> Drone in the forest
We are now seeing more and more drones in forests outside of France.
The available image sources are diversifying...
Best regards,
François LE COAT
>>> Monocular Depth:
ow
a
ith
s you to see the
ny
neural
thm,
ar_depth.html>
y
Here is another example of drone in the forest, outside from France:
<https://www.youtube.com/watch?v=BO_OUFHFzTY> Forest
We also obtained the trajectory in the X-Z plane, of the flight:
<https://sketchfab.com/3d-models/forest-e253ebd61e2a4bd6abcd21ac56f25bae>
These are filtered measurements and it's not ideal computer graphics.
Best regards,
François LE COAT
e>
Here is a sequence of images of a ballad in the forest. This scene
is observed by a tracking drone...
<https://www.youtube.com/watch?v=46VWJ6-YqtY>
The camera's movement is estimated in the images using a projective
dominant motion measurement. The presence of a man in the image sequence
does not interfere with trajectory estimation, because the character
occupies a position in the field of vision that is not dominant. The
dominant motion corresponds to the scrolling of the scenery, that is
the movement of the forest relative to an observing camera.
Best regards,
ae>
e
Here is a drone in the forest...
<https://www.youtube.com/watch?v=h3vhlRBB9tg> Forest
We also obtain the trajectory in space: <https://skfb.ly/pxGqL>
It's interesting to note that this trajectory loops. That is to say,
the drone passes over the professional pilot's location, and is in
the same place at the end of the video.
This proves the quality of the trajectory estimation in space. :-)
Best regards,
bae>
ce
Here's a long drone flight through a Swedish forest...
<https://www.youtube.com/watch?v=ppW5BbDPFHc> Swedish forest
We obtain the estimated trajectory in space: <https://skfb.ly/pxZHy>
The image matching algorithm doesn't incorporate any prior knowledge
about what the camera is observing. This might look like a SLAM
(Simultaneous Localization And Mapping) method, which is a sparse
method, but what is presented is a global and dense method based
on optical-flow measurement (Dense Inverse Search - DIS).
This is an algorithm, i.e. a numerical recipe, that does not use
artificial neural networks. We obtain a filtered measurement (by
a Kalman filter) of physical data.
Best regards,
Here's a drone's long flight through the forest in France...
<https://www.youtube.com/watch?v=f_Zi811qWFI>
We're in rather complicated lighting conditions, with shadows and
clouds. Hence the significant noise in the video. The optical-flow
(DIS - OpenCV) that allows the determination of monocular depth
performs rather well. Mathematicians refer to this determination
as an "ill-posed problem". But statistically, for the large images
we're dealing with, it works well :-)
Best regards,
Here's a sequence of images from a drone in the forest.
<https://www.youtube.com/watch?v=gOAwt0I7GNE>
These image computing looks like SLAM (Simultaneous Localization and
Mapping) method. We obtain both the location (trajectory) and the
visible relief (3D depth map). However, we're dealing with a monocular
(single camera) image sequence, not a stereoscopic (human vision) one.
Here's the drone's trajectory in space: <https://skfb.ly/pCyBy>
Best regards,
