POV-Ray : Newsgroups : povray.advanced-users : Optical Inertia Server Time
27 Jun 2026 01:23:34 EDT (-0400)
  Optical Inertia (Message 15 to 24 of 24)
Subject: Re: Optical Inertia
Date: 15 May 2025 08:45:01
Message: <6825e1cd$1@news.povray.org>
Francois LE COAT writes:
> Here is another example of drone in the forest, outside from France:
> <https://www.youtube.com/watch?v=BO_OUFHFzTY> Forest
> We also obtained the trajectory in the X-Z plane, of the flight:
> <https://sketchfab.com/3d-models/forest-e253ebd61e2a4bd6abcd21ac56f25ba
e>
> These are filtered measurements and it's not ideal computer graphics.
Here is a sequence of images of a ballad in the forest. This scene
is observed by a tracking drone...
	<https://www.youtube.com/watch?v=46VWJ6-YqtY>
The camera's movement is estimated in the images using a projective
dominant motion measurement. The presence of a man in the image sequence
does not interfere with trajectory estimation, because the character
occupies a position in the field of vision that is not dominant. The
dominant motion corresponds to the scrolling of the scenery, that is
the movement of the forest relative to an observing camera.
Best regards,
<https://eureka.atari.org/>
Date: 30 May 2025 09:51:05
Message: <6839b7c9@news.povray.org>
ae>
e
Here is a drone in the forest...
<https://www.youtube.com/watch?v=h3vhlRBB9tg> Forest
We also obtain the trajectory in space: <https://skfb.ly/pxGqL>
It's interesting to note that this trajectory loops. That is to say,
the drone passes over the professional pilot's location, and is in
the same place at the end of the video.
This proves the quality of the trajectory estimation in space. :-)
Best regards,
Date: 18 Jun 2025 09:15:02
Message: <6852bbd6$1@news.povray.org>
bae>
ce
Here's a long drone flight through a Swedish forest...
<https://www.youtube.com/watch?v=ppW5BbDPFHc> Swedish forest
We obtain the estimated trajectory in space: <https://skfb.ly/pxZHy>
The image matching algorithm doesn't incorporate any prior knowledge
about what the camera is observing. This might look like a SLAM
(Simultaneous Localization And Mapping) method, which is a sparse
method, but what is presented is a global and dense method based
on optical-flow measurement (Dense Inverse Search - DIS).
This is an algorithm, i.e. a numerical recipe, that does not use
artificial neural networks. We obtain a filtered measurement (by
a Kalman filter) of physical data.
Best regards,
Date: 16 Sep 2025 09:30:04
Message: <68c9665c$1@news.povray.org>
Here's a drone's long flight through the forest in France...
	<https://www.youtube.com/watch?v=f_Zi811qWFI>
We're in rather complicated lighting conditions, with shadows and
clouds. Hence the significant noise in the video. The optical-flow
(DIS - OpenCV) that allows the determination of monocular depth
performs rather well. Mathematicians refer to this determination
as an "ill-posed problem". But statistically, for the large images
we're dealing with, it works well :-)
Best regards,
Date: 21 Oct 2025 10:35:05
Message: <68f79a19$1@news.povray.org>
Here's a sequence of images from a drone in the forest.
	<https://www.youtube.com/watch?v=gOAwt0I7GNE>
These image computing looks like SLAM (Simultaneous Localization and
Mapping) method. We obtain both the location (trajectory) and the
visible relief (3D depth map). However, we're dealing with a monocular
(single camera) image sequence, not a stereoscopic (human vision) one.
Here's the drone's trajectory in space: <https://skfb.ly/pCyBy>
Best regards,
Date: 4 Nov 2025 10:15:04
Message: <690a1878$1@news.povray.org>
Here's a sequence of images from a drone in the forest:
	<https://www.youtube.com/watch?v=ToRk-o1cD_4>
This image computing looks like SLAM (Simultaneous Localization and
The question that arises, then, is why do highly accurate inertial
navigation systems drift? Why are loop-closing methods, used with the
SLAM algorithm? Would an optical inertial navigation system be subject
to drift in the trajectory it estimates? That's debatable, isn't it?
Best regards,
Date: 18 Nov 2025 09:10:15
Message: <691c7e47$1@news.povray.org>
This is a large sequence of images from a drone in the forest:
<https://www.youtube.com/watch?v=22QoxEwMBQA> The forest
The sequence is constituted of 10 000 images at 60 frames per second.
It is both large and high-resolution.
Here's the drone's trajectory in space: <https://skfb.ly/pDCwR>
Best regards,
Date: 9 Dec 2025 09:30:01
Message: <69383269$1@news.povray.org>
This is a sequence of images from a drone in the forest:
<https://www.youtube.com/watch?v=Kt0mkFYX45A> Drone
The drone flies very slowly compared to the acquisition rate of 30
frames per second. This makes it much easier to observe the trajectory
and visible depth. The successive images in the sequence are highly
correlated. It is not necessary to frequently reset the reference image
selection over time, as the correlation between this image and
subsequent images remains well above the 60% threshold chosen for
resetting.
Best regards,
Date: 14 Jan 2026 09:15:03
Message: <6967a4e7$1@news.povray.org>
> resetting.
<https://www.youtube.com/watch?v=hFcDUU626po> Swedish woods
This image computing called 3D Optical Inertia looks like SLAM
(Simultaneous Localization and Mapping) method. We obtain both
the location (trajectory) and the visible relief (3D depth map).
However, we're dealing with a monocular (single camera) image
Here is the spline trajectory in space: <https://skfb.ly/pFx6u>
Best regards,
Date: 28 Apr 2026 09:45:03
Message: <69f0b9df$1@news.povray.org>
Here is a sequence of images of a ballad in the forest. This scene is
	<https://www.youtube.com/watch?v=b4aTYv7A1lM>
the movement of an observing camera relative to the forest.
Best regards,
