POV-Ray : Newsgroups : povray.advanced-users : Optical Inertia Server Time
8 Apr 2026 14:26:10 EDT (-0400)
  Optical Inertia (Message 13 to 22 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Optical Inertia
Date: 1 Apr 2025 13:15:03
Message: <67ec1f17$1@news.povray.org>
Francois LE COAT writes:
>> Monocular Depth:
>> <https://www.youtube.com/watch?v=34zUDqEzHos>
>> A drone flies between the trees of a forest. Thanks to the optical-flo
w
>> measured on successive images, the temporal disparity reveals the
>> forest of trees... We take a reference image, the optical-flow is
>> measured on two rectified images. Then we change the reference when
>> the inter-correlation drops below 60%. We can perceive the relief in
>> depth with a single camera, over time.
>> In fact, when we watch images captured by a drone, although there is
>> only one camera, we often see the relief. This is particularly marked
>> for trees in a forest. The goal here is to evaluate this relief, with
a
>> measurement of "optical-flow", which allows one image to be matched wi
th
>> another, when they seem to be close (we say they are "correlated").
>> We have two eyes, and the methods for measuring visible relief by
>> stereoscopy are very developed. Since the beginning of photography,
>> there were devices like the “stereoscope” which allows
 you to see the
>> relief with two pictures, naturally. It is possible to measure relief,
>> thanks to epipolar geometry, and well-known mathematics. There are man
y
>> measurement methods, very effective and based on human vision.
>> When it comes to measuring relief with a single camera, knowledge is
>> less established. There are 3D cameras, called "RGBD" with a "D" for
>> "depth". But how do they work? Is it possible to improve those? What
>> I am showing here does not require the use of any “artificial
neural
>> network”. It is a physical measurement, with a classic algorit
hm,
>> which does not come from A.I. nor a big computer :-)
> A WEB page was made to illustrate Monocular Depth...
> <https://hebergement.universite-paris-saclay.fr/lecoat/demoweb/monocula
r_depth.html>
> This is about measuring monocular depth, just as stereoscopic disparity
> is measured. It means quantifying the depth, with images from a single
> camera. We can see this relief naturally, but it is a matter of
> measuring it with the optical-flow :-)
Until now, drone images came from forests in France. The first images
were obtained in the French Vosges.
<https://www.youtube.com/watch?v=245yJJrwMQ0> Drone in the forest
We are now seeing more and more drones in forests outside of France.
The available image sources are diversifying...
Best regards,
François LE COAT
<https://eureka.atari.org/>
Date: 17 Apr 2025 09:15:04
Message: <6800fed8$1@news.povray.org>
>>> Monocular Depth:
ow
 a
ith
s you to see the
ny
 neural
thm,
ar_depth.html>
y
Here is another example of drone in the forest, outside from France:
	<https://www.youtube.com/watch?v=BO_OUFHFzTY> Forest
We also obtained the trajectory in the X-Z plane, of the flight:
<https://sketchfab.com/3d-models/forest-e253ebd61e2a4bd6abcd21ac56f25bae>
These are filtered measurements and it's not ideal computer graphics.
Best regards,
François LE COAT
Date: 15 May 2025 08:45:01
Message: <6825e1cd$1@news.povray.org>
e>
Here is a sequence of images of a ballad in the forest. This scene
is observed by a tracking drone...
	<https://www.youtube.com/watch?v=46VWJ6-YqtY>
The camera's movement is estimated in the images using a projective
dominant motion measurement. The presence of a man in the image sequence
does not interfere with trajectory estimation, because the character
occupies a position in the field of vision that is not dominant. The
dominant motion corresponds to the scrolling of the scenery, that is
the movement of the forest relative to an observing camera.
Best regards,
Date: 30 May 2025 09:51:05
Message: <6839b7c9@news.povray.org>
ae>
e
Here is a drone in the forest...
<https://www.youtube.com/watch?v=h3vhlRBB9tg> Forest
We also obtain the trajectory in space: <https://skfb.ly/pxGqL>
It's interesting to note that this trajectory loops. That is to say,
the drone passes over the professional pilot's location, and is in
the same place at the end of the video.
This proves the quality of the trajectory estimation in space. :-)
Best regards,
Date: 18 Jun 2025 09:15:02
Message: <6852bbd6$1@news.povray.org>
bae>
ce
Here's a long drone flight through a Swedish forest...
<https://www.youtube.com/watch?v=ppW5BbDPFHc> Swedish forest
We obtain the estimated trajectory in space: <https://skfb.ly/pxZHy>
The image matching algorithm doesn't incorporate any prior knowledge
about what the camera is observing. This might look like a SLAM
(Simultaneous Localization And Mapping) method, which is a sparse
method, but what is presented is a global and dense method based
on optical-flow measurement (Dense Inverse Search - DIS).
This is an algorithm, i.e. a numerical recipe, that does not use
artificial neural networks. We obtain a filtered measurement (by
a Kalman filter) of physical data.
Best regards,
Date: 16 Sep 2025 09:30:04
Message: <68c9665c$1@news.povray.org>
Here's a drone's long flight through the forest in France...
	<https://www.youtube.com/watch?v=f_Zi811qWFI>
We're in rather complicated lighting conditions, with shadows and
clouds. Hence the significant noise in the video. The optical-flow
(DIS - OpenCV) that allows the determination of monocular depth
performs rather well. Mathematicians refer to this determination
as an "ill-posed problem". But statistically, for the large images
we're dealing with, it works well :-)
Best regards,
Date: 21 Oct 2025 10:35:05
Message: <68f79a19$1@news.povray.org>
Here's a sequence of images from a drone in the forest.
	<https://www.youtube.com/watch?v=gOAwt0I7GNE>
These image computing looks like SLAM (Simultaneous Localization and
Mapping) method. We obtain both the location (trajectory) and the
visible relief (3D depth map). However, we're dealing with a monocular
(single camera) image sequence, not a stereoscopic (human vision) one.
Here's the drone's trajectory in space: <https://skfb.ly/pCyBy>
Best regards,
Date: 4 Nov 2025 10:15:04
Message: <690a1878$1@news.povray.org>
Here's a sequence of images from a drone in the forest:
	<https://www.youtube.com/watch?v=ToRk-o1cD_4>
This image computing looks like SLAM (Simultaneous Localization and
The question that arises, then, is why do highly accurate inertial
navigation systems drift? Why are loop-closing methods, used with the
SLAM algorithm? Would an optical inertial navigation system be subject
to drift in the trajectory it estimates? That's debatable, isn't it?
Best regards,
Date: 18 Nov 2025 09:10:15
Message: <691c7e47$1@news.povray.org>
This is a large sequence of images from a drone in the forest:
<https://www.youtube.com/watch?v=22QoxEwMBQA> The forest
The sequence is constituted of 10 000 images at 60 frames per second.
It is both large and high-resolution.
Here's the drone's trajectory in space: <https://skfb.ly/pDCwR>
Best regards,
Date: 9 Dec 2025 09:30:01
Message: <69383269$1@news.povray.org>
This is a sequence of images from a drone in the forest:
<https://www.youtube.com/watch?v=Kt0mkFYX45A> Drone
The drone flies very slowly compared to the acquisition rate of 30
frames per second. This makes it much easier to observe the trajectory
and visible depth. The successive images in the sequence are highly
correlated. It is not necessary to frequently reset the reference image
selection over time, as the correlation between this image and
subsequent images remains well above the 60% threshold chosen for
resetting.
Best regards,
