POV-Ray : Newsgroups : povray.advanced-users : Speeding up media Server Time
30 Apr 2026 04:58:25 EDT (-0400)
  Speeding up media (Message 1 to 10 of 32)
Subject: Speeding up media
Date: 5 Feb 2021 05:59:14
Message: <601d2502$1@news.povray.org>
I have a planetary atmosphere with both scattering and absorption
interior media. It renders very slowly. Any tips on speeding it up? Thanks.
Mike
Subject: Re: Speeding up media
Date: 5 Feb 2021 05:59:53
Message: <601d2529$1@news.povray.org>
> Mike
Here is the media:
// atmosphere
#declare RWorld_Atmos_Color_Scatter	= <0.1, 0.3, 1.0>;
#declare RWorld_Atmos_Color_Absorb	= <0.9, 0.7, 0.0>;		// should be the
inverse of RWorld_Atmos_Color_Scatter
#declare RWorld_Atmosphere_Object = difference
	cylinder {<0,+RWorld_Ring_Width/2,0>,		<0,-RWorld_Ring_Width/2,0>,
RWorld_Ring_Radius - 1}	//
	cylinder {<0,+RWorld_Ring_Width/2 + 1,0>,	<0,-RWorld_Ring_Width/2 -
1,0>,	RWorld_Ring_Radius - RWorld_Atmosphere_Height}
	bounded_by
	hollow
	material
		texture
			pigment {rgbt 1}
		interior
			media
				scattering
					4, RWorld_Atmos_Color_Scatter
				density
					// Reverse: It starts at 1.0 at the origin and decreases to a
minimum value of 0.0 as it approaches a distance of 1 unit from the Y axis.
					function {1-f_cylindrical(x,y,z)}
					density_map
						[0 rgb 0/10]
						[1-RWorld_Atmosphere_Height/RWorld_Ring_Radius rgb 0/10]
						[1 rgb 1/10]
					scale RWorld_Ring_Radius
			media
				absorption RWorld_Atmos_Color_Absorb
				density
					density_map
						[0 rgb 0/10]
						[1 rgb 1/10]
Date: 5 Feb 2021 07:00:00
Message: <web.601d3280df5181b61f9dae300@news.povray.org>
> Mike
it's likely not your media - but your media settings.
try:
http://news.povray.org/povray.newusers/message/%3C59a9ec1c%40news.povray.org%3E/#%3C59a9ec1c%40news.povray.org%3E
Date: 5 Feb 2021 09:55:09
Message: <web.601d5bbedf5181b679819d980@news.povray.org>
hi,
> Here is the media: ...
tweaking the code may gain you some, but, perhaps, you can cheat and clip the
sphere/planet just behind the horizon, saving ~40%.
>       [0 rgb 0/10]
confused why you don't write just '[0 rgb 0]'.
regards, jr.
Date: 6 Feb 2021 02:41:24
Message: <601e4824$1@news.povray.org>
Op 05/02/2021 om 11:59 schreef Mike Horvath:
>> Thanks.
>> Mike
> Here is the media:
I am studying/testing your media, but need a little time...
Date: 6 Feb 2021 22:41:29
Message: <601f6169$1@news.povray.org>
> try:
I'm not sure how that applies to my case. I am not using emissive media
or the "samples" keyword.
Mike
Date: 6 Feb 2021 22:43:00
Message: <601f61c4$1@news.povray.org>
On 2/5/2021 9:52 AM, jr wrote:
> hi,
It's actually a cylinder or ring, so it reflects upon itself on the insides.
>>        [0 rgb 0/10]
> regards, jr.
I use fractions a lot and like to keep the source code tidy.
Mike
Date: 7 Feb 2021 02:23:31
Message: <601f9573$1@news.povray.org>
Op 07/02/2021 om 04:41 schreef Mike Horvath:
>> try:
There is nothing really wrong with your code as far as I can tell and
from own experience. From the outside (of the media) it is even rather
fast due to the default intervals 1 and samples 1 (Yes! you /do/ use
samples, even if you don't).
However, depending on the location of the camera within or without the
media, render times can be very different; you even may need to increase
the samples value to avoid splotches, and that will decrease render time
even more although not that much.
Using media is time consuming. There is no alternative.
Date: 8 Feb 2021 10:16:10
Message: <602155ba$1@news.povray.org>
>>> try:
>> media or the "samples" keyword.
The default for samples is 10.
samples default to 1 when using sampling method 1 or 2.
The default are, as of version 3.6 :
sampling_method 3
intervals 1 //DO NOT increase !
samples 10
Increasing intervals dramatically increase the rendering time without
giving any appreciable improvement.
samples 10 intervals 3 render slower than samples 50 intervals 1.
Date: 9 Feb 2021 02:30:23
Message: <60223a0f@news.povray.org>
Op 08/02/2021 om 16:16 schreef Alain Martel:
>>>> try:
>> increase the samples value to avoid splotches, and that will decrease
>> render time even more although not that much.
> sampling_method 3
> samples 10
I don't know where in the wiki there was a line saying defaults being
intervals 1 and samples 1,1. Of course, I cannot find that paragraph
anymore (typical!); but you are right of course: default samples is 10.
